Forum » Strojna oprema » ATA disk prenos + QDI Excellent 1 plata
Jernej L ::
glede nadgradnje diskov sem novinec, kupil sem disk:
maxtor diamondmax plus 9
60gb ATA/133 HDD
to zadevo sem priklopil na:
http://www.qdigrp.com/qdisite/eng/produ...
sistem se požene, a diska bios ne more prepoznati,
sploh ga ne štima - ob avtomatskem zaznavanju zmrzne.
bios ima award bug z računanjem kapacitete diskov >= 64GB a
bi moral sistem še vedno zaznati disk, a ne?
tako da patchati bios ne mislim če ni potrebno, je pa patch za
moj bios tukaj:
http://wims.rainbow-software.org/index....
QDI ExcellenX I 02/05/99-i440EX-W977-2A69JQ1HC-00 P6I440EX Excellent I BIOS V1.3SL Feb.5,1999 bp 128 GB
v monitorju junij 2002/stran 38 pravijo:
"Vmesnike ATA za priklop diskovnih enot od leta 1995 vgrajujejo v vse osnovne plošče za računalnike PC."
na strani o moji osnovni plošči pa piše:
Q4 Does the EX mainboard Support ATA66 Hard Disk?
A4 No, because the EX chipset can't support ATA66 Hard Disk.
a na tem disku piše ATA/133, kakšna je razlika?
kabel je isti kot za druge "navadne" diske (80 pinov)
kje se da bolje poučiti o ata diskih?
Lp, Jernej.
60gb ATA/133 HDD
Chipset
* Intel 82443EX, 82371PIIX4-E
Bus Type
* One AGP Slot
* Three PCI Slots
* Three ISA Slots
CPU
* Intel PentiumII Processors 233/266/300/333MHz
Intel Celeron Processors up to 533MHz
(Convertor card with voltage control needed for support)
System Memory
* Two 168pin DIMM sockets, support 8 to 256MB SDRAM or 512MB EDO
BIOS
* 1M memory size
* Award Flash BIOS with PnP ready
* SpeedEasy, LogoEasy, PowerEasy
On board IDE
* Two PCI PIO and Bus Master IDE ports, support up to PIO Mode 4, Ultra-DMA/33
I/O Feature
* Two high speed serial ports (16550 Fast UART Compatible)
* Two USB connectors
* One Enhanced parallel port (SPP/ECP/EPP)
* One Floppy port supports up to 2 floppy drives (360K/720K/1.2M/1.44M/2.88M)
Green Function
* Full support of ACPI and OS Directed Power Management
Advanced Feature
* ATX power supply support
* Provides protection circuit to prevent damage to parallel port
* Supports IrDA infrared
* Anti-virus function, DMI ready
* Supports Windows 95/98 software power shutdown
* CPU power supply 1.3v to 3.5v adjustable
* Supports KB wakeup, PS/2 mouse wakeup, Infrared wakeup (option)
* Supports both internal and external Modem ring power on
* Supports wake-up on LAN
Board Size
* ATX Form Factor 305 x 175mm
moj bios tukaj:
Lp, Jernej.
Daedalus ::
Flashaj bios z najnovejšo različico za tvojo plato. Pa prej 10x preveri, da maš pravi bios, ker je flash z napačnim biosom težko popravit...
Disk bo deloval na plati, ker so vsi diski združljivi z ATA standardi za nazaj. Se pravi, da ATA133 disk deluje na kontrolerju, ki omogoča ATA66/33 prenose. Tvoja plata ima verjetno ATA33 vmesnik, kar pomeni, da bi disk prenašal podatke z max. 33Mb/s. Delati mora, samo prej moraš nadgraditi BIOS, da bo lahko prepoznal disk.
[J.P.Sartre]
[J.P.Sartre]
Jernej L ::
kako pa vem če moja plata sploh ima katerikoli ATA kontroler?
- spremenil: Jernej L ()
Daedalus ::
>On board IDE
Ni ATA kontroler, ampak je IDE kontroler. ATA33/66/133 so načini prenosa podatkov. In ta tvoja plata podpira ATA33, oz. UDMA-2, kar znese teoretično max 33 Mb/s.
Na svoje vprašanje si si že odgovoril s tem, ko si napopal specifikacije plate... Malo sem se mogoče tud jaz zakvačkal s temi razlagami okoli ATA, ampak v grobem je to to. Na IDE kontrole napopaš disk, ki potem deluje s hitrostjo prenosa, kot ga omogoča kontroler ali pa disk, odvisno od tega, ker je počasnejši. V tvojem primeru je to ATA33 oz. UDMA-2, kar je, kot sem že napisal 33Mb/s max.
Za kaj več pa google...
[J.P.Sartre]
[J.P.Sartre]
VASkO ::
pomoje pa si, ker vidim, da se ravno ne spoznas, pozabil nastaviti jumper na disku na pravo pozicijo: master ali pa slave
edit: no, ce je sam na kablu, pol ni vazno
- spremenil: VASkO ()
Jernej L ::
nadgrajeval sem že diske, a ne diske nad 20GB in na take stare
plate.. tako da vem kaj so jumperji in kaj delajo..
bios sem flashal, dela super, hvala za spodbudo :)
sam nekaj še, udma - je to "dobro" nastaviti v biosu kot način prenosa podatkov? ker se mi zdi da so tam neke opcije lba/udma
pa sem v knjižnici na netu da ne morem pogledat..
Daedalus ::
LBA on, pri nastavitvah za prenos podatkov pa na auto. Pa ne bi smelo biti težav...
[J.P.Sartre]
[J.P.Sartre]
| » | Dva računalnika na izbiroOddelek: Kaj kupiti | 1770 (1613) | opeter |
| » | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 2325 (2132) | Blinder |
| » | Plošča QDI KinetiZ-da ali ne?Oddelek: Kaj kupiti | 1935 (1799) | Jux |
| » | QDI plataOddelek: Strojna oprema | 1690 (1615) | Koci |
| » | Soyo????Oddelek: Kaj kupiti | 2323 (2259) | piko |
