Kako odstraniti Win XP iz particije D
Romancek1 ::
Pozdrav,
zanima me, kako bi odstranil Windowse XP iz particije D. Nove sem inštaliral na particijo c, kjer so billi prej nameščeni Win 98. Sedaj imam na začetku zopet tisti meni za izbor, katere Windowse naj zaženem ( v trenutnem primeru je na izboru v obeh primerih Win XP). Ta meni bi se torej rad znebil, particijo d pa kasneje, ko prenesem vse podatke, formatiral. Gotovo bo po formatiranju particije D še vedno izbirni meni na začetku...
Romancek1 ::
A res nihče ne ve pomagat?
Mogoče ti to kaj pomaga;)
Google search - unistall xp
grain ::
To specify the default operating system for startup
Open System in Control Panel.
On the Advanced tab, under Startup and Recovery, click Settings.
Under System startup, in the Default operating system list, click the operating system you want to start when you turn on or restart your computer.
Select the Display list of operating systems for check box, and then type the number of seconds you want the list displayed before the default operating system starts automatically.
bobby ::
boot win98
ukaz fdisk /mbr
v c:\ pa poišč boot.ini pa zbriš vrstico ki se nanaša na winxp
to je vse
dissector ::
bootloader editiras, tako nekako kot sta predhodnika napisala:>
There it was. The final destiny. A sunrise that never came, still the night lamp that never faded away. Farewell was the word, and the afterglow was the brave morning. Rising and telling everyone about the beauty of its PROLOGUE.
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485575 (4123) Gray_Warden_
XP gonilniki za macbook
171465 (561) CoolBits
Gentoo install (strani: 1 2 )
526393 (5813) HerrBaron
Iščem alternativo vuduju
122420 (2184) Arthur
Norton Antivirus 2001 pod win XP ne dela??
61575 (1526) Nigga
