Forum » Operacijski sistemi » env-problem v gentoo
Senzacionale ::
Mogoče kdo ve kaj bi blo tole narobe.
Vedno ko emergam kako stvar isti error oz. podoben
* The default theme has been changed to be black on white.
* You can download the old theme files at:
* http://xchat.org/files/themes/blackthem...
* Place the files into your ~/.xchat2 directory.
!!! Unexpected end of config file: variable LC_ALL
Traceback (most recent call last):
File "/usr/bin/emerge", line 2604, in ?
mydepgraph.merge(mydepgraph.altlist())
File "/usr/bin/emerge", line 1560, in merge
retval=portage.doebuild(y,"merge",myroot,self.pkgsettings,edebug)
File "/usr/lib/portage/pym/portage.py", line 2365, in doebuild
return merge(mysettings["CATEGORY"],mysettings["PF"],mysettings["D"],mysetti
ngs["BUILDDIR"]+"/build-info",myroot,mysettings,myebuild=mysettings["EBUILD"])
File "/usr/lib/portage/pym/portage.py", line 2487, in merge
return mylink.merge(pkgloc,infloc,myroot,myebuild)
File "/usr/lib/portage/pym/portage.py", line 5929, in merge
return self.treewalk(mergeroot,myroot,inforoot,myebuild,cleanup=cleanup)
File "/usr/lib/portage/pym/portage.py", line 5649, in treewalk
env_update(makelinks=0)
File "/usr/lib/portage/pym/portage.py", line 625, in env_update
myconfig=getconfig(root+"etc/env.d/"+x)
File "/usr/lib/portage/pym/portage.py", line 950, in getconfig
raise Exception("ParseError: Unexpected EOF: "+str(mycfg)+": line "+str(lex.
lineno))
Exception: ParseError: Unexpected EOF: /etc/env.d/02locale: line 15
lineno))
http://www.dostavahrane.si
borchi ::
predvidevam, da si takoj pogledal v /etc/env.d/02locale in ugotovil, da je emerge našu v njej v vstici 15 nekaj kar ni pričakoval?
l'jga
Senzacionale ::
borchi, hvala sam nisem pogledu ker nisem vidu tega.
tocno tu je bla napaka
ni blo nastavlen na sl_SI
hvala ti
hvala ti
| » | [Python] HTTPS na desktopu dela, na Arduinu neOddelek: Programiranje | 1981 (1594) | N4g4c3N |
| » | Gentoo - problemi z framebuffer in ifconfig (strani: 1 2 )Oddelek: Operacijski sistemi | 6251 (5575) | Zaibatsu |
| » | K3B problemOddelek: Operacijski sistemi | 1700 (1578) | theD3viL- |
| » | digest verification failed in gentooOddelek: Operacijski sistemi | 1363 (1291) | Senzacionale |
| » | unmergal sem gccOddelek: Operacijski sistemi | 2350 (2096) | borchi |
