Program za predogled in tiskanje *.CDR datotek
b0B3k ::
Zanima me, če kdo pozna kak manjši software, s katerim bi lahko pogledal *.CDR sliko in jo med drugim tudi natisnil?
P.S.
Da mi ne bi bilo treba nameščat Corel Draw-ja.
harvey ::
Za silo lahko importiraš v Word, če imaš nameščen filter. Samo to je tako tako, spodaj piše katere verzije CoreDRAWja podpira wordow filter.
The CorelDRAW graphics filter (Cdrimp32.flt) supports .cdr, .cdt, .cmx, and .pat files from CorelDRAW 3.0, 4.0, 5.0, 6.0, and 9.0. The CorelDRAW graphics filter (Cdrimp32.flt) supports .cdr, .cdt, .cmx, and .pat files from CorelDRAW 3.0, 4.0, 5.0, 6.0, and 9.0.
This filter has the following limitations:
Object and PostScript texture fills are replaced with solid gray fills.
Gradient fills are split into monocolored stripes.
There is no support for:
CorelDRAW preferences, such as page size and orientation, units, grid, and guidelines.
Lenses and powerclips.
Pages, layers, and groups.
OLE objects.
Rotated bitmaps.
Vector fills.
Multiarea paragraph text.
  • spremenil: harvey ()
"masovna" pretvorba CorelDraw verzije 17 na 16?
Oddelek: Programska oprema
101287 (1033) SeMiNeSanja
Pregledovalnik corel draw datotek (*.cdr)
72475 (2377) JacqueS
Izšla nova različica Inkscapa
347733 (5731) CaqKa
Pisava CE in Corel 11
51498 (1439) reber
Izdelava letaka / časopisa / dnevnika?
83207 (3086) kuglvinkl
