Forum » Pomoč in nasveti » Zakaj ugaša COMP ko zaženem nekatere igre?
denalom ::
Zanima me zakaj ugaša računalnik, ko zaženem igro (Axis & Allies, NBA 2005, Medal of Honor Pacific Assault,...).
Igro zaženem z programom Deamon tools in mi računalnik avtomatsko resetira.Imam-AMD Athlon 3.0+, 512 DDR RAM, ATI Radeon 9200 SE (najnovejši gonilniki), kar zadošča za igre. Imam naložene programe: NOD 32, Zone Alarm (oba posodobljena).
to se izpiše ko se pojavi napaka:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you´ve seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to be sure you have adeguate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for drivers updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates. Disable BIOS memory suchas caching or shadowing. If you need to use safe mode to remove or disable components, restar your computer, press F8 to select Advanced Startup options, and then select safe mode.
Technical information:
*** STOP: 0x0000008E (0xCoooooo5, 0x000002E4, 0xBA697CC8, 0x00000000)
PROSIM ZA POMOČ!!
PROSIM ZA POMOČ!!
"Kako se je Bill Gates domislil imena za firmo ?"
"Preveril je svoj penis: Micro & Soft . . ."
msms ::
Izklopi enable write combining.
Display properties-setting-advanced-trobleshoot tam izklopiš "enable write combining"
Lith ::
še več pa piše stric Google http://www.google.com/search?hl=en&lr=&q=STOP%3A+0x0000008E+&btnG=Search
¤ black holes rule; I like the speed, speed kills ¤
| » | Problemi...Oddelek: Pomoč in nasveti | 2480 (1810) | Cifix63 |
| » | samodejni vklop in izklop računalnikaOddelek: Pomoč in nasveti | 2892 (2716) | RuskiSnajper |
| » | plata zjebava z modrim zaslonom smrti !!!Oddelek: Pomoč in nasveti | 1851 (1638) | SavoS |
| » | Resne težave s Win XP!!?Oddelek: Pomoč in nasveti | 2363 (1848) | alyF |
| » | nasvet za XPOddelek: Pomoč in nasveti | 4283 (3875) | [t502] |
