A mam virus ali ne ;(
iBojan ::
Star računalnik (486/100MHz/8MB) sem si preuredil za igranje igric pa sem si pred nekaj časa naložl še QEMM 8.0 in tedaj so se pojavile težave. Ko grem pa pogledam z F-PROT ali imam kak virus mi javi, da imam The One_Half.35xx.C virus has been found in memory. ;( Pa da naj zaženem računalnik z clean disketo pa zbrišem pa bo. Potem pa to naredim, pregledam računalnik pa vrusa več ni ;( Ni ga v nobeni datoteki pa niti v memory. Ali je možno, da me kaj zaj*** QEMM ali kaj bi lahko bilo narobe ??
lp, _GeS_
Can ::
Sophos antivirus priporoča tako odstranitev:
Aliases: LEAVE
Infects: COM and EXE files, Master boot sectors
Memory resident: Yes
A virus reminiscent of Commander Bomber in the way that it infects files. It gradually encrypts the contents of the hard disk, decrypting them on the fly. If the virus is simply removed from the boot sector, encrypted data will be lost. To remove the virus, backup the data first while the virus is active (the virus does not infect floppy boot sectors), repartition the disk using FDISK, use FDISK /MBR to remove the virus from the master boot sector, reformat the disk using FORMAT and restore the data. Infected COM and EXE files should be deleted and restored from master copies.
First reported in september 1994.
ABX ::
Virus gor ali dol, ti uni qemm vrži v smeti ker povzroča samo pizdarije.
Če imaš probleme z starimi igrami in XMS/EMS memory uporabljaj emm386 (upam da se tako kliče ker je šlo preveč časa mimo) funkcijo pod config.sys.
Diagnostično orodje za WD
Oddelek: Programska oprema
145037 (4897) clovk
lilo boot loader problem
Oddelek: Operacijski sistemi
152441 (2073) Michael7
seatools
202381 (2226) StratOS
Končno. Na mojem računalniku z linuxom sem odkril virus.
161881 (1595) suse80
100%Cpe + ostalo
112802 (2472) postar_si
