MFC 7.0 wizard
MFC 7.0 wizard
losnah ::
Do zdej sem delu v VS6.0 zdej sm pa hotu delat v VS7.0. Samo da VS6.0 nima wizarda.
primer:
V VS6.0 MFC resource sem naredu dialog, not sem dal edit box, static text ... In ko sem koncal sem prtisnu ctrl+W. odpru se mi je wizard, da sem use posmeku- member variable, message maps...
Kako pa to nardim v VS7.0 MFC?
VS 2005 C++ pa ne dela brez NET frameworka
Oddelek: Programiranje
121562 (1410) BlueRunner
apache axis
Oddelek: Programska oprema
81640 (1535) MasterBlaster
[c++] razvojno okolje
111380 (1257) Gundolf
VS C++
342562 (1594) Vesoljc
Visual Basic 6.0
101789 (1651) capitanoss
