Duron 1600 in Abit kr7a "kompatibilna"???
Container ::
Mam plato Abit Kr7a in sem dal zdej not duron 1600 in mi dela blazne probleme računalnik. (primer: quakeIII po par minutah zamrzne in morm PC ugasnt).
Sem ze probavu razne nastavitve po biosu, sam ne kaže, da bi se stvari kej spreminjale.
Zdej sem pa končno pomislu, da bi blo lahko narobe, ker ženem durona na 133 fsb.
A je to uredu? je problem stabilnosti v procesorju? Lahko probam na 200fsb in primernem multiplajerju? Bo to uredu za ram in Grafično?... in plato sploh?
Nujno rabim POMOČ!!!
resetiri bios, uzem rame vn, pa jih dej nazaj not, namaz ga s pasto, na frisno naloi windowse.
nekak v tem vrstnem redu.
Slowenc ::
Podatko o plati:
Supports AMD Duron™ and Athlon™ Socket A processors
200/266MHz FSB settingsSupport for AGP 2X/4X
Supports up to 4.0GB DDR200/266 SDRAM as well as PC100/133 SDRAM and Virtual Channel memory
266MB/sec high bandwidth North/South Bridge V-Link
Support for Advanced Communications Riser (ACR) Card Standard
Integrated 6 channel AC-97 Audio
Integrated MC-97 Modem
Integrated 10/100 BaseT Ethernet and 1/10Mb HomePNA controller
Support for ATA 33/66/100
6 USB ports, UHCI compliant
Advanced power management capabilities including ACPI/OnNow and AMD's PowerNow™
552-pin BGA VT8366A North Bridge
376-pin BGA VT8233 South Bridge
podatko o duronu 1600
AMD Duron 1600 MHz:
- Producator: AMD
- Soclu: Socket A
- Bus: 333 MHz
- Cache L1: 128 kb
- Cache L2: 64 kb
- Instructiuni : MMX, SSE, 3Dnow !2
Dej durona na 266 fsb
Skiny gate.
Container ::
hvala za hiter odgovor, ampak mene neki druzga zanima. zdej sem šou na abit stran in ugotovu da moja plata podpira samo naslednje:
Processors based on 200/266 MHz(100MHz/133MHz Double Data Rate)
Jest mam 265 ddrama pci 2100 torej 133mhz če jest kej vem. In torej ne smem procesorja navit na 200 fsm al kaj???
še enkrat hitrer odgovor prosm
(še zanimivost. Zdele delam na tem računalniku in sicer na enem disku 3g velikem, z windosi s prejšnjim procesorjem inštaliranimi. mam pa disk 80g k mi noče windowsov pognat oziroma mi vrže nek čuden blue-screen, kjer se na da prebrat kej dost kr hitr pol resetira.. pa mi je na tem disklu že laufu... ČUDNO, ni kej):\
Container ::
uuuu, ste hitri, ne dohajam...
Ampak a ne bo potem temperatura drastično višja?? zdeej mam okol 37celzijev.
pa morm to počas narest = postopoma al kr naenkrat z multi0plajerjem 8 in fsb 200???
8-O
kaj bo pa ram reku pci2100!!!
kuglvinkl ::
Pozabi na 200 FSB že zaradi chipseta, kaj šele zaradi RAMov.
hm...
zdej je tko..fsb je lohk 100,133,166,200mhz ali ddr 200,266,333,400. vidis povezavo?
tvoj duron dela na 133mhz oz ddr 266. ram pravtako ce mas pc2100.
se pravi da dela ram dela sinhrono z fsb-jem, kar je nekak optimalno.
Container ::
TOREJ NAREDIM, KAJ???
pustim na 133 al dam na 266 fsb???8-O
Container ::
al je to isto sranje...
to je to.:)
Container ::
v bistvu ga mam jest že zdej na 266? (ko ga mam na 133???
potem ni kriv procesor in moja plata je čist zadovoljna z njim??? in je keč nekje drugje..:\
tako je.
za zacetek resetiri bios. dej ram na 266 ce slucajno ni. itd.
Container ::
slowenc je reku da:
- Bus: 333 MHz
za procesor. torej to pomeni 166 ddr??:\
ja kle zna bit problem..ce mas ti zdej fsb/ram sinhrono in fsb na 333, te ram jebe pol...
Container ::
v biosih piše:
current ram frequency na 133
torej je to ddr 266, ker bi moglo bit kul, ne?
biose sem že resetiru.
nej povem še par zenimivih bedarij:
-že ko sem probu inštalirat winXP s tem proc in diskom 80 giga mi ni hotu skopirat par fajlov. nevem zakaj. Zasilo sem inštaliru win na drugi (čist podobni plati abit kg7a in potem driverje naložu na tej plati).
- logično je, da so zato slabi windowsi, ampak Quake III nima kej dost veze s tem, ali pač?
- enkrat i je celo word šteku ko sem delu en večji dokument.
- unreal tournament mi je kazu z debilno grafiko, k je blo vsake tok časa vse prozorno.
- probavu sem nastavitve v biosu za grafično, pa ni blo nč drgač
dobr. tvoja plata uradno podpira fsb max 266mhz. ram pravtako. oboje laufa na 266. se prav tuki ni problema.
bios si resetiral...
kaj pa timinigi rama?? je by spd??
kako pa je s hlajenjem? je prisotna pasta med jedrom procesorja in hladilnikom?
Container ::
ja pašta je prisotna, inštaliru mi ga je bivši uradni profesionalac (serviser)...
sej, tud to sem probaval - torej ne "by spd" po navodilih enga dobrga pejđa za to plato, pa ni blo nč drgač.
Še najbolj me zdej skrbi ko mi noče windowsow na disku maxtorju (80g) zalaufat. je lahko kašna nastavitev za ide?:\
kako ne zalaufa? se pojavo BSOD, enostavno zmrzne, al kej tretjega?
Container ::
morm povedat, da mi je stvar tud prej, ko sem mel duron 900 not in disk 3giga zaštekala na podoben način. Ko sem gledu divx mi je kr naenkrat butnu bluecsreen in resetiru. Torej nevem če je disk kriv...
Container ::
se pojavo BSOD???kaj?
blue screen v nekakšni obliki. ko mi že naloži desktop, al pa še to ne, pa cup... pa ni več.. Pač piše nek error, se mi zdi in še neki vrstic info, česar se ne da prebrat ker mi ga takoj resetira.
IRQ_not_less_or _equal
verjetno kej tazga. ponavad je to tezava s pregrevanjem, ni pa nujno.
vec trenutno nebi vedu z glave.. :\
Container ::
pregrevanje česa? če mam pa procesor na 37 stopinjah?
no, tud na irq-je sem pomislu, pa ne bi smel bit problem ker nimam problematičnih kartic not...
jest10 ::
Procesor ni edina stvar ki se lahko pregreva.
Jaz mislim da ti rami popuščajo
Thanatos ::
respect to dr M, da imas zivce se s takim novincem ubadat :D
Thanatos: ja ucas me kr zagrabi, da bi nekomu pomagu :) :D
Container ::
ja, hvala za spoštovanje, .....:(
(res ne vem kdo se je ubadu s tabo, mr. Thanatos, ko si bil ti "novinec")
drgač sem pa pogruntu u čem je problem...
zalaufu sem memtest86 in mi je pri petem testu pokazu eno tono errorjev.
Kokr pravi memtest to baje ni nujno sesut ram, ampak lahko tud nekompatibilen.
jest mam no-name ram in je čist verjetno da se nekako ne razumeta s procesorjem. Lahko ga zamenam, sam ne vem kako bo to šlo na moji plati
(Supports up to 4.0GB DDR200/266 SDRAM )
hvala za ideje...
eno vprasanje glede RAM-a
151743 (1577) lambda
Je kriva plosca za memtest errorje/nestabilnost?
Oddelek: Navijanje
82281 (2133) AtaStrumf
hitrost rama
202143 (1770) royt
ABIT KT7 RAID-ATHLON1300
271921 (1447) ijatebi
Ferkvenca al Faktor?
Oddelek: Navijanje
242211 (1989) SaTaNIsT
