Brisanje WMP 11
Brisanje WMP 11
megabit ::
Pozdravljeni.
Mene pa zanima če kdo ve kako izbrisati Windows media player 11. V dodaj/odstrani programe ga ni, v mapi kjer je inštaliran, pa nima uninstall-a.
Hvala.
Lime ::
dodaj/odstrani programe -> dodaj/odstrani komponente programa windows
megabit ::
noup... unicila so se mi skoraj vsa ozadja, vendar je WMP se na disku... a to ko enkrat posnames moras kar imet?
Lery ::
Probi system restore.
megabit ::
jest bi rad samo to nesnago pocistil iz diska...
Microsoft ::
Ja uporabi System Restore, ane! Sej te itak med instalacijo opozori, ce imas to disejblan. Pa se beta je, tko da res nevem, kaj ti tu ni jasno.
by Miha
StratOS ::
"D:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
torej witch /Uninstall v MS-DOS command promptu :)
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Internet problem .
4312165 (11140) Gregor3
Win MSN live 2010
Oddelek: Programska oprema
71476 (1338) Cold1
windows update
Oddelek: Operacijski sistemi
142240 (2151) bluefish
Windows bodo dobili črno skrinjico (strani: 1 2 )
749077 (7479) MrStein
Kako odstraniti program?
102457 (2310) Sims
