Forum » Operacijski sistemi » SuSE 9.1 - "Manjši" problemi
PARTyZAN ::
Ko inštaliram nvidiine driverje za NF3 chipset (mrežna) je vse lepo in prav. Ko pa posodobim SuSE preko YaST pa driverji ne delajo več (modprobe.conf sem ponovno odkomentiral nvnet...modprobe nvnet ne prime -> modul naj nebi obstajal)...niti ponovno inštalirat jih ne morem (Kernel-source naj se nebi ujemal z tem kernelom ki ga uporabljam)...čeprav sem pri updatu pobral oboje (in nov kernel in kernel-source)
uname -r mi vrne 2.6.5-7.108-default, bljižnica v /usr/src (linux) kaže pa na linux-2.6.5-7.108 Ideje?
der_Alte ::
Če si z YOU posodobil jedro in si imel tudi izvorno kodo jedra nameščeno, je YOU posodobil tudi to. Potrebuješ izvorno kodo NForce gonilnikov, da se bo modul pravilno prevedel. Vzemi src.rpm in rebuildaj.
PARTyZAN ::
Kernel ki ga vrne uname -a sem našel v /lib/modules/2.6.5-7.95-default. Zadevo sem linkal (ln -s /lib/modules/2.6.5-7.95-default v /usr/src/linux)
Ampak zadeva še vedno ne dela:
nforce-installer log file '/var/log/nvidia-nforce-installer.log'
creation time: Mon Sep 27 14:41:02 2004
option status:
license pre-accepted : false
expert : false
uninstall : false
driver info : false
no precompiled interface : false
no ncurses color : false
no questions : false
silent : false
Installer install prefix : /usr
kernel source path : (not specified)
net kernel install path : (not specified)
audio kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA audio driver for Linux-x86
-> Found package NVIDIA network driver for Linux-x86
-> Please select packages for installation:
Selections:
NVIDIA network driver for Linux-x86 (1.0-9)
-> Starting install of NVIDIA network driver for Linux-x86
-> Checking for loaded module nvnet
-> Checking for loaded module forcedeth
-> License accepted.
-> Skipping check for conflicting rpms.
-> There appears to already be a network driver installed on your system (versi
on: 1.0-9). As part of installing this driver (version: 1.0-9), the existin
g driver will be uninstalled. Are you sure you want to continue? ('no' will
abort installation) (Answer: Yes)
-> /proc/version is Linux version 2.6.5-7.95-default (geeko@buildhost) (gcc
version 3.3.3 (SuSE Linux)) #1 Thu Jul 1 15:23:45 UTC 2004
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
ERROR: The kernel header file
'/lib/modules/2.6.5-7.95-default/build/include/linux/kernel.h' does not
exist. The most likely reason for this is that the kernel source path
'/lib/modules/2.6.5-7.95-default/build' is incorrect. Please make sure
you have installed the kernel source files for your kernel; on Red Hat
Linux systems, for example, be sure you have the 'kernel-source' rpm
installed. If you know the correct kernel source files are installed,
you may specify the kernel source path with the '--kernel-source-path'
commandline option.
ERROR: Installation of the network driver has failed. Please see the file
'/var/log/nvidia-nforce-installer.log' for details. You may find
suggestions on fixing installation problems in the README available on
the Linux driver download page at www.nvidia.com.
option status:
expert : false
uninstall : false
driver info : false
silent : false
tmpdir : /tmp
Selections:
commandline option.
| » | Stranded in console [opensuse linux]Oddelek: Operacijski sistemi | 1822 (1532) | rdecaluc |
| » | Skoraj že obupal pri inštalaciji LinuxaOddelek: Operacijski sistemi | 1785 (1604) | Brane2 |
| » | Linux vprašanjaOddelek: Operacijski sistemi | 3259 (2492) | BigWhale |
| » | NVIDIA gonilnik za LinixOddelek: Operacijski sistemi | 1732 (1603) | borchi |
| » | RPM installation ERRORS ?!Oddelek: Operacijski sistemi | 1547 (1478) | SasoS |
