Forum » Programiranje » MFC 7.0 wizard
MFC 7.0 wizard
losnah ::
Do zdej sem delu v VS6.0 zdej sm pa hotu delat v VS7.0. Samo da VS6.0 nima wizarda.
primer:
V VS6.0 MFC resource sem naredu dialog, not sem dal edit box, static text ... In ko sem koncal sem prtisnu ctrl+W. odpru se mi je wizard, da sem use posmeku- member variable, message maps...
Kako pa to nardim v VS7.0 MFC?
primer:
| » | VS 2005 C++ pa ne dela brez NET frameworkaOddelek: Programiranje | 1562 (1410) | BlueRunner |
| » | apache axisOddelek: Programska oprema | 1640 (1535) | MasterBlaster |
| » | [c++] razvojno okoljeOddelek: Programiranje | 1380 (1257) | Gundolf |
| » | VS C++Oddelek: Programiranje | 2562 (1594) | Vesoljc |
| » | Visual Basic 6.0Oddelek: Programiranje | 1789 (1651) | capitanoss |
