Forum » Pomoč in nasveti » Prazen Device Manager WinXP ?????
Igor0 ::
Živjo,
kam so se izgubile naprave. Ko odprem Device Manager se odpre, polje pa je prazno !!??!!.
kar naenkrat se je to zgodilo. Kako naj povrnem naprave v upravitelja.
NUJNO !!!!
Lp Igor
NUJNO !!!!
Lp Igor
Igor0 ::
Med mnogimi odgovori na netu, ki so samo nakladanje, sem po dveh dneh našel pravega.
Se ne spomnim linka, bom kar prilepil rešitev :
Empty Device Manager
"The issue is security permissions in the registry. I cannot tell how they are lost
but I can tell you how to fix it short of having to re-install Windows!
You must use regedt32.exe in Windows 2000/XP (as I have not seen this problem posted
for any other operating system). Be very carefull making changes in the regisrty!
You must be logged on as a local administrator to perform this task:
1. Go to "Start", "Run", and enter "regedt32"
2. Maximize the "HKEY_LOCAL_MACHINE" window.
3. Scroll down to "SYSTEM\CurrentControlSet\Enum"
4. With "Enum" selected click the "Security", "Permissions" menu.
Note: At this point you will probably notice there are no permissions on this key.
5. Click "Add".
6. Add the group "Everyone" and the user "SYSTEM".
7. Select "Everyone" and check "Read" ONLY!
8. Select "SYSTEM" and check "Full Control".
9. Click the "Advanced" button at the bottom of the window.
10. On the Advanced window check "Reset permissions on all child objects..."
11. Click "OK"
12. On the warning window click "Yes"
13. Close REGEDT32
Moprda komu prav pride !!!
Lp Igor
5. Click "Add".
11. Click "OK"
13. Close REGEDT32
Lp Igor
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3704 (3094) | fr!Xy |
| » | Optiarc DVD RW AD-5170AOddelek: Pomoč in nasveti | 1198 (1135) | Han |
| » | Disk 200GB je v winsih samo 128GB?Oddelek: Pomoč in nasveti | 1532 (1416) | danielka84 |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2600 (2196) | Swiwer |
| » | winXP tezavaOddelek: Operacijski sistemi | 1245 (1024) | ToniT |
