Navil Athlona 64 FX venice z gigabyte GA-K8NF-9
2
rkajtn ::
Lep pozdrav!uspelo mi je naviti ta cuden procesor z cudezno ploščo ki se sploh ne da naviti dokler ne poskusis cudnih trikov!Moj dosezek je naslednji!
CPU-Z Report
CPU-Z version 1.31.
CPU(s)
Number of CPUs 1
Name AMD Athlon 64 3000+
Code Name Venice
Specification AMD Athlon(tm) 64 Processor 3000+
Family / Model / Stepping F F 0
Extended Family / Model F 2F
Brand ID 4
Package Socket 939
Core Stepping DH-E3
Technology 90 nm
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
CPU Clock Speed 2162.2 MHz
Clock multiplier x 9.0
HTT Bus Frequency 240.2 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2162.2 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
Mainboard and chipset
Motherboard manufacturer Gigabyte Technology Co., Ltd.
Motherboard model GA-K8NF-9,
BIOS vendor Award Software International, Inc.
BIOS revision F10
BIOS release date 01/13/2006
Chipset nVidia nForce4 rev. A2
Southbridge nVidia nForce4 MCP rev. A2
Sensor chip ITE 8712
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 196.6 MHz
FSB:DRAM CPU/11
CAS# Latency 2.5 clocks
RAS# to CAS# 4 clocks
RAS# Precharge 4 clocks
Cycle Time (TRAS) 10 clocks
Bank Cycle Time (TRC) 14 clocks
DRAM Idle Timer 16 clocks
# of memory modules 2
Module 0 DDR-SDRAM PC3200 - 512 MBytes
Module 1 DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
robi
sid911 ::
aja pa nimaš FXa ampak athlona 64
no zdaj pa nam zaupaj svoje čudne trike, kako si uspel naviti
1. Asus P8P67 LE | i3 2100 | HD 3850 | 2x4GB | 320 GB + 2 TB
2. FSC Amilo PRO V3515 ( T2060;2 GB;80GB)
Gatsu ::
No ja ni ti ravno velik uspelo navit ker imam sam popolnoma isto plato pa CPU in mi dela stabilno na 9x300 HTT 2.5, 2.9V na ramih, 1.65V CPU in +0,2V na HTT. Sem pa imel s to plato obupne težave zaradi prešvoh napajalnika - chieftec 360W ni dopuščal niti 9x215. Sicer sem mislil menjat plato - to sem uzel ker niso imeli na zalogi DFI NF4- ULTRA D, vendar sedaj po uspešnem navitju za 50% ne vem če se mi sploh splača dat dodatnih 10k za tisto plato.
AMD 64 3000+ Venice @2700
Gigabyte GA-K8NF-9
Corsair TWINX C2 1GB (2x512MB)
Club3D 7800GT @ 455/1180
LC 550W
rkajtn ::
Gatsu jaz imam napajalnik 650 q-tech!zdaj pa mi prosim z print screenom v biosu poslikaj pa mi poslji nastavitve kak mas kaj nastavljeno!jaz imam bios F11 gor!Prosim ce ti ni pretezko da ti sprobam ce mi doseze tak kot imas ti ker imam iste stvari!!Pa nastavitve ramov se prosim napisi!!
robi
  • spremenil: rkajtn ()
IVo ::
Gatsu kaj maš za en bios?
GaS ::
Ce imas ta novega oz. novejsega Venica, ga itak ne bos spravil na 2700..Pa tudi ce imata povsem enake komponente, ne pricakuj tega.
sid911 ::
moj noče čez 2600 it:'( ...mogoče ko si nabavim boljše hlajenje se malo pošpilam z voltažami, sam jebiga, slab seping sem dobil....imam pa F9 bios, a je F11 kaj boljši za navijanje?
rkajtn ::
No ja meni se je splacalo menjat bios oz nadgradit.Zdaj cakam da dobim novega zalmana 9500 led cena je 12k za cpu seveda,ker sedaj imam box varjanto in ce ga vredi navijem tak kot sem zgoraj opisal mi pride temperatura na dobrih 55c z burn in z programom sandra!Imam hladilnike na ramih samo nimam neke znane firme.baje da so dobri ne pa tak spet kot kaki corrsair pa tako naprej!!Nevem zakaj je gatsuji tezko nalepit slike njegovega biosa ce ima taki lepi dosezek,nevem zakaj noce deliti navijanja z drugimi.Jaz bi probal po njegovih nastavitvah tak da bi videl kje sem presvoh!
robi
Gatsu ::
Kdo je reku da nočem? Sam kolkr vem bi moral z digitalcem poslikat bios ker se v dosu pač ne da v clipboard kopirat al se pa motim.
rkajtn ::
Daj te pa poslikaj prosim pa daj gor ali pa na mail poslji!
Kajtna.robert@siol.net
S!lentHunter ::
Ti kar poslikaj bios pa prilepi slike na forum pa bo. Veliko nas je ki imamo težave z navijanjem GA-K8NF-9, zato na dan z besedo in sliko !
l.p.
AMD Ryzen 5 2600x,MSI 450 Tomahawk,Gigabyte RX580 8GB,16GB DDR4, SSD Samsung
Huawei
Gatsu ::
Ekola da vam ustrežem :P
slike biosa z nastavitvami ki delajo brez sesuvanja - prime95 res nisem laufal mi pa zato npr špil WOW dela tut po 8 ur brez problema ipd.
CPU-Z
3DMARK2006
  • zavaroval slike: kuglvinkl ()
S!lentHunter ::
Hvala za fotke, vendar nekdo, ki je pokazal nastavitve še enkrat hvala !
Huawei
Gatsu ::
Aja verzija Biosa je F11.
Škoda je samo to da sistem ni stabilen ako znižam delilnik rama da bi le ti delovali na 450 namesto 392 mhz. Škoda da funtech še ni imel takrat TCCD in BH5 ramov po tej ceni kot jih ima, ker bi se dalo z njimi najbrž boljše razmerje med FSB in hitrostjo ramov dobit.
rkajtn ::
Najlepsa ti dala gatsu!!res se ti zahvaljujem za fotke!zdaj pa bom probal ce bo to pri meni zdrzalo bios imam enak!!
rkajtn ::
Zal mi z temi gatsujemi bios nastavitvami ne pride niti v windowse!Na zacetku zgleda vse lepo in prav potem pa se samo resetira tik preden gre v windowse!Zgleda da me izdajajo rami ceprav imam gori coolerje!!
robi
ta_pravi ::
pozdravljeni!
imam: AMD Athlon 3000+ @2400 939, GA K8NS 939
z original hladilnikom box....mi procesor lepo drži temperatuto na obremenitvi okoli 33 stopinj!
hvala za fotke!!!
ta_pravi
globoko grlo ::
ahm
mam tut GA-K8NF v1.xx
A64 3000+ big typhoon
pa geil 2x512 kit
in sem zadevo navil po zgornjih fotkah, sicer vse lepo dela, 3d05 pride čez, kkšno 1.5h F:E:A:R:a sem prešpilal, pa ene par ur BFME2ja in je temp narastla na 37, kar se mi ne zdi preveč
zdej, cpuz mi pokaže frekvenco 2700Mhz, a to dejansko pomen, da sm ga navil za 900Mhz? Se mi zdi full velik. Aja, a sm prow zračunal, da to potem pride 4500+?
Sem pa opazil eno težavo, namreč moja logitec mx700 je nehala delat (priklopljena je na zadnjih USBjih), se prav miška sama dela, v winsih pa ne jebe, tko da sm mogu eno dugo ožičeno miš priklopit na sprednji USB na ohišju, ta pa dela, a se komu sanja zakaj?
drgač sem pa supr zadovoljen
tnx
tiborrr ::
Probaj voltazo cipseta dvignit, morda bo pomagalo z USBji.
globoko grlo ::
a potem imam 4500+ ali ne
S!lentHunter ::
Če nastavim bios po zgornjih fotkah pridem le do 220 FSB-ja-če navijam v biosu, če pa vse nastavim isto po zgornjih fotkah le FSB pustim na 200, pa grem pol navijat s programom Easy tune 5 (programček, ki je priložen pri MB) pa se zadeva normalno navije na 300 FSB ter vse dela, PC je stabilen. V čem je tle pol problem (verzija biosa zadnja F11) ???????????????? ve kdo odgovor.
Huawei
GrimReaper ::
@globoko grlo:
S temle poglej pod QS-Rating.
galimim ::
Mam sicer GA-K8NF-9 Ultra je pa problem v latencah to niso sicer te nastavitve ampak tiste ki so obkrožene je treba dati na eno več
Born To Bleed, Fighting To Succeed, Built To Endure What This World Throws At Me
galimim ::
Biosi pravkar fleshani na verzijo f6 pa imam možnost hammer vid control pa me zanima kaj to je
GrimReaper ::
@galimim: Zakaj HT ratio na 2.5x?
Če daš 3x te pride komi 900MHz (1000MHz je stock HTT).
F6? Zadnja verzija je F11, vsaj za plato revizije 1.x.
Za 2.x pa kolker sem tukaj gledal tud ni nobenga F6.
Hammer Vid Control je pa za voltažo CPU-ja.
Aja, zdaj sem opazil da vas veliko navija po zgornjih fotkah, ne vem zakaj je dal on HT na 2.5.
Sicer morš pa tudi zakasnitve rama in potrebno voltažo sam ugotoviti, ne morš neki po slikah navijat.
galimim ::
f6 ker mam GA-K8NF-9 Ultra ht pa zarad bootanja ker se men ns bios verziji f5 ni hotu bootat če nism dau ht ja na 1x zdej je na 2x pa bom probu še gor it
GrimReaper ::
Če daš na 3x ne bo problemov.
HTT mora bit čim bližje 1000MHz.
OldSkul ::
A ma še kdo probleme, da ko mam navit procesor, da mi ko rebootam NOČE zaznat sata diska. Mora izklopit rač., pol pa dela. WTF!?!? Rač. je drugač stabilen 100%.
Sem bral, da imajo eni tud iste probleme, ampak nekako tiste rešitve ne pomagajo.
TEDY ::
Men enako naredi, ko imam navit proc pa imam K8NF-9.
Navil sem ga na 260FSB po zgornjih nastavitvah, samo voltaža je malo manjša.
Po nekaj časa se mi je ponovno zagnal, zato sem znižal FSB na 255, in zaenkrat deluje vredu.
V SuperPI sem dobil 38sec.
GrimReaper ::
Ta plata je res čudna kar se bootanja tiče.
Malo mojih izkušenj:
Na 289FSB, 1.550V se kar dvakrat boota (v prvo ne zazna diskov), na 1.475V pa normalno boota.
Zdaj na 300FSB in 1.65V pa kot kaže ni problemov.
erda ::
katero vrednost morem povečat da bi rami delali na več MHZ ker mi na default delajo 400mhz zdaj mam pa nastavleno na 386mhz. Delal pa sem po galimimovih nastavitvah ki jih je prilepil
galimim ::
CPU/DDR Clock ratio
erda ::
do kolko približno bi šli Geil rami ? (tisti ta plavi)
galimim ::
Odvisn od latenc eni vem da grejo 420 ampak sprobavi pa boš vidu ker moji CEON rami gredo do 400 in nč naprej
erda ::
ewo trenutno so na 498 in dela stabilno
GrimReaper ::
Pa še kaj, potem pa to niso navadni Geil Value rami.
Aja, na 249MHz so in ne 498. Take hitrosti bodo meli DDR3 rami.
erda ::
ja skupaj mata 498 2x512... lahko screen shot nardim prlimam, poslikam rame kaj hočeš če ne verjameš :\
super PI mod pa se je ustavil pri 35.127 sek
GrimReaper ::
Ja pa ne boš rekel da maš to Geil rame za 24k?
erda ::
ja :D
p.s 3dmark 06 pa je naštel 1700 pik
  • spremenil: erda ()
galimim ::
GrimReaper ne se razburjat sej mam tut jst CEON rame pa se noben ne p**** zarad tega sam hudič je ker je treba pazit da ne gredo čez 200Mhz
GrimReaper ::
@BigBoy: Dobr letijo, sam pa sploh še nisem probal do kolk grejo :8) . Ko bo čas.
@galimim: Tebe pa ne razumem, zakaj bi se razburjal nad tvojimi rami ko pa ne grejo niti čez 200MHz :)) .
erda ::
@GrimReaper bom ju3 probal povišat še za malo in poročam, danes čez noč ga pustim da vidim če je stabilen (prav tako je bilo opravljenih ducat testov in za zdaj še ni bilo težav) 0:)
galimim ::
My bad sm mislu da boš meu kej za prpomnt uzvezi z rami:8) :8)
S!lentHunter ::
No tudi meni je končno uspelo naviti procesor AMD 3000 na čudni MB Gigabyte GA-K8NF-9 vendar nisem preveč pretiraval FSB 270, rami pa delujejo na 203 MHz kar je 406 MHz zadeva je stabilna. Kljub temu, da imam isto MB in procesor, so moje nastavitvu v Biosu popolnoma drugačne HT frequency ratio sem moral dati na 2x, ker če ga dam samo na 2.5x se zadeva noče navijati, rami pa delujejo na 2/1.5. Torej iz tega sledi, da se vsaka komponenta pa tudi če je identična z drugo navija drugače.
Huawei
erda ::
@Gatsu Kolikšnje so tvoje temperature v mirovanju in na full in kakšen hladilnik uporabljaš
za vse ki imate isti procesor in plato o kateri gre tema prosim če tudi napišete kr se mi zdi nekam čudno da mam na idle 35 stopinj ko pa špilam pa gre tudi čez 50 mam pa thermaltake tower 112 in gor 2 venta
Veron ::
BigBoy tole tvoj superpi je slab
glej moje:
erda ::
ja daj ga na 300x9 pa bomo potlej vidli realno razliko
GrimReaper ::
Še moj, še moj :D :
Ti Veron maš vredu za tvojo frekvenco.
@BigBoy:
Na bratovem 2700MHz pride 34s, tak da maš ti res mal mal.
erda ::
kakšne so temperature ??
Lord.Febo ::
kva je zdej to, a vi temu pravte navijanje? dejmo se nehat hecat fantje.
2
AMD 64 3200+ vs AMD 64 X2 4200+ (strani: 1 2 )
625675 (5325) mesoreznica
težave pri navijanju amd athlon 64 3000+
Oddelek: Navijanje
462637 (1900) crazy-lemon
Navijanje AMD + Gigabyte
Oddelek: Navijanje
292452 (1816) dejansan
Navijanje AMD 64 3000+???
Oddelek: Navijanje
462144 (1520) tiborrr
athlon 64 maksimum
Oddelek: Navijanje
111837 (1372) CoolBits
