Bsodi (problem) 2 jurja dam tistmu k odpravi 2 problem
NighthawkSLO ::
Mam probleme z bsodi!
Mam jih od nove plate (epox 8rda+ limited edition! )
ja na jetra mi gre ko igram katerokoli igro in mi zabije error ali pa bsod.
Probav sm tudi z novimi windowsi pa ni pomagalo. Imam namescene nforce gonilnike (5. 10), vse varnostne popravke (autopatcher, keysers soze 3. 0, + win updates, uporablam win xp)
No bsodi so pa tele?
-0x0a0
-0x0c5
-0x08e
Svoj komp sm testeru z:
-hd tune (disk brez bad sektorjev)
-memtest (ram prezhiben)
-prime95 sledeci problemi (a ne vedno! )
[sun feb 26 11:17:19 2006]
compare your results to other computers at http://www. Mersenne. Org/bench. Htm
that web page also contains instructions on how your results can be included.
Amd athlon(tm) xp 2600+
cpu speed: 1920. 61 mhz
cpu features: rdtsc, cmov, prefetch, 3dnow!, mmx, sse
l1 cache size: 64 kb
l2 cache size: 512 kb
l1 cache line size: 64 bytes
l2 cache line size: 64 bytes
l1 tlbs: 32
l2 tlbs: 256
prime95 32-bit version 24. 14, rdtsctiming=1
best time for 512k fft length: 33. 258 ms.
Best time for 640k fft length: 46. 226 ms.
Best time for 768k fft length: 55. 304 ms.
Best time for 896k fft length: 68. 544 ms.
Best time for 1024k fft length: 76. 348 ms.
Best time for 1280k fft length: 96. 905 ms.
Best time for 1536k fft length: 116. 739 ms.
Best time for 1792k fft length: 155. 699 ms.
Best time for 2048k fft length: 157. 431 ms.
Best time for 2560k fft length: 213. 518 ms.
Best time for 3072k fft length: 279. 083 ms.
Best time for 3584k fft length: 315. 187 ms.
Best time for 4096k fft length: 355. 407 ms.
Best time for 58 bit trial factors: 6. 295 ms.
Best time for 59 bit trial factors: 6. 320 ms.
Best time for 60 bit trial factors: 6. 334 ms.
Best time for 61 bit trial factors: 6. 320 ms.
Best time for 62 bit trial factors: 11. 248 ms.
Best time for 63 bit trial factors: 11. 293 ms.
Best time for 64 bit trial factors: 27. 220 ms.
Best time for 65 bit trial factors: 27. 738 ms.
Best time for 66 bit trial factors: 28. 180 ms.
Best time for 67 bit trial factors: 28. 616 ms.
[sun feb 26 11:24:10 2006]
cpu speed: 1920. 76 mhz
l1 tlbs: 32
l2 tlbs: 256
best time for 512k fft length: 33. 058 ms.
[sun feb 26 13:17:07 2006]
fatal error: rounding was 0. 4998050928, expected less than 0. 4
hardware failure detected, consult stress. Txt file.
[sun feb 26 13:46:36 2006]
fatal error: rounding was 0. 4998745769, expected less than 0. 4
[sun feb 26 13:53:53 2006]
fatal error: rounding was 0. 4999885559, expected less than 0. 4
[sun feb 26 14:15:23 2006]
fatal error: resulting sum was -1. 086599467051591e+088, expected: 2830779598889533
Ok dej mi nej pls en pove kaj je narobi da povem se pol nasledni primer z mjo copperhead misko!
MihaFirst ::
ce ti ne povem rešitve, te pa vsaj lepo prosim - bi mi dal pol vsaj ENGA jurja? :\
www.gamma.si
Dead_Eye ::
1. Na koliko imaš nastavljen FSB? nastavi na 166Mhz
2. RAM? Če imaš več kot 1 ploščico zna bit to problem, vstavi jih v single channel in clock naj bo 166(333)
Glede na Mhz zgleda da CPU ni navit, vseeno preveri temperature...
aja, denar pa obdrži, če ne drugo za novo ploščo :D:D:D
The one and only
  • spremenilo: Dead_Eye ()
Fizikalko ::
Najbrž se tvoja plata ne ujema prav dobro z rami. Povečaj napetost na ramih in opazuj adogajanje. Če ni uspeha, zmanjšaj FSB proca , potem pa počasi večaj in testiraj. Tudi procu bi lahko probal malo napetost povečat. Ampak najverjetneje so rami.
Offtopic: Edward, dam ti jurja, če se odstraniš s foruma.
Fizikalko ::
Aja, glede keša pa - na forumu smo zato, da si pomagamo zastonj. Tako da v bodoče ne skrbi glede tega.
Duhec ::
Tabulator (Nighthawk), podobno kot so že dejali predhodniki in vsi tisti na rumenem forumu-'rumenjaku' (tam ti žal ne morem odgovarjat) imaš po vsej verjetnosti neke težave okoli spomina, ki se navadno manifestira z različnimi BSOD-i.
Torej plata je epox 8rda+ limited edition.
Dobro bi bilo izvedeti celotno konfiguracijo, posebno koliko močan napajalnik imaš, saj je lahko tudi on vzrok, da ti npr. napetost malce zaniha in se to odraža kot BSOD.
Če imaš dva spominska modula jih izmenično testiraj.
Flešaj zadnji bios (29.07.2004), ker je popravek ravno okoli spominov (kompatibilnost) in podpora novejšim CPUjem.
MadMax ::
Kondenzatorji na plošči, ali pa morda okrušen procesor.
tecumseh ::
Prej bi rekel, da gre za sw problem, po moznosti driverji ali pa nekompatibilen softver. Vsaj stop codes kazejo na to:
0x0A - IRQL_NOT_LESS_OR_EQUAL
0xC5 - DRIVER_CORRUPTED_EXPOOL
0x8E - KERNEL_MODE_EXCEPTION_NOT_HANDLED
Prva dva sta povezana z dostopom do memorya, ko kernel-mode proces nima dovoljenja do tistega mem locationa ali pa kadar dostopa s previsokim IRQL. Zadnji je sicer bolj splosen, ampak tudi povezan z napako pri dostopu do memorya. Bolj bi pomagalo, ce bi dopisal se ostale kode iz oklepajev...
Najprej ugasni vse ostale (nepotrebne) programe in procese, vkljucno z AV, FW, ugasni povezavo na net..., potem pa pozeni spil. Najbolje da pred tem restartas comp. Btw: zanimivo bi bilo vedeti ce se to dogaja samo pri igrah, kar bi kazalo na problem z driverjem za grafo. Ce se BSOD se vedno pojavljajo, reinstaliraj driverje za maticno, graficno, zvocno, mrezno in karkoli ostalega, kar se imas. Seveda v pravilnem vrstnem redu in tako, da jih najprej odinstaliras. Ce to ne pomaga, upostevaj Duhcov nasvet glede testiranja RAM-a, napajalnika.. Ce imas karkoli navito, od-navij. V skrajnem primeru odklopi oz. vrzi ven vse nepotrebne PCI kartice, diske, opticne pogone...
Ce kljub vsemu ne bo nic pomagalo, potem se bo pa treba lotit kakega bolj resnega debugiranja...
NighthawkSLO ::
no u kompu mam samo potrebne reci (razn diketnik k mi pride 1 X na let prov :D:D:D)
sedaj sm sistem ponovno formatirav, a nism naloziv gonil od nvidije (samo za pomnilnik) bomo vidl kaj bo !
drugac mam rame u dual chanel na 166 (333)
imam pa najnovejsi bios seveda 1 stvar k plato ulozim u kisto :O !
napajalnik mam 550 W od lcja.
naslednic ko mi zabije bsod ga slikam in vam pokazm !!!
NighthawkSLO ::
evo vrag spet na pohodu
:O :O :O :O
Izi ::
AMD pravi, da naj bi procesor AthlonXP 2600+ deloval na 2133 MHz (133x16) 1,65V
Se pravi default nastavitve so FSB 133MHz, množitelj x16, kar da 2133 MHz in voltaža na 1,65V
Ali imaš tako in zakaj ne?
Če si navijal in prestavil FSB na 166MHz, na koliko si znižal množitelj? Na koliko si nastavil voltažo?
Prime95 pa ti kaže, da ti procesor deluje na 1920 MHz , kar je pri FSB 166 ne paše skupaj z nobenim množiteljem 8-O
Zakaj si sploh nižal frekvenco procesorju?
Meni izgleda kot, da imaš BIOS nastavljen precej narobe.
In če ti Prime95 meče ven napake potem je vsekakor nekaj narobe v BIOS-u
Najprej napiši koliko imaš FSB in množitelj.
NighthawkSLO ::
ej nimam pojma o tem !?!? ze zenim celeronom sm se cev popovne fuku
evo tle mas screen
sm tuki mi pokaze mnozitl ! (u biosu nism dobu)
tole je pa voltaza :
Polje Vrednost
Lastnosti senzorja
Tip senzorja Winbond W83627HF (ISA 290h)
GPU Sensor Type National LM89 (NV-I2C 4Ch)
Ime osnovne plošče Epox 8RDA / 8RGA Series
Temperature
Osnovna plošča 24 °C (75 °F)
Procesor 38 °C (100 °F)
Grafični procesor (GPU) 42 °C (108 °F)
GPU Ambient 33 °C (91 °F)
ExcelStor Technology J880 26 °C (79 °F)
Ventilatorji
Procesor 2192 RPM
Ohišje 1125 RPM
Napajanje 1205 RPM
Napetosti
CPU jedro 1.70 V
+5 V 4.89 V
+12 V 12.22 V
-12 V -12.61 V
-5 V -5.10 V
+5 V Standby 4.99 V
VBAT Baterija 3.07 V
VDD 1.58 V
DIMM 2.75 V
Debug Info F 8C 96 4D
Debug Info T 18 38 24
Debug Info V 63 6A AC B6 C9 1C 34 (01)
kaj morm pa dej !!!!
Izi ::
Aha, ti imaš Barton procesor.
Potem je pa vredu 1917MHz (166x11,5)
Vse izgleda vredu.
Prek tega foruma, ti verjetno nažalost nobeden ne bo mogel pomagati.
Verjetno je problem software. Kakšen driver ali kaj podobnega.
NighthawkSLO ::
in kaj mi ubistvu svetujes :'( :'(
pa kaj misis da je problem (ker driver)
nalozene mam gonilnke za misko (mam razer copperhead), gf 6600 gt pa za plato nforce 5.10
aja en mi je reku da je lahk to zarad napajalnika ??
a je to mogoce
Duhec ::
Če se ti BSOD tako hitro pojavi ne vem zakaj ne poizkusiš delat najprej samo z enim ram modulom (256MB) nato pa ga, če se BSOD ponovi, zamenjaš in testiraš še z drugim.
Lahko zajebava samo v dual načinu, ko sta oba modula aktivna.
SavoS ::
Namesti novejše Nvidia driverje za tvojo ploščo!!!!!!! te 5.10 imajo probleme z USB 2.0 in če imaš slučajno kaj instalirano ali kaj podobnega v zvezi z USB 2.0 ti bo metalo BSOD...... hehe tud jaz sem mel te probleme, dokler nisem dal druge driverje gor....... ;)
Recimo teli so dobri!
Podpis..... Kdo mi je vkradu podpis???
WarpedGone ::
Zameni napajalnik, 90% da je kriv.
V naprej lahk to poskusaš ugotovit s tem, da iz mašine odstraniš vse neesencialne zadeve (razni dodatni diski, dodatne kartice etc) in pustiš sam to kar res nujno da se zbuta.
Al pa da spustiš frekvenco procu in za kako desetinko znižaš napetos jedra (pod 1,5 ne it).
Če to izboljša situacijo (redkejši BSODi) pol je garant napajalnik.
Zbogom in hvala za vse ribe
NighthawkSLO ::
za napajalnik newerjamm k je now lc 550W.
na masini mam pa razer copperhead k dela pod usb 2.0 :D
te gonila ze dol vlecem !!
vam povem ce bo to pol delal
NighthawkSLO ::
ja dej sm driverje updajtu, vam sporocim ce bo sekej metal
glede napajalnika pa , a mi ga uzamejo u garancijo (k mi naprejsn plat delal vse normalno )
Keyser Soze ::
Hm, dolgo je že tega. Plus ne da se mi več /beri: ni časa/ ubadat z navijanjem. Vem pa da je moj leni sistem (NF-7S 2.0 + Barton 2500 + Geil One) vedno metal ven bsod-e dokler nisem zamenjal SATA diska z PATA diskom.
Saj mi je bilo ful čudno ker ni nihče drug imel podobnega problema. Ampak to ti pove, da ni vedno dobro gledat v najbolj očitne zadeve.
NighthawkSLO ::
evo sm probu znizat napetost pa ni pomagalo.
lihkar mi je vn udarilo tale bsod
stav mi rge ze pocvasi nazivce ;((
sm me zanima kaj povzroca problem (upam da ne napajalnik, bi ga ze zamenu sam nimam druzga)
zanima me ce sekaj lahko povzroca napako:O
EDIT:
aja a ma lahk tud kej graficna u zvezi s tem problemom k u telem bsodu neki pise o grafiki :\
prosim za razlozitev (za n44pa :D)
NighthawkSLO ::
ok des sm spustu voltazo za desetinko, in imam se hujse bsode !!
prej mi je npr metalo vn samo u igrah, dej mi pa tudi v okolju win !
npr igram call of duty 2 pa rgem vn zazenem msn in i pokaze bsod :\
kaj mislte da je lahk problem
WarpedGone ::
Če si spustu voltažo, frekvence pa ne je čist normaln da se sesuva.
Če spuščaš voltažo morš pod nujno tut fejst spustit frekvenco. To je moj nasvet, ker boš tko znižal porabo proca in s tem obremenitev napajalnika. Da je stvar 550W ne pomeni nič, zilch, če je nestabilna.
Si preveru kondenzatorje na plati? Je kater kej napihnjen?
NighthawkSLO ::
sem pogledav in se mi zdi da je tam eden bolj majhen napihjen (okoli ramov)
kako se naj prepircam :\
BSOD
51790 (1682) shark_nm
Posodobitev računalnika
312268 (1699) igiwarcraft
Nimam pojma kaj je tole ???
292628 (1809) Kmet
twinmosi zavirajo navijanje proca?
Oddelek: Navijanje
61540 (1365) NevarHere
Prime95 verzije 23.7.1
Oddelek: Navijanje
101583 (1411) boštjan
