Forum » Igre » American Army PROBLEM
TOP ::
Igra mi deluje odlično ko pa hočem ven z igre mi javi plav ekran in potem moram ga resetirat.Misliv sem da je kaj narobe z rami ampak delujejo dobro imam ga 768MB.Prosim vas,če mi lahko pomagate.Plato imam NF4 grafo 6600GT od Leadtek.
TOP ::
Naložu sem jih in iz igrice gre normalno.Ko pa hočeš ponovno zagnat PC mi ne najde več rajverjev od grafe niti kako grafo in monitor imam.Kaj naj storim.Grafo imam Leadtek 6600GT Extreme.Tudi z njihove strani sem jih naložu isti problem.PROSIM ZA POMOČ.
KraP ::
Za chipset,bom ga vprasal bol tocno ko ga slisim.Mi isto igramo in vem da se je kr prejeb.l zaradi tega,
ima pa tud nf4
LP =RB=_KraP.slo
ima pa tud nf4
LP =RB=_KraP.slo
KraP ::
Evo ( 7.1.8.9) te je imel on pravi pa da so se novejsi zaj zunaj,77.72 in za grafo z 66.93 mu ni delalo, ce pa se ti to nebo pomagalo pa mors v registru nekaj spremenit trenutno neve tocno, ce najdem napisem nekaj z on/off .
KraP ::
Guide for fixing blue screen of death problem with the amd64/geforce 6 series
This is a simple guide i decided to make for people with the amd 64 and the geforce 6 series.
The problem is caused by over half the nvidia drivers for geforce 6 series conflicting with the new amd 64 technology.
To fix this problem you must disable this technology. Why? well because the latest nvidia drivers
will give you a MAJOR frame bost in games! and they have much better support for the geforce 6 series!
disabling the amd 64 technology (that windows service pack 2 enables you to use) will not slow your computer down in any way!(as far as gaming goes)
your pc WILL get bsod if you have these specs!
-Amd 64
-geforce 6 series (/w latest nvidia drivers)
-windows service pack 2!
Note: your pc may only restart once a week but it is caused by this problem!
also the defalut driver that comes with your geforce 6 series will have this problem as well!
if you are playing many graphic demanding games you will notice you are having this problem often!
HOW TO FIX
1. go to control panel
2. click on system
3. click on the advanced tab
4. under the system startup section you will see an edit butten(click it)
5. when the boot.ini file opens, find /NoExecute=OptIn
6. change /NoExecute=OptIn to /NoExecute=AlwaysOff
7. restart and bam you fixed your pc!
(when nvidia brings out newer drivers that fix this problem change it back to /NoExecute=OptIn)
iam gessing this will take a couple months
to je to: when the boot.ini file opens, find /NoExecute=OptIn
-Amd 64
HOW TO FIX
2. click on system
| » | Boot.ini in Windows XP SP3 problemOddelek: Pomoč in nasveti | 1945 (1694) | kixs |
| » | GTA 4 PROBLEMOddelek: Igre | 1408 (997) | Engineer_SLO |
| » | Pomoč pri bootanju vista, xpOddelek: Pomoč in nasveti | 2201 (2063) | matjaz23 |
| » | en problemOddelek: Pomoč in nasveti | 1519 (1436) | Good Guy |
| » | Windows XP PRO Boot problemOddelek: Pomoč in nasveti | 1695 (1662) | 50Cent |
