80GB velika FAT 32 particija
accom ::
Ok, najprej "želja":
Router ima USB in omogoča FTP server z USB diskom... Imam en 80 GB disk "viška", kupim externi USB box za disk. Edini pogoj routerja je, da je disk formatiran na FAT32 in vidi lahko samo 1, primarno particijo diska.
Zdaj pa vprašanje: kako hudiča formatirat 80 GB veliko FAT32 particijo brez win98? Imam W2K in ene XPje, ampak ti ne podpirajo več kot 32 GB velikih FAT32 particij (microsoft pravi, da FAT 32 v teoriji podpira do 2TB veliko diskovje). A se na Win98 da formatirat tako velike particije? Kako pa se to naredi brez Win98?
hvala in lp, Accom
Regret is a hope for a better past.
5er--> ::
http://www.abit-usa.com/faq/mb/2002031801.php
You cannot format a volume larger than 32 GB in size using the FAT32 file system during the Windows 2000 / XP installation process. Windows 2000 / XP can mount and support FAT32 volumes larger than 32 GB, but you cannot create a FAT32 volume larger than 32 GB by using the Format tool during Setup. If you need to format a volume that is larger than 32 GB, use the NTFS file system to format it.
* Another option is to start from a Microsoft Windows 98 or Microsoft Windows Millennium Edition (Me) Startup disk and use the Format tool included on the disk. For additional information about how to use a Microsoft Windows 98 or Microsoft Windows Millennium Edition (Me) Startup disk to format a hard disk, click the article number below to view the article in the Microsoft Knowledge Base: How to Use Fdisk and Format to Partition/Repartition a Hard Disk.
accom ::
Thanx za hiter reply, ampak sprašujem, če obstaja možnost kreiranja/formatiranja take particije na še kakšen drug način. Mah, ziher obstaja, samo ne vem zanjo... damn. A ma recimo knoppix al pa kaka druga off-the-CD distro kakšno tako možnost?
Self-Defence ::
Lahko poskusiš s programom Partition Magic. Mislim, da bo šlo.
SavoS ::
Zagonsko disketo od WIN98 in fdisk poženeš pa boš lahko sformatiral v FAT32 ....
Podpis..... Kdo mi je vkradu podpis???
boštjan ::
tudi z zagonskim win xp cd bi moralo it
NF7-S,2500+@2200MHz,MSi 5900SP,LCD Philip 190X6,Maxtor DM+9 120GB SATA,
2*256 3200/A KHX, PSU 420W DF chieftek
Pyr0Beast ::
Jst sem mel na win98Se 80G fat32 pa je delal čist normalno.
accom ::
Hvala vsem!
Na koncu sem res izbrskal Win98 samo da sem formatiral disk... brez problemov. Želel sem izvedeti - in še vedno me zanima, če kdo pozna kakšno orodje, ki je tega sposobno pod kakšnim drugim OS-om?
totek24 ::
Partition Magic to zna.
Če kdo kaj rabi: http://www.bolha.com/index.php/ukaz/show/kat/-4/userid/totek
SavoS ::
jap partition magic to zna zelo dobro, res pa je, da je plačljiv program ( za nekatere ne...), zato smo ti pomagali z free programi...
Lith ::
@accom: DISKETA !!!
z njo nardiš vsak disk FAT32 particije kak hočeš
¤ black holes rule; I like the speed, speed kills ¤
Formatiranje diska v W10 ne gre v starejše formate (strani: 1 2 )
5611527 (10267) Pithlit
Formatiranje diska v FAT32
134201 (4025) Redorange
od 160gb diska prikaže le 32, prvo mi je v partition magic prikazalo 160...
202515 (2191) sirotka
trdi disk hitachi
282532 (2167) kerrigh
Omejitve FATa 32
Oddelek: Operacijski sistemi
81740 (1599) Brane2
