Forum » Kaj kupiti » Kateri prenosnik?
Kateri prenosnik?
Ker imam še 4 PCIE slote frej v mašini, a misliš, da če dam še 2 titana notri, da bo še vedno slabša od mbp za obdelavo grafike?
Seveda. PCji nimajo usklajenjga hardwarea no, to je kr tko nametano skup !!
GenZNPC ::
Zakaj bi mel 2x xeon E5650, če ti to i5 2c/4t mbp z levo roko požene samo na 1c/2t ?
skibidi
GenZNPC ::
http://www.slrlounge.com/apple-vs-asus-...
Pri punci pa bi bila razlika v uporabi še hujša. Veselo branje tistim, ki želijo izvedeti več.
We have several Apple machines in the studio because they are necessary for some of the things we do. However, our workhorse machines are all ASUS PCs.
If we know we can purchase a $2k machine that can perform as well as a $4k machine, then that would mean we can supply all 15 workstations for $30k as opposed to $60k. This is a big deal for a small business and that is why we run such comparisons.
"Fan Boy Arguments"
Operating System Stability Argument - "Windows 8 users spend forever dealing with crashes and fixing their operating systems."
Operating System Stability Answer - We have switched 3 of our production machines to Windows 8 and seen no stability issues. While in the past, in general Windows has required more maintenance and been less stable than OSX, we have crashed OSX on plenty of occasions as well
Real-Time Playback Results
As you can see from the video above, the MBP Retina struggled when it came to standard real-time playback with just our 4 videos and their base effects applied. Once we added in the Gaussian Blur and started making real time adjustments, playback began to stutter even further.
In both of these tests, the G75 held a very smooth and constant real-time playback framerate, even when we were rapidly adjusting the Gaussian Blur settings. Overall, there was really no comparing real-time playback between these two machines. The ASUS G75 noticeably outperformed the Apple MBP Retina in all real-time playback tests.
Clip Export Results
In exporting the clip, the results were even more one sided. The ASUS G75 took 42.9 seconds to export the test clip, whereas the MBP Retina took 201.4 seconds or nearly 5 times longer to export the exact same video clip.
However, in regards to video performance, the ASUS G75VW-DS73 absolutely crushed the Apple MacBook Pro Retina by margins of 400-500%.
There is no doubt that when it comes to maximizing the performance of Adobe Premiere CS6, the ASUS G75VW-DS73 is the clear winner as it has a far more powerful graphic card and read/write capabilities with its RAID 0 configured SSDs. Not bad at all for a machine that costs nearly half the price.
skibidi
- spremenil: GenZNPC ()
leiito ::
krneki0001 je izjavil:
Leiito, moja domača mašina je trenutno takale:
2x xeon E5650 (vsak proc 6C/12T - torej skupaj 12C/24T)
24GB rama
5x 146GB SAS s 15K obrati hot-swap
Matrox G200 grafika
redundančna napajalnika 570W
Na tej mašini laufa 5 virtualk nanjo se pa priklapljam s thinclienti, ker je zadeva na podstrešju (je glasna, pa bolje da tam ptiče iz strehe preganja, kot da jo jaz poslušam.
Po moji, sicer laični oceni vsekakor. Dodajati RAM na to pofl je prej kontraproduktivno, pride do McNulty efekta (upam, da sem ga prav napisal, ampak gotovo veš kaj mislim). To nesi na Rdeč križ, če bojo hoteli vzeti, sebi kupi pa Mac Pro. MBP za tvoje potrebe ne bo zadoščal, ipak je to neka jack of all trades mašina, ni namenjena resnim igričarjem.
- predlagalo izbris: GTX970 ()
dnje ::
Zdravo, zanima me če se splača kaj od tega kupit, gre se za rabljen prenosnik:
http://www.bolha.com/racunalnistvo/pren...
najbolj me zanima ravno zadnji, saj ima še dolgo garancijo. Je vredno svojega denarja ali je predrago? Ali je kateri od teh boljši za svojo ceno?
lp.
lp.
krneki0001 ::
24GB rama
Matrox G200 grafika
Rama ta "pofl" kišta podpira samo 288GB (nekje 16X tok kot mbp) in res je, ni namenjena igranju, ampak resnemu delu, pač ni Apple, da bi se igrce igral na njej. Na njej se bo zrenderiralo par projektov, potem jo bom pa šenkal, ko bo odslužila začenti vložek (lahko tudi rdečemu križu).
Texslo ::
Kateri izmed teh dveh prenosnikov je boljsi nakup?
- https://www.mimovrste.com/prenosniki/le...
- http://www.amazon.de/dp/B00KCJAI1A/ref=...
Alamar ::
dj_uro ::
prosim moderatorje, če malo vržejo uč na uporabnika leiito, saj zadnje dni dela samo ''zgago'' in nevoljo v temi Kateri prenosnik?
vw-klub.si
Jure12 ::
Zdravo. Sam se zanima za nakup prenosnika, moram pa reči da se ne spoznam prav veliko na računalnike. Uporabljal bi ga za faks ter večinoma bi imel gor filme ter glasbo. Kar se tiče igric bi igral le kakšen Football Manager in nič drugega. Budget je 700-800€ (lahko tudi kakšnih 10€ več). Najlepša hvala za vso pomoč :)
bananahobby ::
Zdravo! Tudi jaz se zanimam za nakup prenosnika, in me zanima v čem bi se poznala razlika med i5 in i3 procesorjema? Oziroma bi se pri igrah poznala razlika med naslednjima prenosnikama?
http://www.so-doo.si/hp-pavilion-15-p08...
The Spartans do not ask how many but where they are...
- spremenil: bananahobby ()
znbojan ::
Za otroka(6 razred) potrebujem prenosnik (zaslon >15'').
Potrebe: pisanje v wordu, powerpoint, gledanje video, poslušanje glasbe (igre trenutno niso prioriteta) - nič posebnega.
Ker je malo morje enih procesorjev že od Intela (ne vem ali so AMD ok) ali je npr. Intel i3-3217U več kot dovolj ali že kakšen osnovnejši procesor zadošča npr. N3520.
Planirano je, da se dvd odstrani in se vgradi en 128GB ssd disk... verjento kakšne že tako sestavljene kombinacija ni?
Želja: prenosnik manj kot 400 (raje 350?).
ps. nakup v EU ni problem.
(nimam opravka s "slabimi" procesorji.. imam prenosnik za >1k & glede da namesto tablice uporabljamo po hiši chromebook (ki se je izkazal kot odličen nakup za določe vrste opravil in je strojno "ubog"), me zanima ali je potrebno precej investirati za windows8 (7) prenosnik.
Hvala,B.
Hvala,B.
znbojan
sajmonsaz ::
Pozdravljeni, prišel je čas menjave prenosnika in sem si ogledoval po spletu za katerega se odločit in mi je padel v oči Asus http://trgovina.siol.net/oddelki/racuna...
ampak se ne morem odločit ali bi vzel 15" + 24" monitor ali bi vzel 17" http://trgovina.siol.net/oddelki/racuna... brez dodatnega monitorja. Dodatni monitor pri 15" bi vzel izključno zaradi iger in kakšnega filma. razlika je to da je 15" manjši, ima pa IPS zaslon, 17" je večji, nima pa IPS zaslona...
Kakšen predlog za lažjo odločitev?
Lp, Simon
Lp, Simon
galu ::
Hvala,B.
Samo en komentar:
Res mu kupi prenosnik iz DE. Boš prišel ceneje skozi, mali pa se bo še naučil slepega tipkanja. Win-win.
 Tako to gre.
scipascapa ::
Evo, tole iščem za znanca:
Lahek / hiter / 15" / ssd
željeno touch screen / Hd /
Trden da ne razpade /Poslovni razred
Kaksen zvocnik mi odvec
absolutno kak ultrabook, zenbook, spectre ali envy ipd?
samo pri nas hudič dobiti kaj pametnega....
zakaj bi se omejeval na naš bananastan ?
GenZNPC ::
Lp, Simon
N751JK bi tudi moral imeti IPS: http://www.asus.com/Notebooks_Ultrabook...
Pojdi si prenosnik pogledat v živo nekam oba. Glede cene pa, baje ga je imel comshop pod 1000€.
skibidi
Dionis ::
In kako sta se odločila? Estetika ali surovi performance z kvaliteto?
Sicer pa je tu optimalna rešitev za oba, kupiš tole:
http://www.ebay.com/itm/6-Apple-Logo-Au... in tole: http://www.computercenter.si/racunalnik...
Pa imaš vse v enem za 600EUR
Drugač pa kr po 551jk (2,7kg) in 512ssd.
SSD je do 1dag
Pozravljen še enkrat. Zadeve še ni kupila, vendar je rekla da bo raje vzela 13' za 1300EUR sicer z malenkost slabšim HW, vendar ji očitno toliko več pomeni toliko lažji PC. Sam osebno bi vzel 551JK in verjetno malo manjšo SSD 256 max... pomoje bi bil tudi 128 čisto dovolj...
Bi pa rad omenil, da sedaj ko sem se pri večih pozanimal okoli Apple/PC si mislm to. Hvalabogu da obstajajo Apple fani ki preferirajo te izdelke, da imajo PC konkurenco in se trudijo, da so vedno boljši. Tako kot mi je naprimer žal da AMD ne konkurira ravno in prav tako RADEON z grafičnimi karticami.
V glavnem bi se rad še enkrat zahvalil za nasvet in LP
- spremenilo: Dionis ()
DMX ::
a je takšen NB dovolj dober za YT in kakšne flash igrice?
http://www.merkur.si/aktualno/akcije-in...
scipascapa je izjavil:
Pogleda naj Lenovo škatle ...
Thinkpad serijo ...
GTX970 ::
hojnikb: ker mora biti pri nas kupljen žal hehe....diners pa to, imaš kaj v rokavu?
Ne moreš v banki dobiti potrošnikega kredita in kupiti v tujini ?
mariog ::
Kupujem low budget prenosnik. Trenutni asus po parih letih zapušča ta svet in je čas za novega.
Potrebujem ga za brskanje po spletu, web marketing,statistike,... kakšna malenkost v PS. Iger ne igram, kdaj pa kdaj pogledam kakšen film. Se pravi nič zahtevnega. Disk mi je nepomemben, ker vse kar uporabljam imam na cloudu in bo v vsakem primeru primarni disk zamenjal ssd. Tukaj bi potreboval še vaš nasvet kaj kupiti (256GB).
Na amazonu gledam lenovo z50-70 pa ne vem katerega izbrati. Sistema ne potrebujem, ram bom pa verjetno takoj nadgradil na 8gb.
Prvi ima Intel Core i3 4010U in grafiko NVIDIA GeForce 840M 2 GB.
Drugi pa Intel Core i5 4210U in grafiko Intel HD Graphics 4400.
http://www.amazon.de/Lenovo-Notebook-Gr...
Je to v redu izbira ali naj za ta budget pogledam raje kaj drugega?
www.spletnaresitev.com
technolog ::
http://www.ultrabookreview.com/5123-asu...
Karil ::
Pozdravljeni,
zanima me ali obstaja prenosnik, ki je NUJNO dobavljiv v Sloveniji do 650€ in tudi evra ne več razen, če se lahko dobi popust za razliko:
Preiskal sem ogromno spletnih trgovin in brez uspeha, največ zaradi 17" zaslon in posledično maksimalne cene.
Lenovo Z50-70 bi bil idealen, ampak žal nakup v tujini ni možen pod nobenim pogojem.
Tale bi bil definitivno primeren, vendar je 15,6" - http://www.enaa.com/oddelki/racunalnist...
Lep pozdrav in hvala!
- 17" zaslon
- i3 ali i5 4. generacije
- SSD 120GB+ ali SSHD 256GB+
- Ostalo (grafika, RAM,... ni pomembno)
Steinkauz ::
http://www.computercenter.si/index.php?...
https://www.mimovrste.com/diski/crucial...
Pa ti še ostane 500gb disk in kupiš za 5eur ohišje s ebaya in maš zunanji disk.
Laptopi, ki imajo vključen SSD so predragi :)
DMX ::
anyone?
krneki0001 ::
Najbrž bo, čeprav je drag za tak procesor in disk.
DMX ::
a se dobi kaj "boljšega" za takšen denar +/- par EUR?
recimo kaj takega?
http://trgovina.mercator.si/tehnika/rac...
- spremenilo: DMX ()
krneki0001 ::
Osebno nebi kupoval izpod prenosnika s procesorjem pod nivojem Intel I3, še raje pa I5.
Nekako mi tile celeroni niso ravno zgled tega, da bo vse zadovoljivo hitro delovalo.
DMX ::
ma saj vem, ampak je jeba, ker je budget max. 300€, za ta denar pa ne verjamem da dobiš kaj "pametnega" :/
amacar ::
Lahko kaj takega: http://www.amazon.de/Lenovo-Notebook-Gr... z i3 ali daš 50€ več za i5 če ti je integrirana grafa dovolj.
sicer pa: http://www.amazon.de/dp/B00KCJAI1A/ref=...
Aja 300€ budget, taprvi je s poštnino sicer 325€
- spremenil: amacar ()
Silvo ::
Se strinjam....samo kaj,ko ljudje želijo škatle čimceneje,po možnosti za 200€..samo za net pravijo:)
Celeroni pač pokrivajo ta segment "nezahtevnih"kupcev in i5 za ta denar pač ne gre:)
Silvo
krneki0001 ::
Da imaš zraven windowse ne vem če.
lahko je brez
Ali mora biti nov?
Rabljeni Lenovo T410 in T510 so ugodni, imajo I5 procesor, do 8GB rama in so na splošno zelo kvalitetni prenosniki. Na takem bo pa vse delovalo.
lahko je brez
Ali mora biti nov?
Pol raje vzemi T420 ali T 520 da daš lahko noter 16 GB. Seveda če potrebuješ.
Pri Thinkpadih zelo pazi na to kak ekran imajo. Imaš vse variante, ki se bistveno razlikujejo po ceni.
krneki0001 ::
Če je pa budget pod 300 evrov, kje bo pa dobil T420 ali T520 za ta denar?
MStrix ::
KAJ PA KEJ TAKEGA
http://blinkcomp.si/pc-ji/1214-asus-x55...
drgač si pa tuki mal ščekiri ponudbo
http://www.ceneje.si/
- spremenilo: MStrix ()
hcetols ::
Nameravam kupiti naslednji računalnik... zanima me če se splača pa če je tale procesor vredu?
http://www.amazon.de/Lenovo-Notebook-Ge...
In kako je glede garancije :)
MStrix ::
odvisno za kakšno uporabo gre, drugače pa preveri še domače ponudnike, ker se mi ne zdi smiselno kupovat v tujini za isti denar kot doma.
Zheegec ::
za takšno ceno v Sloveniji ne dobiš nič niti približno podobnega.
Janez Janša, 29.04.2014
amacar ::
Nek 4 leta star i5 je glih na ravni novih i3-XXXXU procesorjev, tako da ne bo nič pridobil, sploh če bo dal za rabljenega 300€, medtem ko je že nov ~320€
lmorgh ::
Mi lahko za cca 600€ svetujete kaj boljšega od tegale?
http://www.computeruniverse.net/product...
hcetols ::
rabljenega nebi rad kupovau:) potem pa dam rajši več denarja
npr tole http://www.amazon.de/Lenovo-Notebook-Ge...
edino če je v slo kaj podobnega za isto ceno? :D
GenZNPC ::
Rajši kupi tistega i3 za 340 pa razliko v žep ali za SSD.
Tudi če boš čez 4 leta ta i3 menjal za novega, bo skupno potem 680EUR na recimo 8 let
in bo ta drugi verjetno boljši od tega kvazi i5ke, pa hkrati dobiš novo mašino v roke, ki bo čez štiri leta glih tam-tam.
skibidi
