Duke Nukem: Forever
Duke Nukem: Forever
Senitel ::
Ej a ste vidl un predstavitveni filemček? Men zadeva diši po Unreal 2 pogonu :P.
Pretorijanec ::
Ne... A daš link?:D
Dr.Miha ::
hm....men pa ne.....
Face niti pod razno niso tko dodelane kukr sm jih viduiz Unreala 2.
Duke nukem forever bo uproabljal (izboljšani) pogon iz Unreal Tournamenta.
Za domovino z Nintendom naprej!
Senitel ::
Pretorijanec: Tuki
Dr.Miha: To kolk so face dodelane nima veze ker engine je, ampak kolk so artisti pridni (kolk dajo trikotnikov). Ampak eko enih par takih factov:
-zunanje scene (vožnja z džipom,...), take scene so precej zahtevne tako za engine-e, kot tudi za grafične, in engine v Unreal Tournament-u ni ravno dobro prebavljal takih scen.
-animacije (predvsem "facial animation") so na dosti višjem nivoju kot v Unreal Tournamentu.
Pa engine-a nemorejo kar tko izboljšat, ker bi pol rabil zraven kompleten source od engine-a. Pa tudi Tim Sweeney je rekel (samo), da imajo dostop do najnovejše tehnologije...
Sicer pa živi bili pa videli >:D.
||_^_|| ::
filmček rulez...sam neki mi prav da bom mogu novo grafično nabavt za ta špil:))
Dr.Miha ::
to je potegnjeno dol zLink.
Duke Nukem Forever: Engine
Duke Nukem Forever (DNF) will be using a heavily modified version of the Unreal Engine by Epic Megagames for the most realistic game ever. First planned to use the Quake 2 engine, 3D Realms decided to go with the Unreal engine as a business decision for what they wanted DNF to become.
Many modifications will be added to the engine. First of all, 3D Realms has introduced a new "Skeletal System" for animation. This means that models for the game can be created more easily and much quicker with cleaner more extensive animation's. This also means that more than one animation can be performed by one model at one time, i.e. Jumping and firing at the same time. Characters heads will also be able to track you as you move around them.
3D Realms have licensed Sven Technology's MRG technology for LOD to keep polygon counts at a good balance and to keep frame rate high... George Broussard said , "It saved us months of reinventing the wheel and creating our own LOD system. The benefits come from dealing with less polygons that you have too. And the perceived poly drops in the meshes is negligible. I think everyone agrees that frame rate is more important than keeping a model at full poly count when it's 1 inch tall on the screen."
DNF will be able to display in-game AVI's as "textures", i.e. Movie Screens. When asked on the 3D Realms BB about this topic George Broussard replied: "Heh, we've had that in for months ."
DNF has now moved to use the Unreal Tournament engine which will improve net play, graphics, interface, and stability of the final game. Although it has taken 3-4 week to change over the code from Unreal to UT the final gain in time will be about 5-6 months.
Fog and various other weather effect have been introduced to DNF. It is known the fog in Unreal was pretty but slow, this has been changed. Charlie Weiderhold has this to say on the subject. "There is fog (not just Unreal's beautiful but slow volumetric fog, but also the blazingly fast hardware fog that most games have now). We tend to use it in a more realistic manner though, so it doesn't show through as much in the shots. It adds a huge sense of atmosphere, like there actually is air in the world... and that's what it is there for. It's pretty thick in the club, but that's what happens when everyone is smoking. :)
As for other weather type effects, lots planned... dunno what will make the final cut into the game."
So far know one really knows what kind of powerhouse machine it will take to run DNF, but in an interview in November 1999 George Broussard said: "You can get your specs from Unreal Tournament. But we expect a realistic system (one that would make it fun) to be: 128 megs, Voodoo 3/TNT 2, and P400 or so. It would certainly play on less, but performance would start to become an issue." To get a better idea of the system spec that could be needed as a minimum to get the game off the ground we can look at Unreal's minimum specs:
CPU: 233 MHz Pentium
RAM: 32 MB minimum, 64 MB SDRAM recommended
Distribution Media Drive: CD-ROM drive
Video System: PCI Local Bus Video Card
Audio System: Windows 95/98 compatible sound card
Operating System: Windows 95/98/NT/2000
Network and Internet Setup: 28.8 kbps or higher modem using TCP/IP
Now finally to the issue of a 3D Accelerator. Will one be needed? We haven't really had an official word yet, but as far as we know, YES you will need a good card along the lines of a Voodoo3/TNT2.
System Specs
The final system specs for Duke Nukem Forever have not been released as of yet, we can only make an estimation as to what they will be. Our only suggestion is to follow the guidelines that Unreal and Unreal Tournament use since Duke Nukem Forever will be using the same engine. The basic specs to go by are listed below:
CPU: 500 MHz Pentium
RAM: 64 MB minimum, 128+ MB SDRAM recommended
Video System: PCI Local Bus Video Card (3D card required)
Dami ::
A od Unreala 1 bo srce? Eh, predn bo špil vun pršu (če bo sploh kr to zavlačevanje je že bedasto) bo že Unreal2 udzun. Mal kasnej pa še UT2...aaahhh, slin:D
duke nuke forever ??
Oddelek: Igre
213055 (1285) opeter
Duke Nukem Forever (strani: 1 2 3 4 … 12 13 14 15 )
Oddelek: Igre
742118505 (36168) Testman42
Bombshell (Duke Nukem: Mass Destruction ?)
Oddelek: Igre
123133 (2344) Zmajc
3D Realms šli rakom žvižgat, Duke Nukem Forever tudi (strani: 1 2 )
9214503 (8839) T-Majo
3D Realms & Duke Nukem Forever = No More
Oddelek: Igre
152264 (1726) ahac
