Anemanje filma v quaki
CWIZO ::
A mi lahko eden hitro (res se mudi) pove kako posnamem film svojega igranja v quaki 3 ?
Recimo ko igraš da vse posnameš in pol loh to kasneje gledaš. To vem da se da ker mam ene muvije tko narejene iz enih lanoc pa to.
Pa res če loh čim orej :D:D:))0:)>:D
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
smuk ::
Hm, tisto ni noben muvi ampak je demo:))
Senemanje ni tezko...
/record name
/stoprecord
Tako gre to.. tudi jaz dostkrat snemam demote... in imam za to skripto8-)
Priporocam ti, da si to skripto prekopiras v q3config.cfg (najdes ga v baseq3)
seta demo0 "g_synchronousclients 1; record demo0; g_synchronousclients 0; bind HOME vstr demo1"
seta demo1 "g_synchronousclients 1; record demo1; g_synchronousclients 0; bind HOME vstr demo2"
seta demo2 "g_synchronousclients 1; record demo2; g_synchronousclients 0; bind HOME vstr demo3"
seta demo3 "g_synchronousclients 1; record demo3; g_synchronousclients 0; bind HOME vstr demo4"
seta demo4 "g_synchronousclients 1; record demo4; g_synchronousclients 0; bind HOME vstr demo5"
seta demo5 "g_synchronousclients 1; record demo5; g_synchronousclients 0; bind HOME vstr demo6"
seta demo6 "g_synchronousclients 1; record demo6; g_synchronousclients 0; bind HOME vstr demo7"
seta demo7 "g_synchronousclients 1; record demo7; g_synchronousclients 0; bind HOME vstr demo8"
seta demo8 "g_synchronousclients 1; record demo8; g_synchronousclients 0; bind HOME vstr demo9"
seta demo9 "g_synchronousclients 1; record demo9; g_synchronousclients 0; bind HOME vstr demo0"
bind END stoprecord
Torej z HOME zacnes snemat demo in z END ga koncas.;)
CWIZO ::
OK demo
Se pravi moram dat backslash uspredi ?
a tam k je pa name pa npišem ime datoteke lai pustim?
Pa tist za config. Kam pa vnesem titole k si ti spodaj napisal ? al na konec vsega kar je tam napisano ali kam ?
pa pol če to skripto vnesem sam home napišem in s bo snemal ?
hancic.info
smuk ::
Ne ne ne :)
V q3 je tak, da mors dat pred vsako komando /
Pri name, pac das svojo ime, kero pac hoces...(demo lahko potem najdes v mapi quake3\baseq3\demos)
Glede one skripte, pa jo das samo na konec dokumenta (configa) q3config.cfg
Potem zacnes demo snemat tako, da pritisnes tipko HOME (nad smernimi puscicami) in snemanje koncas tako, da pritisnes END. :)
CWIZO ::
Kero ime se pa potem dodeli?
Sem probu tko de sem dal /record blabalbal
pa mi je pol napisal da neki server ne dela. sem pol tist naštimu in mi jde delal.
Ok bom to skupiral pa bom probu
hancic.info
CWIZO ::
Sem vse tistle skopral na konec tistga cfg file pa mi ni delal !
A obstaja kšn programič da pol to obdeluješ loh te demote?
Aja iz kermu programom pa loh gledaš une file recimo intro pa end pa Tier3 pa to ? Vem de amš tm pod cimetamtic sam jest bi rad jih tko gledal.:D
hancic.info
smuk ::
Vrjetno nisi prav skopiral..
to vse je v eni vrstici (nisem mogel vse v 1 vrstico spravit:)))
Drugace pa mas tudi program GeekPlay za gledanje demotov.
Da bi pa obstajal kak program, s katerim bi gledal one filme od Tierov, pa ne da bi vedo.
CWIZO ::
Se prav vse tist k si ti tam napisu (Bl navrh) moram tko dat da bo v eni vrstici z enmu presledkam razmaka?
hancic.info
Quake IV - Multiplayer (strani: 1 2 3 )
Oddelek: Igre
12111189 (7963) ERGY
Quake III - Rail problem
Oddelek: Igre
342306 (1844) bf4ed
FPS pri quake3
132056 (1869) Enzo77
Quake 2 bindanje
Oddelek: Igre
101318 (1178) Quickbeam
Demo scena
Oddelek: Novice / --Nerazporejeno--
72718 (2718) Justy
