Desni klik na ikono-obešanje sistema
lm44 ::
Ob desnem kliku z miško na ikono, npr. na kako zazipano datoteko, bližnjico za program..., se mi sistem obesi. Ne pojavi se meni (kopiraj, prilepi, itd...).Čez čas se pojavi opozorilo o napaki, nekaj v stilu: Dr.Watson error...Ne pomaga nič drugega kot ponovni zagon.
Operacijski sistem je WIN XP + SP2, 160 GB HD, Athlon 3000+, GeForce 6600 GT, 512 Mb rama. Stvar se je začela pojavljati kar naenkrat in pojma nimam, kaj je narobe!
Hvala za nasvete.
lm44 ::
Našel odgovor. Pa še za tiste, ki bi imeli iste težave:
"Right click causes an error and crashes Explorer.exe after installing Windows XP SP2?
When you right-click on a Desktop icon or a folder, the pointer changes to a hourglass, Taskbar disappears and after about 30 seconds the screen comes back to normal and still no right click options are available. This behavior may be seen after installing Windows XP Service Pack 2. However, it's not a problem caused by Service Pack 2, but an incompatible Context-menu handler from DivX."
"RESOLUTION
(for older versions of DivX software)
Eliminate the context-menu handler from the registry, or disable it temporarily using ShellExView tool.
Click Start, Run and type REGEDIT. Navigate to:
HKCR \ * \ shellex \ ContextMenuHandlers \ EncodeDivXExt
Backup the key to a REG file, and delete EncodeDivXExt key
Close Registry Editor and restart Windows
Using ShellExView utility
See this page for more information on using ShellExView utility (see Method 2 in that page). In ShellExView, the entry might read as EncodeDivXExt Module. More information from DivX.com Forums, regarding DivX and the problems with Windows XP Service Pack 2"
Dober Singleplayer campain FPS špil?
Oddelek: Igre
355776 (4950) Bor H
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153704 (3094) fr!Xy
[DivXviD] filmi na Divx predvajalnikih brez problemov
Oddelek: Zvok in slika
2123721 (10722) bbbb
Manjši popravke za uporabnike Windows Firewall
Oddelek: Novice / Varnost
164019 (3483) denial
Windows xp in samo 127 GB
142186 (2002) Cranchi
