P: Thermalright Burst Assassin 120 ARGB NOV Zapakiran + NOV dodatni ARGB ventilator
nejko8 ::
rodam nov zapakiran CPU hladilnik.
Za podnožja:
Intel:115X/1200/1700/1851
AMD:AM4/AM5
Povezava do strani proizvajalca: https://www.thermalright.com/product/bu...
Technical Spec :
Heatsink Specifications:
Dimension:L124 mm x W52 mm x H154 mm
Weight:510g
Heat pipes:6mm heatpipe x 6 units
Copper Base:C1100 Pure copper nickel plated
TL-C12CG-S FAN Spec:
Dimension:L120 mm x W120 mm x H25 mm
Weight:120g
Rated Speed:1550 RPM±10% (MAX)
Noise Level:25.6 dBA
Air Flow:66.17 CFM (MAX)
Air Pressure:1.53 mm H2O (MAX)
Ampere:0.20 A
ARGB Port:5V/3Pin
Connector:4 Pin (PWM Fan connector)
Bearing Type : S-FDB Bearing
Priložim še 1 dodatni nov Thermalright ARGB ventilator, tako da lahko na hladilnik namestite dva za boljše hlajenje in airflow v ohišju!
Cena: 25€
Kontakt na ZS.
P: prenosnik HP EliteBook 840 G7 i5 10. gen/ 16GB RAM /256GB SSD
240 €
Oddelek: Mali oglasi
0248 (248) nejko8
P: 2x 8GB DDR4 RAM SODIMM 3200mhz Micron
55 €
0154 (154) nejko8
P: SSD 256GB NVMe M.2 SK Hynix PCIe
25 €
0145 (145) nejko8
55 €
0174 (174) nejko8
25 €
0157 (157) nejko8
P: Thermalright Phantom Spirit 120 EVO CPU Hladilnik
35 €
0152 (152) nejko8
40 €
0179 (179) nejko8
25 €
0175 (175) nejko8
