Forum » Programska oprema » Kako bi lahko zaklenil le določene filee v windowsih?
skrc ::
Oj!
Zanima me če obstaja kak program s katerim bi lahko zaklenil le določene mape u winsih? Vem da bi lahko naredil še en account ki bi imel limited access, samo tega ne želim imeti, ker bi potem imel totalno "zbrko"...
že v naprej hvala in upam da kdo pozna rešitev za moj problem.
SanDLL
SanDLL
- premaknilo iz Pomoč in nasveti: bastadu ()
Hammer ::
File Securer
Opis:
File Securer is a powerful tool designed to protect your sensitive folders and personal files. The program includes some strong security, embedding the protection into the Windows system kernel, both in command mode and windows mode.
With exceptional ease of use, File Securer enables you to hide your folders and files anywhere. The locking and unlocking object functions are integrated with the system pop menu. Simply select the object, click the right mouse button, then click 'lock' or 'unlock', that's all!
Should someone try to access your locked object, the system will say "Sir, give me your password please!", and the tools will record all the error passwords and win-user, then report to you.
Key features:
* Hide and lock your personal folders and files on Windows system kernel
* Password to prevent other users and hackers access
* Integrated with system pop menu
* Drag and Drop method locking object support
* Protected folder and file list check
* Settings wizard support
* All activities are logged
* Password recovery
* Password required for uninstall
Opis:
Key features:
* Password recovery
| » | Skype problemOddelek: Programska oprema | 1852 (1257) | tv6865 |
| » | Ne morem dostopati do folderjaOddelek: Pomoč in nasveti | 852 (812) | medenko |
| » | Šifrirana mapaOddelek: Operacijski sistemi | 2831 (2302) | amigo_no1 |
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2086 (1974) | jarni2 |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2526 (2492) | Mercier |
