Forum » Operacijski sistemi » SP2 in peka DVDjev
SP2 in peka DVDjev
Tilen ::
No danes sem prvic probal speci en DVD odkar imam nalozen SP2. Nero mi prijazno javi:
A ve kdo kaj bi blo lahko? Probal sem z DVD+R/-R in obojne zafrkava tko da mediji niso krivi. So pa tisti z Jae-ta, Verbatim.
Napise mi (kot ste videli na sliki) da kao "Drive is not ready". kaj bi lahko blo narobe?
Pa se ena cvetka iz SP2 :
lp,
Tilen
lp,
Tilen
KTr1sk ::
Daj si najnovejši nero gor:Nero Burning ROM 6.3.1.20
Bug Fixes:
Nero Burning ROM / Nero Express:
A Windows XP SP2 compatibility problem is solved
In the expert features of the preferences a localisation problem is solved
Wrong message was shown when an installation was cancelled
New function was added for changing the booktype with several drives
Implemented a workaround for some device specific problems
A problem with the audio plugin manager is solved
Improvement for DVD+VR support on DVD+R9 media was made to determine if a layer breakpoint is set
While opening the setting tab in the expert feature an error occurred
Burning a VCD from a MPEG-1 file failed under Windows™ 95b
Nero Burning ROM:
All controls are now disabled after the burn process is finished
When adding data to a DVD-RW instead of overwriting existing data another media was demanded
A problem with burning VCD is resolved
Fixed a problem that some burnt CD medias were not readable anymore
An unnecessary system reboot at the end of a DVD–VR disc copy process is solved
Audio CD image copy with checked option “copy all subchannel data” resulted in a CD with silence and clicks
Fixed a instability problem when copying a DVD-VR disc
Nero Express:
A problem with a strange title name in Nero Express is solved
When an AAC and a WMA file were added, the slider could not be moved
An error occurred when trying to burn a S-VCD from a S-VCD compliant MPEG-2 file under Windows ME™
A problem with adding DRM protected audio files to Nero Express has been solved
The volume label name of a DVD video compilation is now corrected in case of specific system language
A localization problem under Korean systems in the time track for creating audio CDs is solved
The time-slider in the preview window was jumping back after moving
Fixed a problem in the preview movie player
A multisession CD could not be continued after two sessions
Can’t enter more than only one Korean word in VCD disc name is resolved
A problem with VCD burning under Windows™ 98 SE is resolved
Improvement for displaying Thai text strings on some buttons was made
Adding a video file to a compilation with the add button wasn’t possible
Nero StartSmart:
Fixed a problem with user profiles
Entering a new serial number was rejected with an error
Resolved a GUI problem when switching languages
Nero BackItUp:
Some GUI improvements are made
Nero Wave Editor:
Playback of a WMA file failed when a file was opened the first time
Nero Cover Designer:
A problem that was caused by clicking on the brush tool is fixed
Bug Fixes:
Nero Burning ROM:
Nero Express:
Nero StartSmart:
Nero BackItUp:
Nero Wave Editor:
Tilen ::
kr neke probleme mam ne .. noce pa sm instaliral ta novo verzijo gor kot si mi rekel.
Isti error kot prej ...
| » | Runtime error pri igrah.Oddelek: Pomoč in nasveti | 1489 (1372) | Dead_Eye |
| » | Valve & STEAM & On-Line gaming (strani: 1 2 )Oddelek: Igre | 10035 (8457) | Tilen |
| » | CATALYST 4.1 Has Arrived!Oddelek: Strojna oprema | 2450 (1855) | tx-z |
| » | CATALYST 3.6Oddelek: Programska oprema | 9021 (8506) | freejack |
| » | Novi Nero 5.5.10.7 je zunaj, če kdo slučajno ni opazilOddelek: Programska oprema | 1799 (1485) | KTr1sk |
