Forum » Operacijski sistemi » Remote Desktop
Remote Desktop
bojan1 ::
Zdravo!
Imam en problem. Imam server Win 2003, na njega preko crossoverja povezan notesnik. Zdej, ko pa dostopam preko Remota, lahko pridem samo do serverja. Do notesnika pa ne morem dostopati. Port sem že forwardiru, zanima me pa kje se nastavi na notesniku ta port, da ga uporablja pol Remote?
Hvala za pomoč
Hvala za pomoč
Hašbuba
Slowenc ::
Po moje da moraš ti port nastavit v programu samem. Ko te vpraša za ip, te mora zraven še za port. Drugače pa probaj recimo 194.2.3.4:5000
Ta 5000 je port.
Ta 5000 je port.
Skiny gate.
urarrr ::
na mašina lahko spremeniš na katerem portu posluša oddaljeno namizje. ponavadi je 3389.
oz.
You can use the Remote Desktop feature in Windows XP Professional to connect to your computer from another, remote computer. WARNING: The Remote Assistance feature in Windows XP may not work properly if you change the listening port. To change the port that Remote Desktop listens on:
Start Registry Editor (Regedt32.exe).
Locate the following key in the registry:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\TerminalServer\WinStations\RDP-Tcp\PortNumber
On the Edit menu, click Modify, click Decimal, type the new port number, and then click OK.
Quit Registry Editor.
NOTE: When you try to connect to this computer by using the Remote Desktop connection, you must type the new port.
The information in this article applies to:
Microsoft Windows XP Professional
Microsoft Windows XP 64-Bit Edition
Microsoft Remote Desktop Connection Client for Windows 1.0
Microsoft Remote Desktop Connection Client for Mac 1.0
oz.
LP Urarrr
| » | oddaljeno namizjeOddelek: Pomoč in nasveti | 4273 (2514) | iloveboobz |
| » | Remote Desktop, nastavitevOddelek: Omrežja in internet | 8517 (5391) | fosil |
| » | Remote desktop v XP SP3Oddelek: Pomoč in nasveti | 2904 (1974) | neres |
| » | VPN med 2x WinXP?Oddelek: Omrežja in internet | 2605 (2283) | luciby |
| » | omejevanje RemoteDesktop-aOddelek: Programska oprema | 1525 (1410) | CaqKa |
