Kako NE!! sestavljati računalnik
Jaz - Odličen članek o sestavljanju, oziroma nesestavljanju računalnikov, so pripravili pri HardwareCentral. Ob vsej debati o sestavljanju in modificiranju računal tule na slo-techovem forumu, se bo najbrž marsikak nadebudnež polotil svoje strojne opreme na lastno pest. Svetujem, da si pred morebitnim posegom v drobovje računalnika obvezno preberete tale zelo poučen članek. Seveda pa moram dodati: "vsi posegi so na lastno odgovornost!"
1 komentar
matevzm ::
http://members.aol.com/spoons1000/break/
Ker ravno kopiram stvari z diska, ki bo crknil, mije bil vsec del:
This is a low-level calibration of the drive, done with the hammer from figure 4.2. Note that the unreliable areas of the drive surface which were marked as "bad sectors". Also note that the drive is stubbornly resistant to calibration.
Figure 4.4 shows partitioning of the drive using an ordinary hacksaw. Partitioning in this manner is advantageous over fdisk because it allows partitioning of individual platters and is independent of operating system. You also get to make cute designs.
posodobitev pc-ja
322988 (2670) Pro_moted
menjava procesorja
71590 (1284) nonenone
A si je že kdo sam sestavil (zmontiral) računalnik?
242184 (1558) opeter
Nakup po kosih ali komplet?
121894 (1751) JustVi
Kako postaviti lasten strežnik
Oddelek: Novice / Obvestila
124267 (4267) luni
