Kaj je to dubbing?
Kaj je to dubbing?
Storm ::
Pri enem DVD predvajalniku sem zasledil funkicjo 64x high speed dubbing. Kaj je to, kako temu rečemo po slovensko?
Markec The Great
  • spremenil: Storm ()
CaqKa ::
načeloma nisem najbolj razumel konteksta..
vem da je imel moj dvokasetar možnost 2x dubinga, kar je pomenlo da je kaseto presnel dvakrat hitreje.
sicer pa define:dubbing
Lith ::
točno tole:
The technique of combining multiple sound components into one. Can also refer to automatic dialog replacement of another language. DVD (Digital Video Disk or Digital Versatile Disk) - An emerging medium for storing large amounts of digital data, most notably movies encoded using MPEG-2 compression (a CODEC designed especially for use with DVDs). DVDs can hold several gigabytes on a single disc. Most CDs by contrast can only hold 600 megabytes each.
¤ black holes rule; I like the speed, speed kills ¤
Tv-tuner server
Oddelek: Programska oprema
51278 (1182) Raw
Lg hdd/dvd recorder rh 7900
Oddelek: Zvok in slika
62267 (2182) plamen
kaj je boljse dvd-r/dvd+r in pri tem dvd-rw/+rw
62196 (2040) krneki
Prvi DVD zapisovalnik, ki je cenejši od 100$
Oddelek: Novice / Optične enote / mediji
123324 (3324) freejack
Dolby 5.1
363866 (3414) ciper
