VW Passat ter originalen avtoradio BETA
Jst ::
Včerej mi je zatajil akumulator, tako, da mi avto ni vžgal. In medtem se mi je zaklenil avtoradio (original od VW, gor piše samo BETA). Ko vžgem avtoradio mi na displayu piše "SAFE".
Kako ga spraviti k življenju?
Passat je letnik 1996. Vsa navodila sem dobil v slovenščini *razen* navodil za avtoradio, ki so v Nemščini.
Kje bi dobil navodila v angleščini?
  • spremenil: Jst ()
sirotka ::
hm...probaj tole:
turn radio off press and hold both up and down tunning keys, turn your radio back on and 1000 will appear. Then you can put your code in. press the 1 key to make it a 3 digit code. You have the option of zero with a 3 num code but only the num 1 as your first num for a 4 digit code. I don't know what you press after to enter the code. 1-2-3-4 will change each num in order. I spent 2 hours trying every posible code but to no avail. Someone said hold the down arrow facing the pasanger side and you should hear three beeps. Good luck.
To je pa direktno it priročnika...sicer za golf, vendar pmoje isti postopek:
From the "Operating Instructions: Sound System Deluxe" that came with my '94 Golf.
* Turn on radio -- the word "SAFE" will be displayed.
* First press the MODE button and then press the SCAN button and hold them down simultaneously until "1000" appears in the frequency display. Release the buttons. Do not, under any circumstance, continue holding the buttons down or press them once again. This would cause the radio to take the number "1000" as the code number.
* Using the first four radio station buttons, enter the code number found on your Radio Card. Use button 1 to set the first digit of the four digit code, button 2 to set the second digit, etc. The first digit of a four digit code must be "1". If your code number has three digits, the first digit on display must be set blank.
* Once the code is shown on the display, press and hold the MODE button and SCAN button simultaneously until the word "SAFE" appears in the frequency display. Release the buttons. A radio station frequency will automatically be displayed. The radio will now play once again.
If, when cancelling the electronic lock-up, a wrong code number is entered by mistake, the word "SAFE" will appear in the frequency display first blinking, and then continuous.
You can now repeat the entire cancelling procedure but only once. The number of attempts will be shown in display.
If the wrong code number should be entered again, your radio will be locked up for approximately one hour. The radio will not play. Leave the radio switched on. After an hour, you can cancel the electronic lock-up as previously described.
Če pa tud to ne bo šlo, pa vprašaj tu na tej strani...http://forum.ecoustics.com/bbs/messages...
Vikking ::
V navodilih imaš 4 mestno številko ki jo vneseš v avtoradio.
za vnos 4 mestne številke (zej lahka da maš drug model, se lahko postopek razlikuje): drži gumba MODE in SCAN dokler se napis SAFE ne spremeni v 1000. Spusti gumba in z prvimi 4 gumbi za radijske postaje vnesi številke.
1 gumbom spreminjaš številko na prvem mestu... z 2 gumbo spreminjaš 2 številko.... do 4 številke. Ko nastaviš vse 4 številke, pritisni hkrati gumba SCAN in MODE dokler koda ne izgine.
4 mestno kodo dobiš v originalnih navodilih, lahko je na kakšni nalepki, ki je prišla zraven navodil. V glavnem nekje je napisana. Če je nimaš lahko prideš do kode samo preko serijske številke, ki je napisana na zadnjem delu avtoradia.
Če 3krat fališ kodo, se radio zaklene, če se ti to zgodi, ga odklopi iz štroma za par dni, pa potem ponovno priklopi, pa boš imel verjetno spet na voljo da 3krat vneseš kodo.
upam da ti bo kej pomagalo. lp
Jst ::
Mmm.. ja kodo imam. Samo mi ni bilo jasno kako vnesem 0, ker imam samo tipke s številkami 1,2,3,4,5,6.
Hvala vam za informacije, bom probal, ter poročal.
Hvala!
sirotka ::
gre tako, da 1x ptitisneš je 0, če 2x je 1 in tako naprej:)
Jst ::
Poznen reply, ampak vseeno:
Vžgeš avtoradio. Skupaj držiš tipki TP in TA. Izgine napis SAFE ter tako lahko vpišeš kodo. Spet držiš tipki TP in TA.
Jst ::
+ Imam vsa navodila za avto v slovenščini razen navodil za avtoradio, ki so v nemščini. A kdo ve, če bi se jih dalo dobiti v ang v kakšni pdf obliki ali kaj razumljivega? Avto je pa letnik 1997, na avtoradiju pa piše samo BETA.
paypal zavraca kartico, kaj storiti?
182205 (1898) Djz3l3
Išče se koda za univerzalnega daljinca
Oddelek: Zvok in slika
1312882 (9721) zani
Onkyo TX-SR508 standby
255185 (4713) jerry2000
GTA3 Dodo
Oddelek: Igre
123582 (3109) burekar
problemi pri divxih
Oddelek: Sedem umetnosti
81758 (1589) fictionel
