Slackware 9.1+gnome--Vprašanja
thinker ::
1. Kako v Gnomu nastavit SLO tipkovnico? TOSHIBA LAPTOP
V etc/profile sem dodal zadnjih 5 vrstic
# Set the values for some environment variables:
export MINICOM="-c on"
export MANPATH=/usr/local/man:/usr/man:/usr/X11R6/man
export HOSTNAME="`cat /etc/HOSTNAME`"
export LESSOPEN="|lesspipe.sh %s"
export LESS="-M"
export ROOT_USES_LANG="sl_SI"
#export LANGUAGE="sl=_SI"
export LANG="sl_SI"
#export LC_ALL="sl_SI"
export LC_CTYPE="sl_SI"
v etc/X11/XF86Config sem spremenil 102 v 105 in en v si
# These are the default XKB settings for XFree86
# Option "XkbRules" "xfree86"
# Option "XkbModel" "pc105"
# Option "XkbLayout" "si"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
stvar ne deluje
2.Problem z miško
Imam usb miš in ne dela kolešček ,tudi miš v tipkovnici ne dela.Pod Win2000 delata obe
ection "InputDevice"
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
# Option "Protocol" "Auto"
# The available mouse protocols types that you can set below are:
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
# ThinkingMouse ThinkingMousePS/2 Xqueue
Option "Protocol" "PS/2"
# The mouse device. The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
Option "Device" "/dev/mouse"
# Option "Device" "/dev/psaux"
# Option "Device" "/dev/ttyS0"
# Option "Device" "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Option "Protocol" "Xqueue"
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
3.Imam isdn modem Mini Vigor 128 ingonilnik za linux miniVigor128-for-2.4.18-V1.1-1.tar.gz
Kako ga konvertiram v tgz,
instaliram,
nastavim povezavo za internet?
Hvala za odgovore :D
moj_nick ::
Znak # pred začetkom vrstice pomeni, da je to komentar in zato ne bo upoštevan pri konfiguraciji, zato pobriši tiste #je v /etc/X11/XF86Config in /etc/profile, katere ne potrebuješ
Za miško spremeni vrstice takole:
spremeni v
Option "Protocol" "IMPS/2"
in pod to vrsto dodaj
Option "ZAxisMapping" "4 5"
.tgz = .tar.gz ;)
110111001001010001010000
  • spremenil: moj_nick ()
64202 ::
drugace ima gnome fensi keyboard layout switcher:
1. add to panel
2. utility
3. keyboard layout switcher
xfree je pa najvecji drek za konfigurirat. se enga mouse wheela ne more "autodetectat". argh. a ni ironicno, da pa picis usb kljuc notr, pa se zloada driver avtomatsko in to ene 20x hitrej ko v winxp?
Ati radeon, Xorg in Xv
Oddelek: Operacijski sistemi
101869 (1741) MasterMind
Gentoo setup problem
252213 (2037) G2
Linux / ATI Radeon / problem z driverji
132225 (2042) ahac
Problem z Linux Red Hat 9
172063 (1896) root987
Vtis Gentoo Linux 1.4
211756 (1520) Brane2
