Forum » Navijanje » twinmosi zavirajo navijanje proca?
NevarHere ::
tule je slikca:
moj PC spec:
256mb twinmos pc2700 dual chan ram
p4 2.0 northwood proc (vcore skoz 1.5V)
asus p4b533 plata
(in temp. proca okoli 42°C :)
malo sem se špilal po biosu in sem ugotovil da lahko navijem samo do tisti RAMove (twinmos pc2700 256mb ) meje kar je 333MHz in ce se zelo potrudim lahko pridem do 344MHz, 128mhz system bus ter 513mhz FSB. takrat pridem do 2.56ghz in ne vec kot 44°C proca in 57°C pri full obremenitvi proca.
nekaj sem spreminjal CAS opcije in sem prisel od 1.5-2-2-5 (v glavnem sem spreminjal prvo in zadnjo št.), ter tudi turbo funkcijo ;) (in napetost))
ko sem zagnal prime95 (sem imel nastavljeno po max. nastavitvah ki sem jih prej opisal in turbo 2-2-2-5 in 2.65V) mi je napisalo:
Prime95 version 23.7, RdtscTiming=1
Best time for 384K FFT length: 14.411 ms.
Best time for 448K FFT length: 17.052 ms.
Best time for 512K FFT length: 19.439 ms.
Best time for 640K FFT length: 23.293 ms.
Best time for 768K FFT length: 28.422 ms.
Best time for 896K FFT length: 33.433 ms.
Best time for 1024K FFT length: 37.553 ms.
[Thu Dec 18 19:55:49 2003]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
(to je neke bayte pošiljal ramu, podobnu pingu...?:)
ko pa sem zagnal torture test pa je takoj neka fatal error kazalo (bsod-a pa ni bilo nikjer)
dodatek:
zajle sem še rame vrnil v teoretično max. settings:
125sys bus, rami delajo na 333mhz, proc na 2.5ghz, turbo je on in 2-2-2-5, 2.65V:
Best time for 384K FFT length: 14.771 ms.
Best time for 448K FFT length: 17.508 ms.
Best time for 512K FFT length: 19.949 ms.
Best time for 640K FFT length: 23.929 ms.
Best time for 768K FFT length: 29.150 ms.
Best time for 896K FFT length: 34.223 ms.
Best time for 1024K FFT length: 38.535 ms.
Best time for 1280K FFT length: 51.063 ms.
Best time for 1536K FFT length: 62.360 ms.
Best time for 1792K FFT length: 73.925 ms.
Best time for 2048K FFT length: 84.359 ms.
in tudi torture je zalaufau(nisem do konca cakal)
tukaj pa imam nastavitve iste ko prej samo da voltaza na Auto (verjetno 2.5V ali malo manj) in 1.5-2-2-5:
Best time for 384K FFT length: 14.814 ms.
Best time for 448K FFT length: 17.501 ms.
Best time for 512K FFT length: 19.975 ms.
Best time for 640K FFT length: 23.931 ms.
Best time for 768K FFT length: 29.216 ms.
Best time for 896K FFT length: 34.260 ms.
Best time for 1024K FFT length: 38.590 ms.
Best time for 1280K FFT length: 51.252 ms.
Best time for 1536K FFT length: 62.523 ms.
Best time for 1792K FFT length: 74.043 ms.
Best time for 2048K FFT length: 85.560 ms.
na
lahko vidite še graf in ostale statistike
dodatek2; graf povprečja:
na
mi lahko mogoce pomagate kje bi lahko proca še bolj navil, mogoče brez efekta na rame?
sem iskal po googlu za northwood operacije, vmodi, al pa karkoli pa ni bilo nič, ništa :\
bom vesel katerokolega responsa
TnX!
tule je slikca:
moj PC spec:
asus p4b533 plata
dodatek:
na
na
TnX!
- spremenil: NevarHere ()
TribesMan ::
Glede na to da maš twinmose, ti svetujem da probaš dat RAS-CAS na 3. CAS ne nastavljaj pod 2. RAS na 2, cycle time pa na 6.
Pa default napetost...
TribesMan
TribesMan
BoLhCa ::
pa tudi plata ti ne koristi 60% tvojega procesorja...
drugac pa res daj na 3 (RAS-CAS)!
napetost dej na max!
moji twinmosi gredo do 240Mhz pri 2.85v!
NevarHere ::
ras-cas sem prestavo kar se pa tiče napetosti pa bom pusto ker se mi pri 2.80V zasteka, oz. zelo dolgo nalaga OS
btw, ze zajle mi delajo na 333mhz pri obicajni frekvenci...
bom se danes ponoči pozabaval z jumperji pa vam bom pol povedo kak bo situacija
TnX!
TnX!
| » | Posodobitev računalnikaOddelek: Kaj kupiti | 2260 (1691) | igiwarcraft |
| » | Obremenitev procesorjaOddelek: Pomoč in nasveti | 1964 (1719) | mesoreznica |
| » | Nimam pojma kaj je tole ???Oddelek: Pomoč in nasveti | 2621 (1802) | Kmet |
| » | Bsodi (problem) 2 jurja dam tistmu k odpravi 2 problemOddelek: Pomoč in nasveti | 2477 (1683) | NighthawkSLO |
| » | Prime95 verzije 23.7.1Oddelek: Navijanje | 1577 (1405) | boštjan |
