Forum » Operacijski sistemi » knoppix
knoppix
simbad ::
Oj, a se da kako CD verzijo pripravit, da bi samostjno delala brez CDja oz, da bi ta Cd posnel na disk? Imam verzijo 2.4
ql000 ::
evo lenobca:
iz: http://www.knoppix.org/ FAQ -a
Q: Can one also install the distribution from the CD onto a hard drive?
A: In principal, yes (after all, the "master" system also runs on a hard
drive before it is burned to CD). However there is currently no
installation GUI for this, so installation to a hard drive should probably
only be attempted by more knowledgeable Linux users. Assuming the KNOPPIX
system has already booted, installation approximately follows this
procedure:
1.) initialize a free partition with the ext2 file system and mount it on
/mnt/knoppix, for example.
2.) cp -a /KNOPPIX/* /mnt/knoppix/
3.) set up /mnt/knoppix/etc/fstab and /mnt/knoppix/etc/lilo.conf for the
new system (Caution: symlinks in /boot initially point to the Ram
disk!), run lilo.
4.) mkdir /mnt/knoppix/home/knoppix && \
chown knoppix.knoppix /mnt/knoppix/home/knoppix
5.) Reboot, try the system out, fix any broken settings.
(No guarantees.)
Ni glih biser za install, ampak nobody's perfect!
procedure:
disk!), run lilo.
(No guarantees.)
| » | Disk je crknil...Oddelek: Pomoč in nasveti | 1131 (909) | mat xxl |
| » | Iščem živo distribucijo linux-aOddelek: Programska oprema | 2367 (1908) | bluefish |
| » | Slo-techov linuxOddelek: Operacijski sistemi | 1816 (1488) | pobcc |
| » | Linux / netOddelek: Pomoč in nasveti | 2045 (1718) | roscha |
| » | kako "odformatirat" trdi diskOddelek: Pomoč in nasveti | 1557 (1276) | NevarHere |
