ATI Radeon 9200 TV out pod Ubuntujem
poweroff ::
Imam ATI grafikuljo pod Ubuntujem (x.org), pa ne vem kako bi vklopil TV out. Sicer vse dela kot je treba, edino to ne deluje. Fireglcontrol je neuporaben - nastavitev ne zapiše NIKAMOR.
Tole ja pa moj xorg.conf:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands:
#   cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
#   sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum'
#   sudo dpkg-reconfigure xserver-xorg
Section "Files"
 FontPath "unix/:7100"   # local font server
 # if the local font server has problems, we can fall back on these
 FontPath "/usr/lib/X11/fonts/misc"
 FontPath "/usr/lib/X11/fonts/cyrillic"
 FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/Type1"
 FontPath "/usr/lib/X11/fonts/CID"
 FontPath "/usr/lib/X11/fonts/100dpi"
 FontPath "/usr/lib/X11/fonts/75dpi"
        # paths to defoma fonts
 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
 Load "bitmap"
 Load "dbe"
 Load "ddc"
 Load "dri"
 Load "extmod"
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "record"
 Load "type1"
 Load "vbe"
 Load "GLcore"
 Load "glx"
 Load "dri"
 Load "extmod"
 SubSection "extmod"
  option "omit xfreee86-dga"
 EndSubSection
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
 Option  "XkbRules" "xorg"
 Option  "XkbModel" "pc104"
 Option  "XkbLayout" "us"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/input/mice"
 Option  "Protocol"  "ImPS/2"
 Option  "Emulate3Buttons" "true"
 Option  "ZAxisMapping"  "4 5"
EndSection
Section "Device"
 Identifier "ATI Technologies, Inc. Radeon 9200 Pro (RV280)"
 Driver  "fglrx"
 BusID  "PCI:1:0:0"
 Option  "VideoOverlay" "on"
 Option  "OpenGLOverlay" "off"
 Option  "UseInternalAGPGART" "no"
EndSection
Section "Monitor"
 Identifier "L1715S"
 HorizSync 30-65
 VertRefresh 40-80
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier "Default Screen"
 Device  "ATI Technologies, Inc. Radeon 9200 Pro (RV280)"
 Monitor  "L1715S"
 DefaultDepth 24
 SubSection "Display"
  Depth  1
  Modes  "1280x1024" "1024x768" "800x600" "720x400" "640x480"
 EndSubSection
  Depth  4
 EndSubSection
  Depth  8
 EndSubSection
  Depth  15
 EndSubSection
  Depth  16
 EndSubSection
  Depth  24
 EndSubSection
EndSection
Section "Screen"
 Identifier "CATV network"
 Monitor  "L1715S"
 DefaultDepth 24
  Depth  1
  Modes  "800x600" "640x480"
 EndSubSection
  Depth  4
 EndSubSection
  Depth  8
EndSubSection
  Depth  15
EndSubSection
  Depth  16
EndSubSection
  Depth  24
EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 Screen  0 "Default Screen" 0 0
 Screen  1 "CATV network" Above "Default Screen"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
EndSection
Section "Extensions"
 Option  "Composite" "on"
EndSection
Section "DRI"
 Mode 0666
EndSection
sudo poweroff
Težave z resolucijo na Linux sistemu
Oddelek: Operacijski sistemi
162009 (1791) INVICTRA
radeon 9200 suse10 brightness problem
252386 (2202) roli
Ubuntu - par vprašanj
252828 (2246) 64202
suse 9.1 in radeon 9800PRO
112219 (2091) jurre
Suse 8.2 težave z grafično...
92256 (2144) norvalk
