predvajanje avi datotek v firefoxu
zigi ::
Zdravo,
imam en html fajl s to kodo:
<embed type="application/x-mplayer2" pluginspage="http://www.microsoft.com/Windows/MediaP... src="madmax.avi" width="240" height="252" autostart="0" showcontrols="1" showstatusbar="1"></embed>
V firefoxu se mi lepo prikaže okence WMP-ja, ko pa dam play, se ne zgodi nič. Če kliknem z desno in dam "Error Details", mi napiše to:
Windows Media Player cannot play the file. If the file is on another computer, verify that you are connected to the network. If you typed a path, verify that it is correct. If the problem persists, the server might not be available.
madmax.avi je v isti mapi kot ta html dokument.
Imam pa firefox 1.0.2, WMP 10 in vse plugine za FF
  • spremenil: zigi ()
direct3D
91456 (1370) Mikron
DMI pool data
Oddelek: Operacijski sistemi
62098 (1971) cryptozaver
Router?
111408 (1174) cisco
problemi pri divxih
Oddelek: Sedem umetnosti
81775 (1606) fictionel
Micro$oft proti piratstvu
61286 (1126) zetko
