Mandriva 2006 - adsl
markosus ::
Zdravo.
Zanima me kako zaboga se nastavi adsl povezava v mandrivi 2006?Mrežno kartico sis prepozna,potem pa ko izberem adsl opcijo,ppp over ethernet vstavim še ostale podatke in na koncu ko izberem naj me takoj poveže pa izpiše da sploh nimam povezav v internet.Ta povezava v win xp deluje brezhibni.Se komu kaj sanja o tem?
Lp.
mirkuma ::
Identicen problem s sicer pravilno prepoznanim on-board VIA enthernet adapterjem...
Tudi sam prosim za nasvet kako ustimat zadevo...
...all those moments will be lost in time, like tears in the rain...
mirkuma ::
Ce bo se slucajno koda matralo, meni je uspelo, tako da sem najprej v nadzornem srediscu odstranil vse mrezne adapterje, restartal X streznik, na novo naredil samo ADSL povezavo, se odjavil in ponovno restartal X streznik in stvar je zacela delovat...
QUOTE:
you have to remove all network protocol you configured before, close session and rerun x server.
Then:
Menu -> System -> Configuration -> Configure your computer
Network and internet section, launch "configure new network interface"
Step 1: ADSL connection
step 2: normally it shows the ethernet interface, selected.
step 3: select your provider from the list; if not present, select "Not in list"
step 4: select PPP over ethernet (pppoe)
step 5: insert DNS servers of your provider (if you don't know them, I think they will be configured automatically when you connect first time, because a week ago when my provider changed them, I found them already changed in my configuration), user and password. Click on "advanced" and compile VPI and VCI as specified on your modem configuration; in my case, they are 8 and 23.
other steps: ask as you prefer.
Then you have to close session and restart x server.
In my case, i preferred not to start pppoe connection at startup.
I have netapplet (menu -> system -> monitor -> netapplet: then you choose to start netapplet at startup) on status bar, and i connect when I need.
BladE_ ::
Kako pa resetiras X streznik?
Akcija - Reakcija
PARTyZAN ::
drola ::
Zapreš vse programe in hkrati pritisneš Ctrl+Alt+Backspace
https://drola.si
Print - ethernet kabel
143948 (3743) SasoS
Asus WL500gP, dd-wrt, printer and disk sharing
Oddelek: Omrežja in internet
97326 (3730) coyotee
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820331 (17171) arrigo
A kdo ve kako v Linuxu skonfigurirat zunanjo mrežo
Oddelek: Operacijski sistemi
162002 (1801) Yohan del Sud
Časovna omejitev dostopa
Oddelek: Programska oprema
111758 (1590) francek1
