email narejen z html+css
nobodyelse ::
Hocem napisat html+css email in ga poslati prek gmaila.
Lahko kdo pomaga? kaksen link al pa nasvet.
tenx
Lp A
Hardstyle ::
ne gre.
t3hn0 ::
prek php je dejansko to edina moznost :)
seveda "more" mail vsebovat css v glavi, ker drugac lahk pride do komplikacij...
edit: kaj pa drugace manjka e-mail clientom? z njimi lahko (ubistvu se v vecini uporablja html format) posliljas take maile...pac tam notr naredis par tabel, crke se tud da oblikovat
  • spremenil: t3hn0 ()
JanK ::
7 reasons why HTML e-mail is EVIL!!!
1. HTML e-mail is dangerous
Nearly all viruses are transmitted by email. Both plain text and HTML mail may carry malware attachments but with HTML there is a significantly greater risk since some malware can exploit vulnerabilities in the HTML parser to automatically execute code as soon as the message is viewed in the preview pane (i.e. without the attachment having to be 'opened'.)
2. HTML e-mail wastes bandwidth
Look at the source code of any HTML message and after the headers you'll see the message body is duplicated, once in plain text and once in HTML. So most HTML messages are at least twice as big as plain text only, and they can be many time larger.
3. HTML e-mail doesn't always work
Some popular e-mail readers (e.g. Pegasus) simply don't read HTML mail, others (Pocomail and even AOL) have difficulties displaying it properly.
4. HTML e-mail can connect to the internet by itself
If you're off-line, opening an HTML email cantaining images may (by default) open a connection to the internet.
5. HTML e-mail renders slowly
Some mail apps (e.g. Outlook) can slow down considerably when rendering HTML. The need for an HTML parser has also led to code-bloat in email apps generally.
6. HTML e-mail is not always reader-friendly
HTML allows the sender to use unreadably small or non-standard fonts, clashing colours, badly formatted images and sometimes there is no quick or easy way for the reader to adjust the appearance to THEIR choice.
7. Digested lists hate HTML mail
Subscriber lists, particularly those with a digest, discourage and sometimes block HTML (since it appears in the digest as a mess of code).
BlueRunner ::
Dajmo se malo ustaviti...
Kaj je tukaj sploh osnovno vprašanje:
- Kako poslati takšno sporočilo preko spletnega vmesnika? Ne bo šlo. Pa še napačna tema.
- Kako poslati takšno sporočilo preko GMail SMTP strežnika? To se da sprogramirati (tudi brez PHP).
- Kako sploh narediti takšno spročilo in ga poslati preko GMail SMTP strežnika? Tudi to se da sprogramirati...
Če pa se sploh ne gre za programiranje, potem je pa to napačna tema.
Torej kaj?
nobodyelse ::
Hvala za odgovore.
V bistvu ni potrebe po css-ju. Hocem naresti sam en lep reklamni email, ki vsebuje par slik.
Zanima me kako to narest v gmailu. Dat notr html kodo. Glede fotk ssm nekaj bral da jih mors dat na server ali pa zraven v priponko(sam ni priporocljivo, ker ce je kdo zbrisi se potem vse podre).
nobodyelse ::
-kako sploh narediti takťno sporo�ilo in ga poslati preko Gmail streŞnika.
Nisem sploh nek web programer, sam eno reklamo z parimi fotkami bom pa ze nekak znal napisat v html-ju.
Preden startam hocem probat kako sploh zgleda. Torej hocem sam seb poslat en tekst z fotko.
Ala:
html
body
p
Slika:
img src="slika.gif"
width="144" height="50">
/p
/body
/html
Kako nej to sprobam?
urban99 ::
Good luck... ko boš ugotovil, kakšna je podpora za takle hec v različnih clientih, se pa javi. Zadeva sploh ni tako trivialna kot si misliš.
Baja ::
zna biti zoprno, ker mas ogromno razlicnih klientov ki si vsak po svoje predstavlja kaj si hotel napisati. drugace pa se html emaili sestavljajo kot strani par let nazaj, tabele za dizajn, inline css (ce le gre uporabi rajsi atribute kot so color="", width="", ..).
pa se en link, kjer je vse skupaj zelo dobro opisano
http://www.sitepoint.com/article/code-h...
tempoFlow ::
Za reklamne namene je daleč najbolje zadevo zapečt v PDF, pa potem pošiljat.
IceIceBaby ::
tempoFlow, to pa niti slučajno ni res.
Resno, kakšen misliš da bo open rate tistih PDFjev. Ljudem se že tako ali tako ne da brat mailov, zelo redki pa bodo odpirali PDF.
Če je HTML mail dobro sestavljen bo vsebina vidna v vseh mail clientih, v tistih z dobro podporo za HTML pa bo viden še pravilen layout, ozadja, slike itd.
nobodyelse, če nameravaš takšne maile redno pošiljati ti predlagam, da uporabiš kakšen email marketing servis (aweber, getresponse...)
Če gre za občasno pošiljanje pa naloži Mozilla Thunderbird in sestavi nov HTML mail. Enostavno lahko dodajaš slike, tabele, oblikuješ tekst itd.
Samo preden boš poslal dobro stestiraj zadevo. Vsaj naslov in podnaslov morata biti vidna tudi, če client ne prikazuje slik.
nobodyelse ::
Imam ze narjen mail :)
Napisal html kodo, odprl v firefoxu ctrl+a, ctrl+c. ter ctrl+v na gmailu, fotke pa dal na web :)
Morm se mal sprobavat kako zgleda v razlicnih mail progih, ter razlicnih resolucijah. Če bi kdo rad videl, mu ga z veseljem pošlem, itq je reklama za mojo web stacuno sloncek.si
Do sedaj sem nasel samo en problem. V gmailu mors klikniti da dovolis prikaz slik. Pac en nadlezen klik. V vecini ostalih progih pomoje ni tega oz. ne vem :)
Posiljati pa mam namen kot spam mail, sam ne glih na hard!
IceIceBaby ::
Večina sodobnih mail clientov ima blokirane slike, moraš kliknit, da ti jih prikaže.
Na spam pa raje pozabi. Jaz imam legit listo strank, ki so se prijavile (double opt in, pošiljam zaenkrat max. 1x mesečno), pa sem že imel opravke z inšpekcijo. Če bi se v tistem primeru izkazalo, da sem pošiljal spam bi takoj dobil minimalno 3000€ kazni + verjetno še kakšen ukrep.
Resno, spam se ne splača. Poleg tega, da te lahko inšpekcija drago stane tudi učinka ne bo. Raje se potrudi in naredi spodobno lead generation akcijo. Veliko boljše je poslati mail na 100 kvalitetnih naslovov kot spam na 10k.
nobodyelse ::
Jep za zacetek bom posiljal samo na izbrane maile 100-300.
Hvala usem za info.
BigWhale ::
Hvala usem za info.
Na izbrane maile? Torej na tiste maile katerih lastniki so ti dovolili, da jim posiljas spam?
R33D3M33R ::
Zato pa daš v .ppt ali .doc Je zelo popularno -še posebej v verižnih pismih.
gokky ::
BigWhale je zadel bistvo.
Preden se lotiš pošiljati si dobro preberi ZVPot-UPB2. Še posebej bodi pozoren na 45.a člen in njegove sankcije v 1. odstavku 77. člena.
Tilen007 ::
Vso srečo pri 'marketingu'... in hvala za opozorilo, pri meni je @sloncek.si že na block listi.
Pa še nasvet glede html mejla: res dobro stestiraj, ker včasih dobim taka skropucala v obliki html, da je noro. Če že uporabljaš html potem vsaj poskusi to izkoristiti v tem smislu, da bo vsaj za pogledat. Ne pa naslov z rdečimi bold črkami, slike pa nametane levo in desno kot novoletna smrekca.
Pa dej mal preber kako se uporablja email za marketing, internet je poln nasvetov, dobrih in tud slabih. Probi ne samo mejl v stilu ' juhu, lejte mene, jest pa to prodajam...' ampak jim dodaj recimo kakšen popust, kupon, opozori na kakšno novoletno akcijo... neki tazga, da se jim bo splačal it sploh pogledat tvojo stran. Ker verjemi, da možnost, ko nekdo vid tvoj 'spam' in se točno takrat spomne 'sej res, jest pa to rabm... dobr da sm dubu tale spam...'... to je pravljica.
Aja, kaj je zate 'spam na hard'? Da ga pošlješ na 100 naslov al na 1Mio? Ker ko jest dobim spam, me prov nič ne zanima ali sem eden izmed tistih 5 izbrancev, ali pa med 100Mio 'izbranci'...
IceIceBaby ::
100 ali 100000 naslovov - čisto vseeno. Dovolj je ena prijava pa ti bo žal, da si sploh razmišljal o spamu.
Kar se pa e-mail marketinga samega tiče je pa področje kar obsežno. Na kratko povedano - direktna prodaja preko e-maila v smislu enkratnih obvestil se ne splača. E-mail marketing je bolj proces, v katerem ohranjaš stike s strankami. Skoraj obvezno je treba v sporočilih strankam nekaj ponuditi. Poleg popustov še kakšne brezplačne (koristne, ne kr neki) informacije itd.
krho ::
Not a problem s pravim mail klentom.
Agree.
IceIceBaby ::
Pri današnjih povezavah in računalnikih tole ni ravno problem.
mitjaxp ::
poskusam tu sam poslati novoletno čestitko vsem registriranim članom pa mi nikker ne rata poslat html mail u bistvu bi rabu sam prilepit sliko ko posljem prejemniku ispiše le kodo in ne prikaže slike kk prepricat npr gmail da bo bral html kodo ni problem poslat taksen mail prek outloka problem je pa preko enostavnega mail clienta za posiljanje masovnih mailov (wordpress plugin)
Gmail - Kako
Oddelek: Omrežja in internet
62250 (1845) T-Majo
Mailing lista - html
Oddelek: Izdelava spletišč
101590 (1434) IceIceBaby
kako se znebit spam-a?
222632 (2090) zee
Mail: plain text s pdf priponko ali html brez nje ?
81535 (1448) Gandalfar
Htmlentities()
Oddelek: Programiranje
101856 (1715) rc-car
