Forum » Pomoč in nasveti » Hyper-Treading Technology
him ::
Imam Pentiuma 4, 3.00Ghz, ki podpira HT. Vendar mi HT ne deluje, saj je menda težava v BIOSu in Chipsetu. Matična je ASRock P4V88: FSB800MHz, DDR400.
S programom Hyper-Threading Technology Test Utility, z Intelove strani sem pa preveril
zakaj mi HT ne dela.
http://img395.imageshack.us/img395/4779/clips21ar.gif
5er--> ::
him ::
Tako je poročilo testa:
ADVISORY! The Hyper-Threading Technology Test Utility
was unable to identify if all the core components are present, turned on or functional in this system.
Without all required components, Hyper-Threading Technology is not fully enabled.
Processor test: Passed
Chipset test: Did not pass
BIOS test: Did not pass
Please contact your PC system manufacturer or vendor where you purchased your computer system
if you expected it to be enabled with Hyper-Threading Technology.
him ::
Je pa res da mam CPU usage history razdvojen... Torej naj bi deloval?
5er--> ::
Ja, dela. Samo tisi program od intela je tup, pa verjetno pravilno prepozna samo svoje matične
| » | Mticna plosca i845PeOddelek: Strojna oprema | 1930 (1713) | mtosev |
| » | procesor intel core2duo E6600: vprasanjeOddelek: Kaj kupiti | 2440 (1932) | TechBeats |
| » | kakšen procesor je P4 531 (3.0Ghz/800MHz/1Mb, int NIC)?Oddelek: Strojna oprema | 1894 (1614) | opeter |
| » | s katerim procesorjem nadgraditi p4 2.6 GHz s478Oddelek: Strojna oprema | 2541 (2118) | tiborrr |
| » | A se splača kupit na eBayu ker majo nore ceneOddelek: Kaj kupiti | 1655 (1558) | Phoebus |
