Forum » Omrežja in internet » Calls from analog phone to CCM
bad2Dbone ::
Hi, everyone!
I have problem:
I am using CISCO 1760 router for gateway with 2x vic 2nt/te and CCM 4.1 server for IP telephony, working together over MGCProtocol and connected to 3 BRA lines with 20 avalible public phone numbers. I can make and except all cals, except those from analog phones. Debugging Q.931 on router shows, that the last digit of called number is missing. That happend almost every time, when call from analog line appers froum network side.
I have set Allow overlap receiving flag for PRI set on true, I have changed values of T302 and T304 timers, added alow overlap-receiving line on gateway...
Did anyone had solved that kind of problem or has any ideas, documents... about that?
Plese help me, i am getting a bit frustrated...
Thanks in advance.
Ne da se mi prevajat, pa itaq kdor ne razume ne more pomagat...
I have problem:
Thanks in advance.
carpe diem ;)
- premaknil iz Pomoč in nasveti: ToniT ()
enough98 ::
Zdravo,
v CCM preveri nastavitve pod Device -> Gateway -> .. Endpoints -> Significant Digits
bad2Dbone ::
To imam na all. Namenjeno za rezanje številk tako, da pusti samo željeno število zadnjih cifer, ki so ponavadi enake internim.
Najlepša hvala za trud, se zelo priporočam in bom preveril vsako idejo.
carpe diem ;)
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20348 (17188) | arrigo |
| » | Geslo za Ganymede 822+ iz VoljeOddelek: Omrežja in internet | 7263 (4876) | Tilen |
| » | Gmail posodobitev sistemaOddelek: Pomoč in nasveti | 2646 (2450) | Goldee |
| » | connecting own dialling router to siol adslOddelek: Omrežja in internet | 2767 (2663) | enis |
| » | Iptables in C&C GeneralsOddelek: Igre | 2518 (2287) | Tito |
