Forum » Omrežja in internet » Zavračanje emailov
Zavračanje emailov
kalisto ::
Subject: ATTENTION: Bounced Message Notification, Total Bytes!!
Date: Fri, 13 Feb 2004 11:35:21 +0100
A message was sent to you that was returned to the sender(bounced)
because it would have caused your mailbox quota to be exceeded.
The following is the reason that the message was over quota:
Quota Type: Total Bytes
Quota Available: 15117
Total Quota: 25600000
To fix this problem, delete some messages from your mailbox, and contact
the sender to resend the message.
If the size of the message is too big, contact the sender to reduce the
size of the message and resend the message
Tale problem se mi je pojavil pred kratkim.
Zbrisal sem vsebino poštnega predala na siolu
vendar problem ostaja.Uporabljam OPERO 7.23
Prej sem za pošto uporabljal Outlook in nisem imel nikoli podobnih problemov.
kalisto
kalisto
ali3n ::
verjetno nimaš omogočenega brisanja sporočil s servera po tem, ko jih pobereš dol...
- "Rozi vidm." "S psom!"
| » | Kako odpreti winmail.dat?Oddelek: Omrežja in internet | 4292 (3928) | mm&r |
| » | avtomatsko vrnjen emailOddelek: Pomoč in nasveti | 2621 (2416) | Spajky |
| » | email narejen z html+cssOddelek: Programiranje | 2897 (2090) | mitjaxp |
| » | Uničujoči virus diskov na pohodu preberite si!Oddelek: Omrežja in internet | 2876 (1952) | demag |
| » | outlook expressOddelek: Pomoč in nasveti | 3325 (3158) | ABX |
