Forum » Mali oglasi » P: Thermalright Phantom Spirit 120 EVO CPU Hladilnik
nejko8 ::
Prodam vrhunski hladilnik. Brezhibno delujoč in malo rabljen. Priložen ves material za pritrditev.
Podnožja:
Intel:LGA115X/1200/1700/1851/2011/2066
AMD:AM4/AM5
Uradna stran proizvajalca: https://www.thermalright.com/product/ph...
Technical Spec :
Heatsink Specifications:
Dimension:L110 mm x W125 mm x H157 mm
Weight:810g(Without Fan)
Heat pipes:6mm heatpipe x 7 units
Copper Base:C1100 Pure copper nickel plated
TL-K12 FAN Spec:
Dimension:L120 mm x W120 mm x H25 mm
Weight:220g
Rated Speed:2150 RPM±10% (MAX)
Noise Level:27 dBA
Air Flow:69 CFM (MAX)
Air Pressure:2.87 mm H2O (MAX)
Ampere:0.16 A
Connector:4 Pin (PWM Fan connector)
ARGB Connector: 3 PIN 5V
Bearing Type : S-FDB V2 Bearing
Kontakt na ZS.
Cena: 35€
Podnožja:
AMD:AM4/AM5
Technical Spec :
TL-K12 FAN Spec:
Weight:220g
Noise Level:27 dBA
Ampere:0.16 A
Kontakt na ZS.
Cena: 35€
| » | 2x 8GB DDR4 RAM SODIMM 3200mhz Micron55 € Oddelek: Mali oglasi | 173 (173) | nejko8 |
| » | P: prenosnik HP EliteBook 840 G7 i5 10. gen/ 16GB RAM /256GB SSD240 € Oddelek: Mali oglasi | 212 (212) | nejko8 |
| » | P: SSD 256GB NVMe M.2 SK Hynix PCIe25 € Oddelek: Mali oglasi | 162 (162) | nejko8 |
| » | P: Thermalright Burst Assassin 120 ARGB NOV Zapakiran + NOV dodatni ARGB ventilator25 € Oddelek: Mali oglasi | 156 (156) | nejko8 |
| » | P: Thermalright Phantom Spirit 120 EVO CPU Hladilnik40 € Oddelek: Mali oglasi | 179 (179) | nejko8 |
| » | P: Thermalright Burst Assassin 120 ARGB NOV Zapakiran25 € Oddelek: Mali oglasi | 175 (175) | nejko8 |
