Forum » Pomoč in nasveti » CSRSS.exe
CSRSS.exe
Apyon ::
Kaj je narobe če ti aplikacija CSRSS.exe zavzema cel ram? A je to virus in kako se ga znebiš. K adware pa te, ga ne zaznajo. Če se je kdo spopadu stem naj prosm odgovori.
TNX!
TNX!
Pujcek ::
v dosu zalaufi netstat -a in povej ce mas port 2288 al pa kej tacga na listening??? ce mas pol si fasu eno jebo k jo je tezko dol dat...
pomaranca ::
http://www.liutilities.com/products/wintaskspro/processlibrary/csrss/
...Note: csrss.exe is also process which is registered as the W32.Netsky.AB@mm worm, the W32.Webus Trojan, Win32.Ladex.a and more. This virus is distributed via the Internet through e-mail and comes in the form of an e-mail message, in the hopes that you open it’s hostile attachment. The worm has it’s own SMTP engine which means it gathers E-mails from your local computer and re-distributes itself. In worst cases this worm can allow attackers to access your computer, stealing passwords and personal data. It is a registered security risk and should be removed immediately. Please see additional details regarding this process...
Slowenc ::
Najbolj učinkovita ideja je format c:
Drugače pa, verjetno obstaja kakšno orodje, ki ti odstrani to nadlogo.
Skiny gate.
Pujcek ::
po mojih izkusnjah bos prej al slej dubu en kup spyware programov na komp. bi ti pa mogu norton av nekaj najdet... men je v koncni fazi en ftp gor hotu zalaufat tko da sem na zonealarmu vidu da je neki narobe. je pa tko, da pickarije nisem mogu nikakor dol dobit. format je dogajal...
http://www.anti-spy.info/
snami tole pa poglej keri procesi ti laufajo... ce ti kej pomaga!
pa velik srece!
pujcek
pa velik srece!
pujcek
| » | Preveč pomnilnika pobere??Oddelek: Operacijski sistemi | 1220 (1074) | vice boy |
| » | svchost in 100% obremenitev cpuOddelek: Pomoč in nasveti | 2693 (2220) | Microsoft |
| » | Težave!! (Grafična kartica ati r9200,...)Oddelek: Pomoč in nasveti | 1623 (1462) | Fly.MaCh!nE |
| » | procesi ??Oddelek: Pomoč in nasveti | 1458 (1259) | dux |
| » | Neznani programi ?Oddelek: Pomoč in nasveti | 1598 (1398) | mihhec |
