SATA diski @ Gentoo - kernel panic
PARTyZAN ::
Imam naslednji problem ob bootu Gentooja (x86_64, maticna na NF3 cipovju):
Klik!
grub.conf izgleda takole:
# Which listing to boot as default. 0 is the first, 1 the second etc.
default 0
# How many seconds to wait before the default listing is booted.
timeout 20
# Nice, fat splash-image to spice things up :)
# Comment out if you don't have a graphics card installed
splashimage=(hd0,5)/grub/splash.xpm.gz
title=Gentoo Linux x86_64 2.6.11-r7
# Partition where the kernel image (or operating system) is located
root (hd0,5)
kernel /kernel-2.6.11-gentoo-r7 root=/dev/sda5
# The next four lines are only if you dualboot with a Windows system.
# In this case, Windows is hosted on /dev/hda6.
title=Windows XP
rootnoverify (hd0,0)
makeactive
chainloader +1
/dev/sda6 je /boot (ext2)
/dev/sda5 je root (ext3)
/dev/sda7 je swap
V kernel imam ze vkompajlano podporo za sata/scsi diske (Ravnal sem se po tem HOWTOju)
CCfly ::
root (hd0,5)
Daj na 0,0.
"My goodness, we forgot generics!" -- Danny Kalev
PARTyZAN ::
hd0,0 je v mojem primeru boot particija XPjev (sda1)
  • spremenilo: PARTyZAN ()
miha ::
zbriši "root=/dev/sda5".
Lp Miha
<body></body>
CCfly ::
2.4.3. GRUB's Root File System
Some users are confused by the use of the term "root file system" with GRUB. It is important to remember that GRUB's root file system has nothing to do with the Linux root file system.
The GRUB root file system is the root partition for a particular device. GRUB uses this information to mount the device and load files from it.
With Red Hat Linux, once GRUB has loaded its root partition (which equates to the /boot partition and contains the Linux kernel), the kernel command can be executed with the location of the kernel file as an option. Once the Linux kernel boots, it sets the root file system Linux users are familiar with. The original GRUB root file system and its mounts are forgotten; they only existed to boot the kernel file.
root device-and-partition — Configures GRUB's root partition to be a specific device and partition, such as (hd0,0), and mounts the partition so that files can be read.
NoOrdinary ::
v kernel vključi še podporo za filesystem ki ga nucaš (obvezno ne kot modul), tvoj grub.conf je čist u redu
brez ideje sem za podpis
PARTyZAN ::
Vse je bilo ze vkompajlano v kernel. Zadevo sem resil z udevom ;) genkernel --udev all
Grub Error 15: File not found
Oddelek: Operacijski sistemi
52065 (2007) poweroff
Kako instalirati Linux in xp?
62718 (2639) Blinder
Iz Linuxa v Windows -> MBR (strani: 1 2 )
625601 (4936) WarMaker
Gentoo install (strani: 1 2 )
526455 (5875) HerrBaron
gentoo,grub čaka minuto ob zagonu
51394 (1327) potepuh
