Forum » Pomoč in nasveti » Nastavitev IE za več kot dva dolpotega
harvey ::
Tole lahko pomaga.
Description
In IE, by default, a user can only download two files at once. Here's how to increase this.
Directions
Because of some silly standards, IE limits the number of files that can be downloaded at once to two. In the world of broadband, this is just not enough. Here's how to increase it.
This requires editing the registry. Backup your system beforehand.
1. Click Start
2. Click Run
3. Enter regedit into the textbox and click OK
4. In regedit go to the following key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
5. Click the Edit Menu
6. Select New and DWORD value
7. Name your selection MaxConnectionsPer1_0Server and hit ENTER
8. Double click MaxConnectionsPer1_0Server
9. When the box opens change the value to a.
10. Click the Edit Menu again
11. Select New and DWORD value
12. Name your selection MaxConnectionsPerServerand hit ENTER
8. Double click MaxConnectionsPerServer
10. Quit regedit
This changes it to a maximum of 10 (hex a) downloads at once.
Further reference:
http://support.microsoft.com/?kbid=2824...
Description
Directions
1. Click Start
2. Click Run
10. Quit regedit
Further reference:
| » | Matične plošče za Windows 7Oddelek: Strojna oprema | 4833 (3868) | Pac-Man |
| » | Kako pohitriti FireFoxOddelek: Pomoč in nasveti | 5061 (4772) | Bakunin |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2524 (2490) | Mercier |
| » | router dela na nekih url jih samo polovičnoOddelek: Pomoč in nasveti | 2038 (1854) | Medo_m |
| » | edonkey2000Oddelek: Omrežja in internet | 1915 (1530) | Mr.Joker |
