miniDV kamera
miniDV kamera
bochow89 ::
Kako iz miniDV-ja (DV-AVI fajla) dobil najboljšo kvaliteto (DVD?) za poznejše urejanje oz. rezanje filma. S tem mislim kateri format naj uporabim (MPEG, AVI?)
TNX:)
Let's get computin'
rabbit ::
Najbolje da film editiraš kar v tem formatu DV) kot si ga naložil v računalnik, nato pa ga izvoziš kot mpreg2 format. V programu za avtorizacijo pa potem dodaš vse linke in gumbe, ter poglavja če jih rabiš.
bochow89 ::
v premieru ne znam dobro nastavljat nastavitev, rad bi dobil full quality mpeg2 file brez prepletenja (deinterlace) pa mi potem ne deluje...:\
Let's get computin'
bochow89 ::
če se kdo tukaj spozna na te nastavitve v adobe premieru 7, naj pove...
Video Summary:
Codec: MainConcept MPEG Video
Video Type: MPEG-2 Video
Quality: 5.00 (high quality)
TV Standard: PAL
Aspect Ratio: 4:3
Frame Rate: 25 fps
Profile: Main Profile
Level: Main Level
Program Sequence: Progressive
Bitrate Encoding: VBR
Encoding Passes: Two
Target Bitrate (Mbps): 14.0000 (high quality)
Maximum Bitrate (Mbps): 14.0000 (high quality)
Minimum Bitrate (Mbps): 14.0000 (high quality)
M Frames: 3
N Frames: 12
Closed GOP every: 0
Macroblock Quantization: 10
VBV Buffer Size (2K bytes): 112
Noise Control: Noise Sensitivity
Noise Sensitivity/Reduction: 5
Write SDE: Do not write
Force VBV Delay: 0xffff
Progressive Frame: Progressive
Intra DC Precision: 9 Bits
Intra VLC Format - I Frame: Table 1
Intra VLC Format - P Frame: Table 1
Intra VLC Format - B Frame: Table 1
Frame Prediction DCT - I Frame: Use Frame Prediction and DCT
Frame Prediction DCT - P Frame: Use Frame Prediction and DCT
Frame Prediction DCT - B Frame: Use Frame Prediction and DCT
Quantization Scale Type - I Frame: Non Linear
Quantization Scale Type - P Frame: Non Linear
Quantization Scale Type - B Frame: Non Linear
Alternate Scanning Pattern - I Frame: Alternate
Alternate Scanning Pattern - P Frame: Alternate
Alternate Scanning Pattern - B Frame: Alternate
Sequence End Code: Write
Embed SVCD User Blocks: Not Embed
Ignore Frame Interval: 0
Reaction Parameter: 0
Initial Average Activity: 0
Initial Global Complexity Measure - I Frame: 0
Initial Global Complexity Measure - P Frame: 0
Initial Global Complexity Measure - B Frame: 0
Initial Virtual Buffer Fullness - I Frame: 0
Initial Virtual Buffer Fullness - P Frame: 0
Initial Virtual Buffer Fullness - B Frame: 0
P Frame Motion Vectors - Forward Search Width: 127
P Frame Motion Vectors - Forward Search Height: 127
B Frame1 - Forward Search Width: 59
B Frame1 - Forward Search Height: 48
B Frame1 - Backward Search Width: 118
B Frame1 - Backward Search Height: 96
B Frame2 - Forward Search Width: 118
B Frame2 - Forward Search Height: 96
B Frame2 - Backward Search Width: 59
B Frame2 - Backward Search Height: 48
Deinterlacing: Enabled
Motion Estimation Type: 11
Do Half Pel Search: On
Online Encoding: Offline
Encoding Level: 31
Automatic GOP placement: Off
Audio Summary:
Codec: MainConcept MPEG Audio
Audio Format: MPEG-1 Layer II Audio
Audio Mode: Stereo
Psych Mode: Psychoacoustic model 2
Bitrate (kbps): 224
Sample Rate: 48 kHz
De-emphasis: No emphasis
Enable CRC: Off
Set private bit: Off
Set copyright bit: Off
Set original bit: Off
Multiplexer Summary:
Multiplexing Type: MPEG-2
Bitrate Type: Constant
Packet Size (bytes): 2048
Packets per Pack: 1
Sectors Delay (ms): 0
Video Delay (ms): 180
Audio Delay (ms): 180
Video Buffer Size (kB): 0
Audio Buffer Size (kB): 4
Mux Rate (kbps): 0
Max file size (MB): 0
Pulldown: Auto
Frame Time stamp: All frames
Write Program end code: On
Align Sequence Header: Off
Let's get computin'
waters ::
Podobno sem jaz že pred časom hotel izvedeti za Pinnacle studio, Ulead DVD workshop in CCE, pa so bli vsi tiho.
Kot da vsi tekmujejo kdo bo spravil več na disk, ne pa da jih zanima kvaliteta.
bochow89 ::
ja, prav maš waters. js sn pa mislu da so na slo-techu sami pametnjaki:\
Let's get computin'
kosobrin ::
Pozdrav!
Tudi jaz imam podobne težave v Ulead VideoStudio 8 SE DVD. Že veste morda kaj novega?
Naj kdo prosim razloži oz pove kam po praktične informacije.
Lep pozdrav.
miha80 ::
tole se mi zdi odločno preveč.
drugače pa uporabljaj preset-e. probaj, zapeči DVD+-RW in poglej, če ti odgovarja kvaliteta. Probaj nastaviti parametre za Bitrate, da ti gre na cel DVD dve uri videa. To je "Standard quality".
Sicer pa ima Adobe Premiere 1.5 PRO (verjetno tudi 1.0) opcijo "export to DVD" ali nekaj podobnega.
jaz doma delam tako: v premieru zmontiram zadevo, potem pa celoten projekt eksportiram v en sam DV-AVI file, ki ga potem uvovim v Adobe ENCORE. tam pa potem naredim authoring.
deinterlacinga ne uporabljam, ker pač delam stvari, ki naj bi se gledale na DVD playerju na televiziji. ta opcija je pa nekje pri Export nastavitvah.
There is no spoon
Občasno štekanje pri predvajanju preko HDMI
Oddelek: Zvok in slika
474246 (3202) sejmon
Mpeg4ModifierMod
415923 (3676) podtalje
packed bistream??
81416 (1345) =RS=
Hitrost kodiranja - XviD, DivX
61856 (1700) podtalje
V XivD
92314 (2019) gumby
