Forum » Programska oprema » Nero 7 Premium
Nero 7 Premium
jernejk90 ::
Imam naslednjo težavo z nerom:
18:37:03 #19 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
18:37:03 #20 Text 0 File Burncd.cpp, Line 4132
Cache writing successful.
18:37:03 #21 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
18:37:03 #22 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 2x (2.770 KB/s)
18:37:03 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:37:05 #24 SPTI -1093 File SCSIPassThrough.cpp, Line 323
G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1093)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 02
Buffer x04803a00: Len xc
0x00 0A 00 00 00 00 00 00 00 14 50 D0
18:37:05 #25 Text 0 File DVDPlusDualLayer.cpp, Line 639
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
18:37:05 #26 CDR -1093 File ThreadedTransferInterface.cpp, Line 1799
No seek complete
G: _NEC DVD_RW ND-4550A
18:37:05 #27 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1799
Could not perform start of Disc-at-once
18:37:05 #28 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 2x (2.770 KB/s)
Kaj je narobe? pečem dvd+dl video film.
Sense Code: 0x02
Sense Qual: 0x00
No seek complete
JOKER ::
.. ma deinštaliraj nero-ta. Sem imel isti problem z 7 Premium in 7 Home Edition pa sem vseskupaj dol vrgel in naložil Roxio 8 .
Gate pipa ! Nero mu ne segne do kolena. Mislim to je moje mnenje.
________________________________________________________
Ka te češ ....
Ka te češ ....
jernejk90 ::
Naložil sem roxio 8 kot si svetoval, vendar tudi ta ne zapeče dvoslojnega video dvd-ja. Kot kaže ni problem v nerotu ampak v nečem drugem. Ima kdo kakšen nasvet???
p'redvidevam, da so zanic mediji. keri so sploh?
jernejk90 ::
Medije imam Smartbuy Double Layer DVD+R 8,5gb. Glede na to da sem dal za enega 1600sit dvomim v kvaliteto pa če ravno je smartbuy... windows mi javi neko napako v kateri piše memory error al nekaj takšnega in pa neke cifre x neke cifre ( 00040235 x 0042502kjg) če to kaj pomaga...
no ja, mediji so krivi. definitivno.
jernejk90 ::
ja saj če pomislim.... enoslojne dvdje in cdje peče brez težav... ampak lahko nesem v trgovino in reklamiram sploh?
kriko1 ::
Poskusi z drugimi mediji, ker smartbuy so tudi pri meni na črni listi (80% mi jih je crknilo). Poskusi TDK, Verbatim.
kriko1 ::
Verbatim pack: 2890 sit (25 kom, 8x +R) - bing bang koper
TDK pack: 3290 sit (25 kom, 16x -R) - bing bang koper
Koliko si dal za smartbuye? Razlika v ceni je sigurno, samo če hočeš imet podatke, jebiga. Drugače če gledaš moraš smartbuye 1x na na določen čas prepeč na nove, ker stari bodo šli po gobe in sedaj izračunaj kaj se ti bolja splača (s tem da TDK in Verbatim niso večni, samo je doba trajanja daljša). Nekje na forumu od cdfreaks je bil članek o kvaliteti medijev in iz katerih tovarn prihajajo, bi bilo zanimivo pogledat, samo ne najdem več linka.
AndrejS ::
Upgrajdaj pekača. Imam NEC3500 in dokler nisem upgrajdal BIOSa ni pekel dvoslojnih DVDjev
| » | NEC ND-3540A problem...Oddelek: Pomoč in nasveti | 2784 (2075) | dean444 |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2195 (2004) | mtosev |
| » | Plextor writer 24/48/48 problem! (strani: 1 2 )Oddelek: Strojna oprema | 6229 (5738) | Hux |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2374 (2314) | boštjan |
| » | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 2162 (1916) | krho |
