T-2: Informacije
T-2: Informacije
berta ::
preko maila ful težko dobiš odgovor. Najlažji način za dobit odgovor je po mojih izkušnjah, da jim pošlješ faks. 8-O
Irmscher ::
Nimam faksa.
Palijo na navadno pošto? :))
BendeR ::
Do zdaj sem na vse maile dobil odgovor v roku nekaj ur. Tak da ...
alexius ::
Helpdesk pokliščeš, pa rečeš naj ti profil spremenijo. Jst sm mu 24ms pinga zato je blo kar treba poklicat.
Ja, in kater profil naj jim rečem, da nastavijo?
Jaz mam tud prevelike pinge IMO.
T-2 ping
Pinging www.t-2.net [84.255.209.69] with 32 bytes of data:
Reply from 84.255.209.69: bytes=32 time=45ms TTL=125
Reply from 84.255.209.69: bytes=32 time=21ms TTL=125
Reply from 84.255.209.69: bytes=32 time=22ms TTL=125
Ping statistics for 84.255.209.69:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 21ms, Maximum = 45ms, Average = 27ms
ARNES ping
Pinging kanin.arnes.si [193.2.1.87] with 32 bytes of data:
Reply from 193.2.1.87: bytes=32 time=23ms TTL=250
Reply from 193.2.1.87: bytes=32 time=22ms TTL=250
Ping statistics for 193.2.1.87:
Minimum = 22ms, Maximum = 23ms, Average = 22ms
Pa še tujina...
Pinging telekom.cms-asp.t-online.de [80.150.6.178] with 32 bytes of data:
Reply from 80.150.6.178: bytes=32 time=58ms TTL=244
Reply from 80.150.6.178: bytes=32 time=59ms TTL=244
Ping statistics for 80.150.6.178:
Minimum = 58ms, Maximum = 59ms, Average = 58ms
Se mi zdi kar preveč.
Not only is life a bitch, it has puppies.
OldSkul ::
Nč, on samo zabeleži tehnikom in ti že oni nastavjo na optimaln profil.
Malkec ::
Ah lol, na amisu je ping do tega .de ipja 31ms >:D
PING 80.150.6.178 (80.150.6.178) 56(84) bytes of data.
64 bytes from 80.150.6.178: icmp_seq=1 ttl=244 time=31.0 ms
64 bytes from 80.150.6.178: icmp_seq=2 ttl=244 time=29.7 ms
64 bytes from 80.150.6.178: icmp_seq=3 ttl=244 time=31.7 ms
/* Xaser 3 * 939 dual sata 2 * Opti165 (ccb1e0608mpmw) @2933 MHZ*/
/*TT 120 * X800 XL *1GB Transcend pc 3200 * MAxtor 160 GB SATA II /
Fury ::
ADSL (SIOL):
Reply from 80.150.6.178: bytes=32 time=50ms TTL=246
Reply from 80.150.6.178: bytes=32 time=52ms TTL=246
Reply from 80.150.6.178: bytes=32 time=49ms TTL=246
SasoS ::
pri meni je 48 na T-2.
bdx ::
amis-cable FTW! Skoda, ker ga nimamo na gorenjskem. :\
progamer
  • spremenil: bdx ()
Malkec ::
Jap, amis in triera cable imata killer pinge. K temu pa znatno pripomore dejstvo, da imata tudi dober routing po evropi. T-2 pa zgleda nekaj ovinkari preko švedske 8-O
SasoS ::
Nič več...zgleda so porihtal 8-)
1 84.255.208.255 (84.255.208.255) 12.526 ms 12.009 ms 12.310 ms
2 84.255.208.129 (84.255.208.129) 11.831 ms 11.782 ms 27.360 ms
3 kklag1-176-69.net.uta.at (212.152.176.69) 14.314 ms 14.386 ms 14.045 ms
4 C76vix2-tengigE-3-2.net.uta.at (212.152.192.173) 22.867 ms 23.028 ms 22.556 ms
5 C76vix2-tengigE-3-2.net.uta.at (212.152.192.173) 22.642 ms 22.618 ms 22.816 ms
6 tele2-TGigE-vie.net.uta.at (212.152.189.66) 23.180 ms 23.292 ms 22.570 ms
7 zur1-core.pos2-0.swip.net (130.244.205.45) 36.183 ms 36.476 ms 36.533 ms
8 tix-gw20.ch.net.dtag.de (194.42.48.56) 36.681 ms 36.706 ms 36.564 ms
9 194.25.10.94 (194.25.10.94) 48.182 ms 48.657 ms 48.054 ms
10 217.6.25.154 (217.6.25.154) 48.701 ms 48.624 ms 48.542 ms
11 80.150.6.178 (80.150.6.178) 48.880 ms 48.680 ms 48.093 ms
Malkec ::
Tracing route to 80.150.6.178 over a maximum of 30 hops
1 1 ms 1 ms 1 ms 192.168.0.1
2 5 ms 57 ms 5 ms 10.71.0.1
3 9 ms 7 ms 7 ms maribor2-ge-0-0-0-1.amis.net [212.18.32.99]
4 162 ms 10 ms 12 ms 80.120.176.181
5 11 ms 10 ms 12 ms 195.3.70.69
6 12 ms 12 ms 14 ms 195.3.70.106
7 12 ms 12 ms 11 ms VIX-gw1.AT.net.DTAG.de [193.203.0.40]
8 44 ms 30 ms 32 ms 194.25.10.94
9 30 ms 41 ms 35 ms 217.6.25.154
10 29 ms 32 ms 31 ms 80.150.6.178
Trace complete.
Skače med 29 in 31 :D
Zgleda da uta nekaj laga preko t-2. Glej do VIX-gw1.AT imam jaz 11 ms, Sasos pa do tix-gw20.ch (ch = ŠVICA??? ) 36ms, potem pa kr 48 do 9. hopa. Torej še vseeno routing bluzi do švice in nazaj v nemčijo :D
Irmscher ::
waaaaaaaaa, kdo mi je popravil ping? :D
PING www.t-2.net (84.255.209.69): 56 data bytes
64 bytes from 84.255.209.69: icmp_seq=0 ttl=125 time=7.320 ms
64 bytes from 84.255.209.69: icmp_seq=1 ttl=125 time=7.258 ms
64 bytes from 84.255.209.69: icmp_seq=2 ttl=125 time=7.368 ms
64 bytes from 84.255.209.69: icmp_seq=3 ttl=125 time=7.457 ms
64 bytes from 84.255.209.69: icmp_seq=4 ttl=125 time=7.771 ms
^X64 bytes from 84.255.209.69: icmp_seq=5 ttl=125 time=7.583 ms
PING kanin.arnes.si (193.2.1.87): 56 data bytes
64 bytes from 193.2.1.87: icmp_seq=0 ttl=250 time=7.981 ms
64 bytes from 193.2.1.87: icmp_seq=1 ttl=250 time=7.841 ms
64 bytes from 193.2.1.87: icmp_seq=2 ttl=250 time=8.532 ms
64 bytes from 193.2.1.87: icmp_seq=3 ttl=250 time=8.033 ms
DSLAM:
PING 84.255.208.255 (84.255.208.255): 56 data bytes
64 bytes from 84.255.208.255: icmp_seq=1 ttl=127 time=7.741 ms
64 bytes from 84.255.208.255: icmp_seq=2 ttl=127 time=7.797 ms
64 bytes from 84.255.208.255: icmp_seq=3 ttl=127 time=7.688 ms
64 bytes from 84.255.208.255: icmp_seq=4 ttl=127 time=7.994 ms
64 bytes from 84.255.208.255: icmp_seq=5 ttl=127 time=8.095 ms
64 bytes from 84.255.208.255: icmp_seq=6 ttl=127 time=7.642 ms
64 bytes from 84.255.208.255: icmp_seq=7 ttl=127 time=7.517 ms
64 bytes from 84.255.208.255: icmp_seq=8 ttl=127 time=7.593 ms
Sharkec ::
Na APEK-u pravijo, da naj bi telekom razvil napravo, katera omogoča nadgraditev telefonskega priključka z ADSL tudi če je priključek vezan na PCM napravo. Tako da je preko te naprave ADSL možen VDSL pa ne. Ali ve kdo kaj več o tem? O tem naj bi pisalo tudi v časopisu, so mi zagotovili na APEK-u. Če to drži, potem se bo še težje prišlo do T2 storitev.
NavadniNimda ::
SHARKEC - dobra fora!:O
Tele naši Telekomarji so pa še hujši kot renesančni umetniki - če kaj prepoveduje znana fizika, potem si je treba kej druzga izmislit, LOL!:D :D :D
antonija ::
Zdej ce se te "napravi" rece "bakrena parica" potem s priklopom na T2 nebi smelo bit tezav...>:D
Sharkec ::
NavadniNimda, tako pravijo na APEK-u. Seveda več o tem ne vejo, pravijo le da se moram sam pozanimat pri telekomu kako je s tem. Vse skupaj mi je dokaj smešno, me pa zanima kaj je konkretno pisalo v časopisnem članku na katerega so se naslanjali na APEK-u. Še vedno čakam odgovor na drugo poizvedbo, katera naj bi bila šele danes poslana s strani T2 (v kolikor bodo fantje pohiteli) na Telekom. Ob enem pa se trudim pridobiti papirje, ki dokazujejo možnost priklopa ADSL.
letecko ::
Še moja zgodba, ki se še ni razpletla (in kot kaže se še dolgo ne bo)...
24.aprila pošljem podpisano pogodbo (za tv, net in telefon) na t-2
15.maj nam Siol izklopi uporabniško ime za adsl, na t-2 helpdesku tisti dan nič ne vejo o tem. Ko parkrat pokličem na Siol mi razložijo, da jim je Telekom poslal 15.maja papir, na katerem piše, da gremo k konkurenci in naj nam zato odklopijo adsl.
16.maja pokličem na T-2 povem zakaj so nas Siolovci odklopili, ženski na helpdesku ni nič jasno, saj ji piše na njenem zaslonu, da je bila naša poizvedba zavrnjena iz strani Telekoma, ker naj bi manjkal nek papir v zvezi z odklopom od interneta, reče da bo problem posredovala administracji t2ja. Ugotovi še, da je naša poizvedba že skoraj pri koncu, da so že predlagali datum 18.maj, da nas pridejo prklopit ampak da še čakajo pozitivni odgovor od Telekoma, da nam odklopijo trenutno tel številko iz centrale.
22.maja kličem spet na t2 in ponovno jim ni jasno zakaj smo odklopljeni od interenta, zgodbo jim ponovim še enkrat, ker očitno oseba s katero sem govoril prejšnji teden sploh ni sporočila ali kam zapisala naš problem. Tokrat govorim s moškim, ki še enkrat ugotovi, da bi t2 že moral priti k nam 18.maja, ampak da še zmeraj čakajo na odgovor od Telekoma. Ko se razjezim, da sem jim to že vse povedal prejšnji teden, me pusti čakati par minut, da to preveri - ugotovi da je prišlo do napake iz t2 strani, ker so pozabili poslati Telekomu nek papir v zvezi z odklopom od interenta (ironija pa je da kljub temu, da so pozbili poslati ta papir Telekomu je Telekom vseeno posredoval Siolu, da nas odklopi). Na helpdesku mi ta moški zagotovi, da bodo to zrihtali in najkasneje v 14 dneh naj pričakujem, da me Telekom odklopi in še isti dan naj bi prišel t2.
29.maja (danes) me firbec matra, kaj se dogaja zato kličem t2, in pravijo, da še zmeraj čakajo odgovor od Telekoma in jim povem, da so mi rekli, da bo to ta teden, pa mi reče, da to ni res in da bo ko dobijo odgovor Telekoma. Prosim ga da me zveže z nekom v adminicstraciji in me noče, ker tega kao ne mora.
Pokličem na Telekom in jih vprašam zakaj zavlačujejo moj odklop, razložim da so me že zdvnaj odklopili na Siolu od interneta, oni pa zavlačujejo odklop naše štvilke iz centrale, ker kao čakajo na nek papir v zvezi z odkopom iz interneta, seveda njim ni nič jasno in grejo to raziskati in me pokličejo čez 15 min nazaj. Povejo, da sploh ne čakajo nobenega papirja, da so mi to na t2 narobe povedali, ampak da je problem v tem, da jim je t2 poslal stornacijo, glede naše poizvedbe, ker je kao t2ju zmanjkalo portov v centrali, da bi nas priklopili na net (btw. moja centrala je cankarjev dom v Lj).
Pokličem spet t2 in zahtevam, da me zvežejo v administracijo in da se ne misim več ukvarjati s njimi na helpdesku, model mi spet reče da ne mora, mu razložim še enkrat problem in ga vprašam če mu zdi, da mi lahko on pomaga ali da bi bilo bolje da me veže v administracijo pa mi reče da mi ne mora pomagati ampak da bo posredoval problem administraciji jaz pa naj pokličem čez 2 do 3 dni. Seveda ponorim ampak to nima veze. Skratka dosežem popolnoma nič.
Sprašujem pa se, da če ne bi sam klical naokoli na Telekom in Siol, a bi na t2 spoh zvedeli, da so pozabili poslati neke papirje oziroma da so poslali stornacijo Telekomu, verjetno bi mi vsak teden ko bi poklical samo rekli "še zmeraj čakamo na Telekom da nam odgovori", in kako je možno, da na helpdesku t2ja sploh ne vejo da so poslali stornacijo???...
Ima še kdo kakšno idejo, kaj še lahko probam, edino možno pot še jaz vidim, da se osebno oglasim na t2 na Brnčičevi, pa da mi v obraz točno povejo kaj se dogaja, če sploh sami vejo...
sosko1 ::
iz lastnih izkušenj ti predlagam da greš na brnčičevo ter tam osebno urejaš zadeve. Jaz sem se podajal z njimi in telekomom pol leta. Za vsako stvar ki sem se jo dogovarjal po telefonu niso naredili, kar sem pa šel urejat tja pa je bilo urejeno takoj saj so to naredili vpričo mene.
Sharkec ::
sosko1,
Upam, da bo šla poizvedba še danes naprej čene se bom moral osebno zglasiti pri jih, saj je v tem momentu pomembno, da se poizvedba čim prej pošlje. Vem le to. da za vse skupaj potrebuješ veliko časa, saj če sam ne drezaš in klicariš ter urejaš, se nič nikamor ne premakne.
Sergio ::
T-2 ping:
64 bytes from 84.255.209.72: icmp_seq=17 ttl=252 time=8.595 ms
64 bytes from 84.255.209.72: icmp_seq=18 ttl=252 time=9.618 ms
64 bytes from 84.255.209.72: icmp_seq=19 ttl=252 time=8.756 ms
64 bytes from 84.255.209.72: icmp_seq=20 ttl=252 time=8.833 ms
64 bytes from 84.255.209.72: icmp_seq=21 ttl=252 time=8.475 ms
64 bytes from 84.255.209.72: icmp_seq=22 ttl=252 time=8.623 ms
64 bytes from 84.255.209.72: icmp_seq=23 ttl=252 time=8.527 ms
SiOL ping:
64 bytes from 193.189.160.47: icmp_seq=0 ttl=251 time=9.494 ms
64 bytes from 193.189.160.47: icmp_seq=1 ttl=251 time=9.320 ms
64 bytes from 193.189.160.47: icmp_seq=2 ttl=251 time=9.304 ms
64 bytes from 193.189.160.47: icmp_seq=3 ttl=251 time=9.209 ms
64 bytes from 193.189.160.47: icmp_seq=4 ttl=251 time=9.771 ms
64 bytes from 193.189.160.47: icmp_seq=5 ttl=251 time=9.176 ms
64 bytes from 193.189.160.47: icmp_seq=6 ttl=251 time=9.196 ms
Precej fajn. Še enkrat apeliram na ljudi, ki imajo doma težave z linijo, naj si poskusijo na novo napeljati domačo napeljavo. Worked wonders for me.
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
shock ::
Sergio: Ni zarad tega ker si na novo postavil kable doma, ampak zarad tega ker je T-2 uštimal par profilov na dslamih in zdaj ljudi nimajo več tako visokih pingov, še prejšnji petek sem bil na enem xy profilu, danes začudeno pogledam da noben profil se ne ujame z prejšnjih tednov. Čestitazt je treba "T-2" in še nekaterim, da so se potrudli naštimat dobre profile (a ne Nimda :D).
Irmscher ::
Kako pa ti veš na kerem profilu si bil in si zdej?
darkolord ::
Pri meni je razlike med vtičnico in tam, kjer mam 10 metrov navadnega telefonskega kabla vmes, približno 5 megabitov.
Sem poklical za pinge, sam so rekli, da je linija zdej nekje na meji zmogljivosti. Očitno bo treba prestavit modem k vtičnici :)
alexius ::
Sam ne morš pričakovat, da bo folk kar po stanovanjih stene razbijal in na novo postavljal kable...
Btw, ne vem kater profil maš ti ampak jaz mam še zmeraj previsoke pinge, pa mi je modem čisto zraven vtičnice... :(
shock ::
Irmscher:
Grem na dslam in preverim na kerem profilu sem, to je vse. BTW ne delam na T-2-ju.
Irmscher ::
--17:45:08-- http://www.t-2.net/test/Restricted/TOly...
=> `TOlympics.zip'
Resolving www.t-2.net... done.
Connecting to www.t-2.net[84.255.209.69]:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 126,854,596 [application/x-zip-compressed]
100%[======================================================================================>] 126,854,596 1.12M/s ETA
17:46:57 (1.12 MB/s) - `TOlympics.zip' saved [126854596/126854596]
A je to kul za 10/2 paket?
xgo ::
@shock
kaj je dslam in kako prides do njega
edit: sm najdu DSLAM @ Wikipedia
sam se kr nvem kuko se povezat in na dslamu pogledam kateri profil imam
  • spremenil: xgo ()
sosko1 ::
a mi lahko kdo zaupa nastavitve za mail na T-2 ( strežnik za vhodno in izhodno pošto)
hvala
Irmscher ::
pop.t-2.net
smtp.t-2.net
OChack ::
mimogrede za vse k tkole pingate in jokate kok počas vm dela, piung je precej odvisn od pripravljalnega časa paketa an uporabnikovi strani, ta pa je odvisn od pasovne širine, tko da če amste 256 kilo en drug pa 10 mega uplinka ne jokat zakaj amte vi 30 ms pinga on pa 8ms, smo pač to zadevo sprobal na cisco serverjih in tm se to lepo vidi........ tko da čudežov z 1mega linki ne prčakvat, zadeva pač taka je, zato majo večji paketi tud večji ping.......
Int€l inside, IDIOT Outside
flier ::
Sharkec: APEK ima prav, stvar se imenuje EMX, omogoca pa 4 povezave s hitrostjo 512kbit ali 2 s hitrostjo 1024kbit. Novico najdes na Telekomovi strani ce v iskalnik vtipkas EMX.
NavadniNimda: baje ti lahko pomagas pri neobicajnih poizvedbah :D Sicer sem pisal bivsemu sodelavcu ki zdaj dela na T-2 a odgovora nisem docakal (moriti mu pa nocem ker vem da ima zagotovo bolj pametno delo).
SasoS ::
OChack: na prazni povezavi je ping popolnoma isti pri 64kbit in 100mega linku
dean444 ::
Men zaenkrat vse dobro dela- sem LJ Dravlje.
Kars e tiče odogovorv dost hiro dobil vezo ko sem klical- na emial pa so mi zelo hitro odgovarjali- takoj naslednji dan in pa pol tri emaile v enem dnevu ko sem jih spraševal kam lahko pošljem pisno pritožbo- rekel sem naj se ne zgovrajajo samo na telekom ker dost stvari oni ne opravijo dobro - po tem sem v roku enega tedna dobil net. Sedaj ali slučaj al pa so pritožbe zalegle.
xy
Sharkec ::
flier,
Na Telekomovi strani sem našel članek o EMX. Sicer piše, da naj bi se uvedel širokopasovni dostop na osnovi EMX sistema za naročnike običajnih telefonov PSTN. Kaj to pomeni za tiste, ki imamo ISDN priključek na PCM. Ali je preko EMX tudi za ISDN naročnike možen širokopasovni dostop?
Pujcek ::
10. maja oddal pogodbo na posto, vceraj poklical telekomovec da pride namontirat razcepnik, pred eno uro pa prisla dva modela z t2, priklopila zadevo in dela. zmagal sem :)
aja, telefon sem obdrzal pri telekomu, paket mam pa najcenejsi (1m/256), lokacija za klinicnim centrom.
Razerzone ::
Včeraj so me s telekoma klical da pridejo jutri ob pol 11 namontirat razcepnik, pa me zanima koliko casa se caka potem se na T2?
SasoS, OChack :
čas potovanja (torej "ping") = latenca + velikost_paketa / pasovna_širina
(v praksi še bolj komplicirano)
64 kbps linija "doda" 12 milisekund,
256 kbps pa le še 3 ms, tak da to res nima vpliva.
(velja za paket velik 100 bajtov, navadni ping pa ima še manj)
alexius ::
@Amir: pričakuj danes klic s strani T-2, ker ponavadi pridejo pol ure po prihodu telekoma...
Če te pa ne pokličejo, jih daj ti.
antonija ::
@Amir: Ti kar klici na T2 ce ti je telekom ze zrihtal in se zmeni za uro/datum.
SasoS ::
stein: to je nek povprečni čas potovanja ki z realnim časom nima dosti veze. Če je linija prazna potem paket pride takoj ne glede na omejitev bandwidtha saj algoritmi nikakor ne morejo toka podatkov omejiti pri enem samem paketu. Torej realno meriš samo latenco povezave in ne skupen čas potovanja. 64kbit linija torej ne "dodaja" pinga. Stvari so seveda drugačne če linija ni prazna...
nastyboy ::
Naredu sem prenos številke iz mobitel omrežja v simobil. No danes sem neki preverjal.. in mi lep glas pove da ta številka ne obstaja?!!!??!?!
Probam še s kolegičino številko ki si jo je tudi prenesla... Ista pesem.
Zanima me če je še kdo opazu ta (d)efekt. In na čigavi strani naj bi bila krivda. Zdi se mi sicer da od simobila, sam vseeno.
Aja, klical sem iz T-2 omrežja, na navadnih verjetno deluje, čeprav nisem sproboval
Zanima me če se še komu to dogaja.
Očitno tale prenos številke ni ravno painless. oz, še ne delujejo stvari tako kot naj bi.
PS: Vidim da še marsikoga zajebavajo glede prehoda na T-2, tako kot so mene.... upam da vam bojo čimprej poštimali...
LP Marko
SasoS:
1.) tista formula ni za povprečje, ampak posamezen paketek
2.) velja za en segment povezave, torej do prvega ruterja (no ja, lahko je prej tudi bridge, switch ali karkoli). Kar je za naš primer OK, ker je dalje itak isto, ne glede kako linijo imaš.
3.) "Če je linija prazna potem paket pride takoj" Ne. Pride po času, ki ti ga pove omenjena formula.
4.) "Torej realno meriš samo latenco povezave in ne skupen čas potovanja" ??? Če govoriš o meritvitvi z orodjem ping, potem valda, da meriš skupen čas potovanja. Saj drugo sploh ne moreš (oziroma zelo težko).
5.) "64kbit linija torej ne "dodaja" pinga" ah ne ? Prosi, da ti narihtajo profil 64kbps (če sploh obstaja in primerjaj). Oziroma, če imaš 2 PC-ja, ju poveži preko RS232 in spreminjaj brzino in opazuj ping. Valda, da počasnejša linija več časa rabi, da prenese paket.
  • spremenil: MrStein ()
mile ::
nastyboy:
problem je na strani T-2 ja..tako kot jaz nisem mogel iz vega omrezja klicat na prenesene stevilke....
SasoS ::
stein pozabljaš da ne gre tukaj za fizično ampak umetno postavljeno omejitev linije. Modem šopa do fula dokler ne preseže alociranega bandwidtha, nato pa neha pošiljat. Sem imel na kablu 64kbit omejitev pa je to zgledalo tako, da je pri uploadu lučka žmrknila nato pa bila ugasnjena. Ping je bil seveda pod 10ms kar po tvoji enačbi sploh ne bi bilo možno. Tvoj trik z RS232 kablom ne bi deloval ker zakasnitev pa je odvisna od tipa povezave, ni pa odvisna od alocirane pasovne širine. VDSL pri 64kbit ali 10mega ima isti "ping".
(ah...za trik z rs232 sem dojel zdaj ja...samo to ni isto pri dsl-u, fizična sinhronizacija modema ponavadi ni ista kot umetna omejitev bandwidtha ker poleg neta po isti povezavi hodi tudi tv, phone - torej je sama linija zmožna večjega prenosa)
  • spremenilo: SasoS ()
Aha. Tak si ti mislil.
Formula je potem prava, samo si ti napačne vrednosti not deval ;)
flier ::
Sharkec: tega pa ne vem, EMX sem videl omenjen v Telekomovem internem glasilu pa sem si zadevo zapomnil. Drugace pa kolikor vem si v primeru da imas ISDN na svoji parici torej ne bi smel biti vezan na PCM skatlo. Najbolje da poklices na Telekom in povprasas, ce si prijazen se da marsikaj izvedeti.
OChack ::
SasoS : ni res smo delal IPSEc protokol in to, pa smo prvo naštimal hitrost linije 56kilo in je biv ping brez odatne glave 250 ms, z dodatno IP glavo (112 okteto) pa nekje 520 ms, potem smo dal hitr5ost na 8Mbit, je zadeva mela pingtm nekje 8-12 ms, seveda so ble razdalje zelo kratke par metrov, tko da potovanje paketov ni mel velicga upliva, vse je blo odvisn od pasovne širine k smo jo določil in od pripravljalnega časa paketa......pač mam tok pojma ker diplomiram iz telekomunikacij pa ne me jebat :)
to če je linija prazna pa je hitrost paketa odvisna pol od tega kok hitr pol vseskup "zrovtajo" in usmerjo na siolu in podobnih usmerjevalnikih. Cisco ma recimo hitrost obdelovanja tm nekje 1 mio paketov v sekundi, zj če ih je več pol jebiga če ni pa nobenga potem pa čas ni omembe vredn.
logično pa je če ti poleg pinganja še neki dol vlečeš in to, valda ne bo ping idealn, so še ostali paketi k poberejo potrebn čas itd....., je pa tud neki da kabl deluje drugač kot DSL in am v osnovi nižje pinge
  • spremenil: OChack ()
Brane2 ::
Hmm. Zanimivo. Ping mi je padel s 24-26 ms na 11-13 ms, pa še nekaj je.
Imam dostop na net preko centralnega serverja. Če sem imel MTU kartice, ki je bila vštekana v VOOD nastavil na max (7200 na moji kartici), je hitrost prenosa testne datoteke padla na nekih 5 Mbit/s. Zanimivo je, da je padla hitrost same TCP/IP povezave, ne pa prenos modema ali česa drugega na nižjem nivoju. Če sem zalaufal dva ali več prenosov, sem lahko dosegel polno hitrost paketa. Če sem spremnil MTU kartice na 1500, je problem zginil.
Mislil sem,d a je to zaradi tega, ker ICMP paketi tipa 3 niso šli skozi. Težil sem, naj jih spustijo in ko so jih, sem lahko pingal arnes si z dolgimi paketi in dobil nazaj error ICMP, vendar hitrost prenosa testnega filea še vedno ni šla čez 5M/s, če je bil MTU nastvaljen na karkoli več kot 1500.
Zanimivo se mi zi to, da ta MTU ponavadi tu ne igra vloge, ker je pri vlečenju podatkov dol pomemben MTU partnerja, torej T-2jevega DSLAM-a.
Tudi če sem dal MTU na 1500 in potem potegnil ta isti file s kakega klienta, je šel prenos počasi.
No, sedaj je problem na lepem zginil. Tudi ping arnesa dela in stvar ne škripne ampak se pobuni, če pingam s predolgim paketom in ne pustim fragmentacije...
No, v glavnem, stvar dela.
Brane2 ::
Malenkosten popravek. Hitrost prenosa sedaj dela, ICMPtype 3 pa ne pride skoz, čeprav prej na mojo zahtevo je.
Sedaj se je stvar bunila zato, ker je imel strežnik nastavljen MTU 1500 na kartici proti VOODu in je ICMP poslal kar strežnik, ko sem pingal arnes, ker stvar ni šla skozi njegovo kartico.
Prej sem imel tudi neomejeno hitrost "za potrebe testiranja" (:D ), ki je sedaj omejena na to, kar plačujem: 8/1...
90 / 253
