Forum » Igre » Enemy territory
Enemy territory
esi ::
Z neta sem si snel igro enemy territory, po nasvetu pa tudi patch2. Ampak, ko hočem igrat ne morem, prikaže se mi okno et console in v njem vsebina, ki jo lahko vidite spodaj.
Glede na minimalne sistemske zahteve za igranje imam vse kot je treba, grafično imam geforce 2 mx400 64 mb.
Je mogoče problem zaradi driverjev, če kdo ve zakaj ne morem igrat prosim za kakršnokoli informacijo.
Hvala
Et 2. 60 win-x86 mar 10 2005
- fs_startup -
current search path:
c:\progra~1\wolfen~1\etmain\pak2. Pk3 (22 files)
c:\progra~1\wolfen~1\etmain\pak1. Pk3 (10 files)
c:\progra~1\wolfen~1\etmain\pak0. Pk3 (3725 files)
c:\progra~1\wolfen~1\etmain\mp_bin. Pk3 (6 files)
c:\progra~1\wolfen~1/etmain
3763 files in pk3 files
execing default. Cfg
couldn't exec language. Cfg
couldn't exec autoexec. Cfg
hunk_clear: reset the hunk ok
... Detecting cpu, found intel pentium iii
bypassing cd checks
- client initialization -
- initializing renderer ----
- client initialization complete -
- r_init -
initializing opengl subsystem
... Initializing qgl
... Calling loadlibrary( 'c:\windows\system32\opengl32. Dll' ): succeeded
... Setting mode 4: 800 600 fs
... Using desktop display depth of 32
... Calling cds: ok
... Registered window class
... Created window@0, 0 (800x600)
initializing opengl driver
... Getting dc: succeeded
... Glw_choosepfd( 32, 24, 0 )
... 35 pfds found
... Glw_choosepfd failed
... 35 pfds found
... Failed to find an appropriate pixelformat
... Restoring display settings
... Warning: could not set the given mode (4)
... Using colorsbits of 16
... Calling cds: ok
... Glw_choosepfd( 16, 16, 0 )
... 35 pfds found
... 35 pfds found
... Warning: could not set the given mode (3)
... Shutting down qgl
... Unloading opengl dll
... Assuming '3dfxvgl' is a standalone driver
... Warning: missing glide installation, assuming no 3dfx available
- cl_shutdown -
re_shutdown( 1 )
glw_startopengl() - could not load opengl subsystem
Hvala
- fs_startup -
bypassing cd checks
- r_init -
... Calling cds: ok
... 35 pfds found
... 35 pfds found
... Calling cds: ok
... 35 pfds found
... 35 pfds found
- cl_shutdown -
re_shutdown( 1 )
Živi VSAK dan kot, da bi bil tvoj ZADNJI!
- premaknil iz Pomoč in nasveti: Damjan Jagar ()
Vesoljc ::
1. tema o Etju ze obstaja, zato ni potrebe po novih temah z istim imenom.
2. ne mores verjet kaj VSE najde stric google
| » | Wolfenstein - Enemy Territory (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Igre | 105997 (23005) | Gregor459 |
| » | Problem z nvidioOddelek: Pomoč in nasveti | 1892 (1640) | lanicorec |
| » | Problem z zagonom iger RTCW in MOHAAOddelek: Igre | 3102 (2786) | Flay |
| » | Medal of Honor in merzno igranje?Oddelek: Igre | 1295 (1157) | mitopuzo |
| » | Wolfenstein in XP???! :o(Oddelek: Pomoč in nasveti | 1479 (1381) | zrebec |
