Katero compact flash kartico
digitalc ::
Katero bi priporočali (velikost 512 mb ali 1 gb). - ne microdrive.
Naj bi bila tako hitra, da lahko snema film v resoluciji 640 x 480 30 fps na Fuji S602Z.
Trenutno imam od Vikinga 256 mb pa ji to ne uspe.
Sevedaj za najugodnejšo ceno.
hja...posez po karticah z 32x ali 45x hitrostjo...seveda so primerno drazje.
tuki je ena precej poceni
pa se ena
  • spremenil: Dr_M ()
Vanich ::
Vsaka CF kartica brez problema snema video 640x480 30 slik na sekundo na fuji s602 zoom - samo formatirat jo moreš malo drugače. Fora je v tem, da določiš drugo veličino clusterjev, kot je pa po defoultu. Edina posledica tega je, da izgubiš placa za eno sliko. Ampak se splača.
Preber:
I got this technique from an taiwan digicam forum...
Background:
Compact Flash are just formatted like a harddrive, it uses FAT system ("NOT FAT32"), and by default...
128MB CF uses 2048 Allocate Unit Size
256MB CF uses 4096 Allocate Unit Size
512MB CF uses 8192 Allocate Unit Size
What to do:
What they suggested is to use a bigger allocate unit size than the default setting, when you try to format it simply by right-click and select "format", the allocate unit size is fixed. To avoid that...
(All the steps are according to windows XP, I don't if other version have the same equivalent)
1. Open Control Panel
2. Open Administrative Tools
3. Open Computer Management
4. Go to the Disk Management
5. Select the CF and format from here...now you can specify the allocated unit size.
Results:
I have a 256MB Dane-Elec CF card, before using this method, I could only record 63 seconds of VGA videos. Then, I formatted it using 8192 allocate unit size, and now I can record uptil I have 1 second left, that's 218 seconds (the card shows that I have 219 seconds buffer when it is blank), no idea why it won't record for that 1 second.
Side notes: with the old format, 3M Fine gives me 200 pictures, but after format with the bigger unit size, now it shows that I only have 199 pictures.
LINK
digitalc ::
Sem probal na moji Viking 256 MB kartici (foramtiral na 8192) pa je stvar še vedno ista kot prej. Snemanje se ustavi zelo hitro, ne posname cele kartice.
Sem poizkusil formatiranje še na 32K in stvar deluje??? Sedaj lahko kartico posnamem v celoti z filmom 640x480 30 fps???
  • spremenil: digitalc ()
pa ti sploh fotic omogoca neomejeno snemanje filmov??
digitalc ::
Omejen je samo z baterijo in velikostjo CF kartice.
Na microdriveu od kolega sem posnel dokler je šlo, se pravi 1 GB v resoluciji 640x480 30fps.
USB ključek ne kaže pravilne velikosti datotek?
62128 (1893) urli
Format diska - allocation unit size ???
81723 (1016) T_F_7
Pomoč pri izbiri digitalnega fotoaparata....
372982 (2576) Koci
Zakaj mi ne ponudi opcije formatiranja v FAT32 ?
51576 (1497) sinko999
Kje v Lj. najceneje do CF 256MB kartice?
232515 (2065) BlackHole
