Forum » Programska oprema » Word 2003 ne odpre datoteke iz worda 2000
morazem ::
Na računalniku kjer imam nameščen word 2003 mi ne odpre samo ene datoteke ki jo imam napisano v wordu 2000. Zanima pa me kako bi lahko to datoteko popravil z wordovo pomočjo sm se že nekaj matral pa ni nič pomagalo. Datoteko pa mi odpre wordpad in tudi frontpage samo tedva programa spremenita celotno obliko dokumenta tako da mi ne pomagata. Word pa mi javi napako:
This error message can appear for several reasons.
The document may be corrupt or damaged. Use either the Recover Text converter or the Open and Repair feature. Both are available from the Open dialog. The Recover Text converter is in the Files of type: drop down and the Open and Repair feature is available from the Open button (select the down arrow and not the button itself).
File permissions may be set so you cannot access the file (read denied). It is even possible you do not have permissions to open anything within the drive or folder the file is saved to. In this case, contact the owner of the drive or folder and request permissions to access the file.
It is possible you have run out of system resources (disk space or RAM) or another program on your system has consumed all the available memory. It is even possible for a program to have a memory leak that is using up large quantities of memory. The best method to recover memory consumed by a memory leak is to restart the computer. It may be possible to shut down the offending program by using the Task Manager, but it is not recommended since it may further destabilize the system.
There may be a read lock on the file you are attempting to open. Another user may have the file open, or even another application that has a link to the file has placed an exclusive lock on the file and is not allowing Word to open the file. If a custom application has opened the file, it may have opened the file using an incorrect method.
More information about this error message online.
Hvala
Hvala
AMD Sempron 3100+, Epox 8KDA, Gf4Ti 4200 64MB, Kingstone512MB, Seagate 160Gb
- premaknil iz Pomoč in nasveti: ToniT ()
Daedalus ::
Probaj z Open Office odpret - če maš hitro povezavo, si pejd downloadat.
[J.P.Sartre]
[J.P.Sartre]
| » | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 4405 (3671) | dukedl |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7273 (7132) | ManDriver |
| » | eno vprašanje glede diskaOddelek: Pomoč in nasveti | 1949 (1794) | ~Speed |
| » | Ne da se zbrisat filmaOddelek: Pomoč in nasveti | 1818 (1605) | andper |
| » | kernel32.dllOddelek: Pomoč in nasveti | 1839 (1660) | alf__ |
