Problem z mp3jem philipsom SA260!
Doman ::
Kupil sem že omenjeni mp3 predvajalnik in imam majhen oz. velik problem z njim.
Ko ga vklopim preko USB-a mi zazna kot 2 napravi(v mojem računalniku mi odpre I: & K: particije) Eno sploh ne morem odpreti in mi napiše: "Invalid path", drugo pa lahko odprem in imam notri 3 mape-mic&fw&recording.Če dodam komade samo v e: mi komade prekopira, mp3 pa jih ne zazna, pravtako tudi če dam komade v katerokoli mapo. Kaj je narobe? Naj ga vrnem?
P.S: Kolega trdi da se to lahko naredi samo z Windows Media Player meni pa se to zdi rahlo smešno:D -tko tudi v navodilih piše. Ampak z tem so tud težave.
Stepni Volk ::
Zaupaj navodilom in prijateljem:
Philips SA260 - FAQ
Question
How do I transfer music to my GoGear player from computer?
Answer
TIP: The order in which your device will play tracks is according to the file names of the tracks in alphabetical order
Transfer music with Windows Media Player 9.0
1. Hook up your GoGear with the PC via the supplied USB cable. Make sure your GoGear is inserted with a battery with sufficient voltage level. Launch the Windows Media Player 9.0 installed in your computer.
IMPORTANT: Please make sure that your GoGear is connected to the computer before launching of Windows Media Player or else the device will not be recognized by Windows Media Player.
2. Click Copy to CD or Device or on the File menu, point to Copy, and then click Copy to Portable Device.
3. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the Items on Device pane, in the drop-down list, click to select Philips or Philips SD to copy files to the device or SD card
6. Click the Copy button.
7. Windows Media Player using the Philips Plug in to verify if there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
8. Repeat steps 2-5 for any other items that you want to copy to your portable device.
9. The Items on Device pane typically refreshes automatically when you connect a device to your computer, when you disconnect a device from your computer, or when you insert or remove storage media from a connected device. If the display does not refresh automatically, you can press F5 to refresh the display manually.
10. Once the transfer is completed, close the Windows Media Player
11. Click on the removal icon on the task tray to stop and eject the jukebox. When a message appears saying the USB device can now be safely removed from the system, click OK.
12. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music with Windows Media Player 10.0
1. Hook up your GoGear with the PC via the supplied USB cable. Make sure your GoGear is connected to a battery with sufficient voltage level. Launch the version of Windows Media Player 10.0 installed in your computer.
2. Click Sync or on the File menu, point to CDs and Devices, and then click Synchronize….
4. Click the check boxes next to any files you want to copy.
5. In the Items on Device pane, in the drop-down list, click to select Philips or Philips SD to copy files to.Click the Start Sync button.
6. Windows Media Player using the Philips Plug in to verify that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
7. Repeat steps 2-5 for any other items that you want to copy to your portable device.
8. The Items on Device pane typically refreshes automatically when you connect a device to your computer, when you disconnect a device from your computer, or when you insert or remove storage media from a connected device. If the display does not refresh automatically, you can press F5 to refresh the display manually.
9. Once the transfer is completed, close the Windows Media Player
10. Click on the removal icon on the task tray to stop and eject the jukebox. When a message appears saying the USB device can now be safely removed from the system, click OK.
11. Unplug the GoGear from the PC and enjoy the music on your GoGear.
i: pametni telefoni z audiofilskim zvokom
449386 (7798) Alen T 1978
mp3 predvajalnik z najboljsim zvokom.
243727 (3203) awy
Mp3 predvajalnik - popravilo
Oddelek: Zvok in slika
71444 (1305) zavajon
Ne predvaja novega audio CD
52618 (2574) Tea Time
Ne da se zbrisat filma
121826 (1613) andper
