Forum » Navijanje » Sandra 04 - Cache&Memory overall test results; kakšen je vaš?
Mavr0 ::
SiSoftware Sandra 2004
Benchmark Results
KAKŠNE SO VAŠE VREDNOSTI??TUKAJ:
Combined Index : 9928MB/s
Speed Factor : 11.5
2kB Blocks : 28468MB/s
4kB Blocks : 26783MB/s
8kB Blocks : 26684MB/s
16kB Blocks : 24524MB/s
32kB Blocks : 20753MB/s
64kB Blocks : 21109MB/s
128kB Blocks : 21557MB/s
256kB Blocks : 21338MB/s
512kB Blocks : 20495MB/s
1MB Blocks : 18164MB/s
4MB Blocks : 2508MB/s
16MB Blocks : 2493MB/s
64MB Blocks : 2483MB/s
256MB Blocks : 2487MB/s
Float SSE2 Cache/Memory Results Breakdown
Data Item Size : 16-bytes
Buffering Used : No
Offset Displacement Used : Yes
Performance Test Status
Run ID : P4-RADEON on 26. december 2004 at 21:23:46
NUMA Support : No
SMP Test : No
Total Test Threads : 1
SMT Test : Yes
Number of Test SMT (per CPU) : 2
Dynamic MP/MT Load Balance : No
Processor Affinity : P0
Page Size : 4kB
Use Large Memory Pages : No
Processor
Model : Intel® Pentium® 4 CPU 3.00GHz
Speed : 3.02GHz
Performance Rating : PR4010 (estimated)
Type : Standard
Internal Data Cache : 16kB Synchronous Write-Thru (8-way, 64 byte line size)
L2 On-board Cache : 1024kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Features
SSE Technology : Yes
SSE2 Technology : Yes
SSE3 Technology : Yes
HTT - Hyper-Threading Technology : Yes
Chipset 1
Model : Giga-Byte Technology 915G Grantsdale CPU to I/O Controller
Front Side Bus Speed : 4x 201MHz (804MHz data rate)
Width : 64-bit
Maximum Bus Bandwidth : 6432MB/s (estimated)
Logical/Chipset 1 Memory Banks
Bank 2 : 256MB DDR-SDRAM 2.5-4-4-8CL 1CMD
Bank 3 : 256MB DDR-SDRAM 2.5-4-4-8CL 1CMD
Bank 6 : 256MB DDR-SDRAM 2.5-4-4-8CL 1CMD
Bank 7 : 256MB DDR-SDRAM 2.5-4-4-8CL 1CMD
Channels : 2
Width : 64-bit
Performance Acceleration Technology : No
Benchmark Results
Speed Factor : 11.5
Buffering Used : No
NUMA Support : No
SMP Test : No
SMT Test : Yes
Page Size : 4kB
Processor
Speed : 3.02GHz
Type : Standard
Features
Chipset 1
Width : 64-bit
Channels : 2
Width : 64-bit
- spremenil: Mavr0 ()
Spajky ::
Za brzino memorije kumulativno v real life uporabi WinRAR3.3ali višji (štartaš test s Alt+B ; tvoj rezultat bi naj bil okoli 430 točk). A mi lahko poveš tudi PR rating tvojga proca v Sandra2001proprosim? [raspakiraj in (če treba uvozi reg ključ in) startaj jo, 459kB, ni instala! - oskubljena!]
Mavr0 ::
Am kaj nihče ni testiral kaj sistema na Cache & Memory test v Sandri 2004??
Dajte malo posredovat teste...sploh AMD platforme...
Tx;
Matej
Tx;
Matej
| » | Kateri CPU mate in utemeljite zakaj? (strani: 1 2 3 4 5 )Oddelek: Strojna oprema | 29892 (21672) | 54j0 |
| » | ali imam quad q9300?Oddelek: Strojna oprema | 2535 (2164) | gendale |
| » | Memory testOddelek: Strojna oprema | 2217 (2058) | tonex23 |
| » | Navijanje celerona DOddelek: Navijanje | 1734 (1644) | SavoKovac |
| » | Igre zamrznejo računalnik, zvok gre na mini loop ali na ton, slika freezne !Oddelek: Pomoč in nasveti | 1777 (1741) | delfinus |
